Eric Cox | 04/03/2015 09:00:23 |
![]() 557 forum posts 38 photos | Looking at various photographs of the Stuart Major such as the cover photo of ME 4501 the parallel linkage is fastened to a "U" shaped casting but other photos on t'internet show the linkage secured by under slung plummer blocks on two strips of metal.. Which is standard ie supplied by Stuart. If it's the metal strip option where are the "U" shaped casting obtained from. |
JasonB | 04/03/2015 09:04:47 |
![]() 25215 forum posts 3105 photos 1 articles | I have always gone by the "Major beam" having the U shaped casting and the smaller "beam" having the two straight strips of metal. Problem with google images is it will show pictures that contain some of the words and miss out the "major" Easy way to check if it is a Major is by the valve chest facing the column, + section conrod and ringgear next to the flywheel as I have seen the basic beam with a U shaped bracket machined from solid on more than one occasion
J Edited By JasonB on 04/03/2015 09:07:55 Edited By JasonB on 04/03/2015 09:08:39 |
Stuart Rogers | 04/03/2015 09:16:32 |
12 forum posts 1 photos | Andy Meakin at Stuarts - a most helpful chap, on 01308-456859, is your best bet. E-mail address is sales@stuartmodels,com |
Michael Gilligan | 04/03/2015 09:17:01 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 04/03/2015 09:04:47:
Problem with google images is it will show pictures that contain some of the words and miss out the "major" . In the early days of google, I'm sure it was possible to "enforce" a search-term by prefixing it with + ... but that doesn't seem to have worked for some considerable time. What does seem to help is to enclose a required phrase within quotes i.e. "Stuart Major" should give better results than Stuart Major MichaelG. |
