Kenneth Deighton | 17/11/2014 19:22:07 |
69 forum posts | This question may have been asked before but I have missed it, is it possible to convert a Metric Myford gear box to Imperial , if the answer is yes, how do I do it ? . Thanks . |
Brian Wood | 17/11/2014 19:31:39 |
2742 forum posts 39 photos | Hello Kenneth, I didn't know Myford ever made a Metric gearbox, if so I at least would love to know the details; I have a real interst in their gearboxes. Anticipating some really new information regards Brian |
daveb | 17/11/2014 21:09:34 |
631 forum posts 14 photos | I'm fairly sure the Myford 7 series gearboxes were all Imperial, they sold a metric conversion set which was a banjo with adjustable gear centres together with a few gears, this fitted between the tumbler gear and gearbox input in place of the fixed centres banjo. 280 and 254 lathes may have had a different arrangement. The selector arm detent positions in Norton type gearboxes are fixed, it would be quite difficult to alter the ratios, probably easier to make a new gearbox. |
Robbo | 17/11/2014 23:07:23 |
1504 forum posts 142 photos | Sorry Brian, no new information! Kenneth, there was only one sort of gearbox, changes from Imperial to Metric threads was done by use of external changewheels on the banjo arm. As Daveb says, there was a complete Metric conversion set available, which included a different banjo arm to hold the changewheels. This was used in conjunction with a conversion chart. So to "convert" the gearbox, you alter the changewheels feeding the drive to it. Edited By Robbo on 17/11/2014 23:09:09 |
Chris Trice | 18/11/2014 01:19:08 |
![]() 1376 forum posts 10 photos | I'd be interested in seeing a pdf or scan of anything related to the Myford gearbox like the manual or something similar. Does anyone know of a link? |
John Stevenson | 18/11/2014 01:52:48 |
![]() 5068 forum posts 3 photos | Here you go Chris.
Brian Wood | 18/11/2014 10:11:06 |
2742 forum posts 39 photos | Hello Kenneth and Chris If you are looking instead to convert Imperial to Metric pitch generating on a Myford gearbox equipped lathe, I can offer alternatives to buying the Myford metric conversion set which offers some advantages and retains the full use of the fine feed, a feature that is lost with the conversion banjo in place. If you would like more information send me a PM Regards Brian |
Chris Trice | 18/11/2014 23:30:23 |
![]() 1376 forum posts 10 photos | Thanks John. You're a star. |
Brian Wood | 02/12/2014 16:01:27 |
2742 forum posts 39 photos | Hello,Kenneth, You've sent me a PM and there is reply waiting in your Inbox for you to open it Regards Brian Edited By Brian Wood on 02/12/2014 16:02:02 |
