Fitting collet chuck to pillar drill
Rod Ashton | 23/09/2014 16:32:58 |
344 forum posts 12 photos | As I have a redundant pillar drill head (no base and table) and a headless milling table x, y and z. It seems prudent to mate them together to give give me an indexable drill. Naturally though, ones thoughts turn to adding a collet chuck?? The problem of course is the draw bar. This would have to be accommodated by boring the drill`s splined drive shaft of only about 3/4" dia. outside spline. Any advice available please. I am sure I am not the first or only person to wish to do this? Help appreciated.
Michael Gilligan | 23/09/2014 17:38:58 |
![]() 23121 forum posts 1360 photos | Rod, If I understand correctly what you have in mind ... I would probably not use a drawbar, but simply Loctite the collet adapter into/onto the drill shaft, using 638 [yes, I am a great advocate of the stuff If you ever change your mind and want to revert to the original fitting, the Loctite can be softened at about 200°C or "destroyed" at somewhat higher temperature. What's the present chuck fitting arrangement ? MichaelG. |
Rod Ashton | 23/09/2014 17:56:27 |
344 forum posts 12 photos | Michael The current fitting is MT2. |
Ian P | 23/09/2014 18:21:11 |
![]() 2747 forum posts 123 photos | The mill I own had an 8mm diameter drawbar for its MT2 socket (Its not MT2 now but that's a long story). Also supplied was an M8 to M10 adapter to fit in the end of whichever tool was being held. Your 19mm or so splined shaft should easily accommodate a 5/16" or M8 clearance hole and if you can get suitably long drills you could drill the hole in-situ just feeding with the quill.onto a drill held vertically. You might need more than one length of drill. Ian P |
Michael Gilligan | 23/09/2014 18:46:52 |
![]() 23121 forum posts 1360 photos | Posted by Rod Ashton on 23/09/2014 17:56:27:
Michael The current fitting is MT2. . That would do nicely; I stand by my suggestion. MichaelG. |
Ian P | 23/09/2014 21:18:26 |
![]() 2747 forum posts 123 photos | I have just checked the spindle that was in my Emco mill. It was drilled through for an 8mm drawbar but I actually opened it up to take a 10mm one. The upper part of the spindle has a keyway (no proper splines on this example of a precision Barvarian machine!) is 16mm OD and the keyway is 1.5mm deep giving originally a 2.5mm wall thickness. At 3/4" your shaft will comfortably stand a 10mm drawbar which gives you the flexibility of changing collets or tooling with the bonus of saving the Loctite for something that really need it! Ian P
Rod Ashton | 24/09/2014 07:23:57 |
344 forum posts 12 photos | Gentlemen - Many thanks for the support. Will dismantle the head for a draw bar. Try to let you know how it proceeds. Rod |
