Dead kill switch
Ron.p | 03/12/2014 14:47:17 |
9 forum posts | Can you help me? The kill switch has gone faulty and I am unable to find a replacement Myford can't help I checked as many suppliers as I know off the switch spec marks are Type YBN 30-C V 41- 11753 230V 10 amp. Thanks Ron
Nick_G | 03/12/2014 16:13:05 |
![]() 1808 forum posts 744 photos | . What do you mean by a kill switch. An isolator or an emergency stop type arrangement.?
Nick |
Chris Trice | 03/12/2014 17:43:07 |
![]() 1376 forum posts 10 photos | Home And Workshop Machinery have Tripus switches in stock. Is this the sort of thing you were after? http://www.homeandworkshop.co.uk/myfotool.htm?36851 |
IanT | 03/12/2014 18:40:11 |
2147 forum posts 222 photos | This simple NVR switch from Axminster seems to work OK on my old Super Seven - just over £15.00 so won't break the bank either and easily replaceable if needed. Regards,
IanT |
CotswoldsPhil | 03/12/2014 20:28:57 |
![]() 196 forum posts 112 photos | I have the same Axminster NVR switch as IanT; it is installed as the main power switch for my Super 7. If you hit the big emergency stop button it locks off and requires a twist to reset. The internal wiring does, however, require 1/4inch spade type crimp connectors and you will need cable entry glands. I have no connection to Axminster apart from being a satisfied customer. I ordered the switch at 3:30pm and the postman delivered it at 10:00am - next day delivery, a bit more expensive but no need to wait in anymore than necessary. Regards CotswoldsPhil Wish I could create a post in one go... Edited By CotswoldsPhil on 03/12/2014 20:31:16 Edited By CotswoldsPhil on 03/12/2014 20:32:18 Edited By CotswoldsPhil on 03/12/2014 20:34:50 Edited By CotswoldsPhil on 03/12/2014 20:38:07 |
Ian S C | 04/12/2014 09:06:40 |
![]() 7468 forum posts 230 photos | Phil, I think you can erase the "Edited By" as you go, just leaving the last one. |
CotswoldsPhil | 04/12/2014 13:25:48 |
![]() 196 forum posts 112 photos | Ian, Thanks for that - I will next time. I was rushing to beat the edit timeout. CotswoldsPhil |
Ron.p | 05/12/2014 10:19:26 |
9 forum posts | Thanks chaps for the advice been a great help I had forgotten Axminster Ron |
