Rebuild & Restoration
Keith Calleja | 04/12/2014 12:42:42 |
14 forum posts 20 photos | Hi, I recently bought this Progress No.1 Bench Drill which I am currently rebuilding and restoring. At the moment I am going to fit new bearings for the replaced motor (Gryphon single phase 1HP) and new bearings for the spindle/pulleys. Then I will continue stripping the old paint and painting it with new paint. Will be fitting the MT1 with a ER26 Collet holder and fitting an old Mercer Dial Gauge to the feed gauge. I also need to fabricate some of the missing parts like: Tool Tray, Black Knobs (ebay), Feed Handles x3, top fixing nut/spring/stud, Feed gauge knurled nuts, grease nipples (local stores), new braided power cable (local stores). It was in good working condition but I will be re-wiring the whole thing with a new configuration to hopefully have a reverse function as well. Photos to follow.
Keith Calleja | 04/12/2014 12:44:08 |
Keith Calleja | 04/12/2014 12:45:14 |
IanT | 04/12/2014 16:23:47 |
2147 forum posts 222 photos | These are nice solid drills Keith - but very heavy for their size (the cast iron belt cover doesn't help either). I had a No. 1 for a while but mine had a Jacobs taper nose fitted - with (I think) a 3/8th Jacobs chuck. I gave it away to a friends' son when I acquired a used Warco MT2 drill (12 speed). I have several sizes of MT2 drill chucks I use with it, so that's useful. The table 'rise and fall' rack is also very good when I have heavier things mounted on the table (compounds for instance) and I can crank them up and down - but otherwise I'm pretty sure I could have lived quite happily with the Progress. Nice machine - enjoy. Regards,
IanT |
Roger Hart | 04/12/2014 17:03:15 |
157 forum posts 31 photos | Very nice machine. Enjoy the restoration, will you be keeping the 'extended' feed handles, useful for those watchmaker jobs..... |
Vic | 04/12/2014 18:51:52 |
3453 forum posts 23 photos | For ball handles you can use Golf Balls or Pool Balls! |
Keith Calleja | 05/12/2014 07:03:50 |
14 forum posts 20 photos | Good morning from Malta Thanks for all the comments, I really like old British tools and their robustness so being a heavy drill is a plus for me http://www.ebay.co.uk/itm/190837418777?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Yesterday the Mercer Dial gauge arrived, So it is time to start figuring out how to set it up with the feed ruler Regards, Keith |
Keith Calleja | 04/03/2015 11:00:51 |
14 forum posts 20 photos | Restoration done. I have one question, Why would you need a reverse on a pillar drill?
Niloch | 04/03/2015 11:48:08 |
371 forum posts | Is Calleja a common surname in Malta? Or is Joseph the world famous tenor a member of your family? |
Keith Calleja | 04/03/2015 11:51:25 |
14 forum posts 20 photos | Haha !! not that common as other surnames. And no, as far as I know, he is not a member of my family |
roy entwistle | 04/03/2015 12:01:34 |
1716 forum posts | Keith Re reversing a pillar drill how else would you drill left handed holes ? Roy ps nice job |
Keith Calleja | 04/03/2015 12:23:49 |
14 forum posts 20 photos | Hi Roy, thanks for your comment. So drilling left handed holes is required when you want to drill a damaged bolt that you need to extract ? (preventing further tightening of the broken bolt) Is that correct ?? are there further operations that require a left handed hole ? Thanks alot |
David Jupp | 04/03/2015 12:42:07 |
978 forum posts 26 photos | The motor is presumably not designed solely for that drill - it is a standard item. Depending upon the device it is fitted to, either (or both) rotation direction might be required. The instructions for reversal are generic. On my drill which is now powered via a VFD, I occasionally do power tapping in Jog mode - the ability to reverse is useful to wind the tap back out. |
Ian P | 04/03/2015 14:18:26 |
![]() 2747 forum posts 123 photos | Posted by Keith Calleja on 04/03/2015 11:00:51:
Restoration done. I have one question, Why would you need a reverse on a pillar drill? In conjunction with a VFD (which gives you reversing for free) its indispensible for tapping purposes. I use my Fobco for power tapping from M2 up to M14. With a bit of extra switchery backing out can be at high speed which helps when tapping multiple holes. I have just made two camera 'cheeseplates' with a matrix of about 90 1/4" and 3/8" threaded holes in 10mm aluminium. Ian P |
roy entwistle | 04/03/2015 14:22:31 |
1716 forum posts | Keith Sorry it was a tongue in cheek remark But I have got a left handed drill bit Roy |
WorkshopPete | 04/03/2015 15:37:21 |
87 forum posts | Hi All Left hand drill bits were quite common at one time used on multi spindle drilling heads in this day of CNC are they still made? Peter |
ronan walsh | 04/03/2015 23:58:17 |
546 forum posts 32 photos | Is that a royal oilfield single cylinder engine on the floor keith ? I have a progress drill too, it needs work after damage caused by people changing the gears without stopping the motor first. I'll get around to it when the weather warms up a smidge. |
Keith Calleja | 05/03/2015 07:45:49 |
14 forum posts 20 photos | Yes Ronan that is a Royal Enfield Bullet 1993 Single 500cc engine fully reconditioned as part of my project. |
ronan walsh | 05/03/2015 17:03:12 |
546 forum posts 32 photos | Looks nice and light keith. I have a triple engine i am putting in a norton featherbed frame. It was going to be a cafe racer, but i think i am getting too old and full of aches and pains to be on a bike that has clip-on handlebars and rear set footrests.
Nick Grant | 05/03/2015 23:10:21 |
32 forum posts | I nearly bought a floor standing progress no.1 recently, they look like lovely machines. These old drills had some beautiful curves you just dont get today. |
