James Stanton 2 | 10/10/2014 04:30:35 |
9 forum posts | Hello, |
Ady1 | 10/10/2014 09:15:31 |
![]() 6137 forum posts 893 photos | Is this what your after? It's in 3779
James Stanton 2 | 10/10/2014 09:17:01 |
9 forum posts | Hi, I am after the brake valve itself, not the brake cylinder. I have since heard that it can be found on the Springbok drawings. Edited By James Stanton 2 on 10/10/2014 09:17:33 |
Ady1 | 10/10/2014 09:35:34 |
![]() 6137 forum posts 893 photos | Is that it? From 3090 |
James Stanton 2 | 10/10/2014 09:40:10 |
9 forum posts | Brilliant. Thank you very much Ady! Edited By James Stanton 2 on 10/10/2014 09:41:39 |
Ady1 | 10/10/2014 09:43:17 |
![]() 6137 forum posts 893 photos | Which bit do you want? I'll just blow it up and put in in here Is it the bottom right drawing? |
James Stanton 2 | 10/10/2014 09:46:23 |
9 forum posts | Hi Ady Can you do just the Brake Valve please. cheers |
James Stanton 2 | 10/10/2014 09:47:43 |
9 forum posts | Posted by Ady1 on 10/10/2014 09:43:17:
Which bit do you want? I'll just blow it up and put in in here Is it the bottom right drawing? Yes it is. Thank you very much. |
Ady1 | 10/10/2014 09:56:39 |
From ME issue 3090 Edited By Ady1 on 10/10/2014 10:02:53 |
James Stanton 2 | 10/10/2014 10:03:33 |
9 forum posts | Fantastic. Thank you very much indeed! |
Boiler Bri | 09/08/2016 21:16:16 |
![]() 856 forum posts 212 photos |
My 5" brittania has a non functional manual brake system which I would like to change to steam operated. Will one of the above cylinders be strong enough to operate the brakes if I make one and fit it? Brian |
julian atkins | 09/08/2016 23:02:48 |
![]() 1285 forum posts 353 photos | Hi James, There is a lot to be said for altering the standard Martin Evans brake valve so that the spring is contained within the interior of the valve rather than on the external front. This allows a large diameter spring and reproduces a better scale external finish. I would also silver solder the valve disc to the spindle. 10BA for the fixing screws is quite OK, and you can easily reduce the overall size to much smaller. If the back is elongated/extended to incorporate an internal spring, you have enough width to add a steam feed to the back and so avoid one port slot on the valve disc. There really ought to be a release function on the valve notwithstanding Martin Evans' spring loaded valve on the steam brake cylinder which I set at 10 psi. Anyway that is how I have always done mine. Cheers, Julian Edited By julian atkins on 09/08/2016 23:04:39 Edited By julian atkins on 09/08/2016 23:05:48 |
