Myford super 7 headstock riser block
Chris Richards 321/11/2014 19:29:49
68 forum posts
13 photos
Hello,
I'm currently in a transition between using a Boxford and Myford. I want to sell on the Boxford to make room and funds for something bigger. There's a job I do about once a month that will not fit in the Myford so I was thinking about adding a riser block between the bed and headstock. Has anyone done this already? I guess the only issue is the gears down to the gearbox and would probably need to fit larger sizes within the same ratio to keep the correct feeds?
Thanks for any opinions,
Chris
daveb21/11/2014 20:46:05
631 forum posts
14 photos
It's fairly straightforward to fit riser blocks but not a quick job because you have to dismantle the headstock. If it's only an inch or two, risers could probably be left in position. If you replace the standard banjo (which does not allow adjustment of the gear spacing) you should be able to replace the idler gear with either a larger gear or pair of gears. This will not affect the final ratio but may affect the direction of rotation, not a problem because you can correct this with the tumbler reverse lever. Myfords made a banjo with adjustable gear centres for use with their metric conversion set, depending on how much height you need to get, this may do. Otherwise you will probably need to make an adaptor or special banjo.
daveb21/11/2014 20:51:39
631 forum posts
14 photos
The usual way of doing this on a Myford is to fit a taller headstock in front of the existing one, driven by either a belt or gears from the spindle. This avoids problems with the gears and is readily fitted and removed as required. I believe one or two versions were commercially produced.
Chris Richards 321/11/2014 22:56:45
68 forum posts
13 photos
Thanks Dave, I figured it must be doable, but was surprised I could find no mention of it anywhere. I had a look tonight I think other than the gears it's just the gear cover that wouldn't fit but that possibly could be cut and tig welded to stretch it to suit.
V8Eng21/11/2014 23:03:16
1826 forum posts
If you go to the Myford.co.uk website, then click on archives 11 in the left hand menu, there is a photo which may interest you.
it's reference 1394 about third one up from the bottom.
Sorry this is very convoluted, but I am having trouble posting links etc tonight.
Edited By V8Eng on 21/11/2014 23:23:11
Mike Poole21/11/2014 23:18:05
3676 forum posts
82 photos
Google myford high swing and go to Tony's lathes website.
Robbo21/11/2014 23:34:52
1504 forum posts
142 photos
There was a Myford headstock riser advertised on here and on Homeworkshop recently. Although for the ML10 it was said to be easily modified to fit 7 series.
I believe it is now sold, but the advertiser email was martin(at)heli-world.co.uk. Obviously swap the "at" for ampersand.
Maybe he would be willing to help - may still have some pics.
Engine Builder22/11/2014 11:36:02
267 forum posts
Here is my solution for the ML10
ian j25/11/2014 20:41:23
337 forum posts
371 photos
Chris.
I've just spotted this for sale by GandMtools:-**LINK**
it's the answer if you have plenty of money !!
Ian
