Cheap milling machine light
Articles
George Round's Home-Made Lathe
Over the years Model Engineer and Model Engineers' Workshop have featured many home-built tools, not least several lathes. In 1959 Model Engineer ran a six part series on an impressive 3 1/2" centre height lathe built by George B. Round. Subscribers Only
James Lawson07/12/2014 19:34:08
1 forum posts
Asda sell 3inch long torches for £3. I tapped a 2BA thread into my Warco machine,screwed a spring clip on, and now have an excellent light. Brilliant! JHL
Graham Wharton08/12/2014 11:45:14
149 forum posts
48 photos
It would be good to see a picture James.
Cheers
Graham
fizzy08/12/2014 11:59:09
1860 forum posts
121 photos
I bought 4 led pads of fleabay for pence, stuck to underside of head they illuminate whole table very well
Capstan Speaking08/12/2014 12:51:10
177 forum posts
14 photos
Machine Mart do a proper "Angle Poise" type lamp for £15 and a magnifier for £20.
Jesse Hancock 110/01/2015 19:35:20
314 forum posts
Yes I have one of those. It has come in for some heavy use over the time I've had it.
Just one criticism and that's the clamp. It comes out in your hand if you aren't too careful and with the head at full stretch the plastic come L shaped metal configuration tends to squirm its way off the bench. Upgrade that DIY wise and you have a winner.
Jesse
Jesse Hancock 102/03/2015 20:49:41
314 forum posts
A friend living close by had junked a desktop lamp in her recycle bin. I asked if I could have it and she said sure.
I took it home thinking I'll attach it to the back of my cross work table but as it had been outside I took it apart to dry it out.surprise The light turned out to be from a twelve volt halogen car bulb and the lamp had a 13amp plug attached!
(W)omen.
Edited By Jesse Hancock 1 on 02/03/2015 20:51:58
Howi03/03/2015 08:44:13
442 forum posts
19 photos
Posted by Jesse Hancock 1 on 02/03/2015 20:49:41:
(W)omen.
12v bulb on 240v - that should be bright enough for anyone!!!!!!!!!
Edited By Howard Winwood on 03/03/2015 08:46:03
IanT03/03/2015 09:18:14
2147 forum posts
222 photos
I purchased a couple of those torches at a National Trust shop last summer (also £3) - I meant to make some mounting clips but I've not got around to it yet - they give very good illumination and I have one in my pocket most of the time. Very small and handy.
A week or so ago - I saw some mains-powered "clip-on" LED lights - quite dinky for just £3.99 in Lidls.
One of those is now clipped to my Cowells drill - it's got a flexible neck and gives a very good light. The clip end of the flexible bit is screwed & nutted on to the actual clip - so it would be easy to re-mount the lamp on anything with a suitable hole. However, I'm finding the 'clip' quite useful for positioning the light and is fairly strong - so I may just screw a flat metal strip under drills headstock to clip the light to. Cheap & simple.
IanT
Clip on LED - Lidls
Clip on LED - Lidls
