old hand operated drill that needs identification
Ebay purchase ,no name or make on it any ideas ?
I.M. OUTAHERE15/12/2014 06:00:41
1468 forum posts
Hi everyone,
I picked this up on Ebay and would like to know more about it but it has no makers name on it - may have been on the front cover but this looks like it may be home made and not the original.
It works fine and will be used as a sort of pillar drill for tapping etc although i need to lock the auto feed on it ( works by rotating the flywheel on top as best as i can see)
For $17 i reckon it was worth it even just for the curiosity factor !
It is around 400 mm high at maximum .
Wish i knew how to rotate the pictures !
Ian
Michael Gilligan15/12/2014 06:23:04
23121 forum posts
1360 photos
Have a look at this thread
Nicholas Farr posted a picture of an old Tyzack advert.
Nicholas Farr15/12/2014 06:39:15
3988 forum posts
1799 photos
Hi Ian, Michael has beaten me to it, and yes I believe the front cover has been replaced with a home made one. You can see photo's of mine all stripped down in this **LINK** but ignore the last three as they relate to another drill, also the stand on mine is not the correct one.
Regards Nick.
Edited By Nicholas Farr on 15/12/2014 06:46:22
I.M. OUTAHERE15/12/2014 23:20:48
1468 forum posts
Thanks Michael and Nick,
I think a good clean and lube is in order then bolt it to my bench.
Probably end up with a countersink bit in it .
Ian
martin perman16/12/2014 12:06:23
2095 forum posts
75 photos
Ian,
I have several options to rotate pictures, the first is my camera, I can rotate the picture using its software, the second is PIXsizer which I use to reduce the pictures before up loading to Websites, windows 8.1 does it and finally Paintshop Pro does it for me.
Martin P
Muzzer16/12/2014 16:52:19
2904 forum posts
448 photos
"Wish i knew how to rotate the pictures !"
If you saw my rant a couple of months back, you'd know that the only solution I found was to get rid of Windows 8 / 8.1. Luckily I am now back on W7 and much better for it. And I refuse to bu**er about with 3rd party programs just because some smart 4rse at Microsoft decided to change something. I even paid £40 extra to have W7 on a new laptop rather than W8.1
There.
martin perman16/12/2014 17:02:47
2095 forum posts
75 photos
I didnt see your rant and I apologise for trying to be helpful, now over to you for the same.
Martin P
