Five Phase Stepper Motor -- I need to find a Driver
Request for Advice _
Michael Gilligan18/10/2014 17:27:28
23121 forum posts
1360 photos
I have just purchased this superb mechanism from a fellow microscopist, who saved it from the Skip !!
For very good reasons, it has a Five Phase [ten wire] Stepper Motor; so I now need to find a suitable Driver for it.
Can anyone please suggest a modestly priced Driver Module, or a suitable DIY circuit ? ... Frankly, I am out of my depth with this one.
Edit: Here is the datasheet [in German ] ... it's the one in the Right-hand column on the first page.
Edit: and here is the explanation of why 5-Phase is Good.
Edited By Michael Gilligan on 18/10/2014 17:31:36
Edited By Michael Gilligan on 18/10/2014 17:33:05
jason udall18/10/2014 23:18:21
2032 forum posts
41 photos
Michael..
I have had to do it ( 3 phase) .
I had to do it with an audrino ...
The programme is simple enough.
You will need 5 1/2 H bridge drives..but it depends on voltage and current requirements. .but the ( iirc ) l293 provides 4 half bridge. .at 2A each coil..
Simple break out boards exist...
Biggest trick will be getting the adjacent nodes sorted.. ( they are generally used in the five sided version of "DELTA" rather than star..)...
Let me know if you need further. ..the programme is simple enough but you need to already doing the audrino thing...again if you need help...
jason udall18/10/2014 23:24:10
2032 forum posts
41 photos
So one audrino nano..two l293 boards...
About ?10...
What do you want from drive. ..?
Do you need micro stepping. . never tryed that but these units at 2000 steps per rev plus gears I suspect single steps are plenty small enough..
Michael Gilligan19/10/2014 06:40:02
23121 forum posts
1360 photos
Jason,
Many thanks for this.
Last night, I did eventually find a helpful article ... but my electronic construction skills are not in his league!
I would certainly welcome your guidance, and will send you a P.M. this afternoon. I have no experience with the Arduino, but I am very willing to learn, and I know there is plenty of tutorial material around.
In the first instance, I'm sure that full steps will suffice: I am led to believe that the unit came from a custom-built laser scanning microscope ... so my humble aspirations in the field of optical photomicrography should be an order of magnitude [or two] less demanding.
For info. Here is another photo of the unit:
John Haine19/10/2014 09:35:36
5563 forum posts
322 photos
The motor is almost certainly a standard frame size. Measure the spacing of the flange screw holes in decimal inches and multiply by 10. Probably get 14, 17, or 23. Small new steppers are quite cheap, eg from Zapp Automation. Replace motor with standard 2 phase type with 2 windings and use a standard controller.
jason udall19/10/2014 10:30:32
2032 forum posts
41 photos
As to replacing with two phase bipolar or even a unipolar motor...These would indeed be simpler to drive...for unipolar you could even use electro mechanical switch...
Driving the multiphase "steppers" isn't black magic...and these are ment to be lower mechanical noise than conventional hybrid steppers. ..a plus..
Bear in mind all phases are energised in one direction or other all the time and steps are" smaller..."..this means you are closer to the holding" situation " state..at all points of the cycle...
jason udall19/10/2014 10:31:57
2032 forum posts
41 photos
As to replacing with two phase ...DING DANG IT DOUBLE POST
Edited By jason udall on 19/10/2014 10:33:31
Michael Gilligan19/10/2014 11:02:21
23121 forum posts
1360 photos
Posted by John Haine on 19/10/2014 09:35:36:
John,
Thanks for the thought, but ...
Please see the second link in my opening post.
... this is a rather special piece of kit [I already have plenty of two phase motors]
Edited By Michael Gilligan on 19/10/2014 11:04:18
jason udall19/10/2014 11:43:48
2032 forum posts
41 photos
Michael... my three phase..uses a slightly different protocol than you link to the oriental motor co..
And as I said no micro stepping.
.will pm you my code and anotations for three phase
And modified ver ( untried) for five phase.
The driver. Modules are pretty ubiquitous I got mine from one of many on amozon
.ditto the nano (audrino) and breakout board..the latter just makes wiring simpler
jason udall19/10/2014 11:46:07
2032 forum posts
41 photos
Btw looks like either an encoder or a rapids motor hidden behind thestepper....
Michael Gilligan19/10/2014 11:48:27
23121 forum posts
1360 photos
Thanks again, Jason
I will send a P.M. with my eMail address, which may be more convenient.
Michael Gilligan19/10/2014 11:56:40
23121 forum posts
1360 photos
Posted by jason udall on 19/10/2014 11:46:07:
Its actually a clutch; and the two "gears" that are visible are flat belts [or maybe timing belts, used inside-out].
These two photos were provided by the seller ... I will take some detail shots next week.
Edit: Machine Components Corp. were very helpful in identifying the "slip clutch" for me ... as a special item, which is not in their regular catalog.
Edited By Michael Gilligan on 19/10/2014 12:00:34
Edited By Michael Gilligan on 19/10/2014 12:01:06
Mark C19/10/2014 12:02:43
707 forum posts
Michael, "custom-built laser scanning microscope" does that mean you found someone who built a LSCM (laser scanning confocal microscope) and then dismantled it? I ask as I have had some involvement with LSCM's and they tend not to be your average shed project!
Mark
Michael Gilligan19/10/2014 12:38:26
23121 forum posts
1360 photos
Posted by Mark C on 19/10/2014 12:02:43:
Mark
Mark,
Not quite ...
Possibly my error of interpretation ... it now appears that although the drive assembly is British, the microscope may have been more "production" than I thought.
... I will send you a P.M.
John McNamara21/10/2014 14:35:06
1377 forum posts
133 photos
Hi Michael
5 phase stepper I just did a bit of research....
Found these?
Simon036221/10/2014 14:52:29
279 forum posts
91 photos
Jason,
Very interested in your Arduino controller - but have you tried micro-stepping? Reason is that I would like to take the step size on my Emco 5PC CNC lathe to a smaller value than the current which is set by half stepping the 5 phase steppers.
The electronics and the Arduino side I can cope with but I have not seen any information on how to do micro-stepping. Vexta supply 5 step micro-stepping drivers but they have very little information to go with them I think - and extreme care appears to be necessary to select the correct version.
Simon
Michael Gilligan21/10/2014 15:17:35
23121 forum posts
1360 photos
Posted by John McNamara on 21/10/2014 14:35:06:
Hi Michael
Found these?
Many thanks, John
Those are astonishingly low prices compared with what I found.
... Must investigate further.
Another JohnS21/10/2014 17:21:58
842 forum posts
56 photos
Simon - off topic, but on the LinuxCNC mailing list, Sam Solik showed an Emco CNC lathe converted to LinuxCNC using the original electronics. Might be of interest?
Simon036221/10/2014 18:21:31
279 forum posts
91 photos
John,
PM'd you to ensure the topic is not further cluttered!
Simon
Michael Gilligan21/10/2014 18:30:36
23121 forum posts
1360 photos
Posted by Simon0362 on 21/10/2014 18:21:31:
John,
Simon
Simon,
Feel free to clutter ...
Jason has pointed me in the direction of Arduino and, despite John McNamara's amazing finds, I'm pretty sure that's the way I'm going. ... Anything broadly in the same area is good by me !!
It could all come in useful some day.
