The aim of this thread is to detail the build and give help where needed
Phil Grant | 25/02/2020 16:40:56 |
107 forum posts 21 photos | Dias, See if this helps |
dcosta | 25/02/2020 20:21:23 |
496 forum posts 207 photos | Hi Phil and others, Thank you for your help. Now, the stepper motor has been connected for approximately three hours and has heated up to, perhaps, 45º (the hand supports the temperature well) and, as far as I can see, it works as well as before. best regards |
Phil Grant | 25/02/2020 22:53:30 |
107 forum posts 21 photos | Dias, That's great news, I suspected it would be the wiring of the coils. Phil |
dcosta | 26/02/2020 23:41:49 |
496 forum posts 207 photos | Hello John, Thank you for sharing information about your project. Could you do me a favor and tell me where that line should be inserted? Thanks in advance |
Johnboy25 | 27/02/2020 09:45:38 |
![]() 260 forum posts 3 photos | Hi Dias If you’re looking for the fast scroll mod/hack it’s here:- It took me a while to get the code inserted correctly - I had help from a friend who’s an experienced C++ programmer as my C programming skill are a lot be be desired! 😳 I will look at the code file to find where it inserted for you. I really think this is a useful mod. John Edited By Johnboy25 on 27/02/2020 09:48:10 |
SillyOldDuffer | 27/02/2020 11:14:40 |
10668 forum posts 2415 photos | Posted by dcosta on 26/02/2020 23:41:49:
Hello John, "add this to UserInterface.h Could you do me a favor and tell me where that line should be inserted? Thanks in advance Hi Dias, Though not into this particular project I am an ex C/C++ programmer. Looking at userinterface.h I found a short file, starting with a comment section containing licence blurb. The action starts at line 27 : #ifndef __USERINTERFACE_H #include "ControlPanel.h" typedef struct MESSAGE class UserInterface The new line can be inserted almost anywhere apart from inside any curly brackets! I'd put it at the top just before the typedef, roughly line 33 thus #ifndef __USERINTERFACE_H #include "ControlPanel.h" int ButtonStateMachine (bool incrementButtonPressed, bool decrementButtonPressed); typedef struct MESSAGE ... H files typically contain definitions shared by a number of source files. In this case int ButtonStateMachine (bool incrementButtonPressed, bool decrementButtonPressed); means: 'A function called ButtonStateMachine takes two boolean arguments and returns an integer result.' Boring explanation, if anyone cares: The function is defined fully somewhere else in a code tree consisting of several source files, and the statement, it's signature, is a promise to the compiler that the full definition of the function will be made available later. So a project consisting of three source files, say A, B and D, will compile A even if it calls a function in D that doesn't exist yet. When the compiler hits an unresolved but explained reference, it leaves a gap in the code ready for the link phase, which is where A+B+C get glued together with any operating system and library calls. The linker, which can see everything, fills any gaps left by the compiler and completes the working whole. It's only an error when the linker can't fill the gaps. Clear as mud? It's a mechanism allowing programmers to separate code into manageable blocks rather than one giant source file, and then assemble the bits into the whole later. It also allows code to be shared between different projects. Dave
Edited By SillyOldDuffer on 27/02/2020 11:19:57 |
Johnboy25 | 27/02/2020 11:32:36 |
![]() 260 forum posts 3 photos | Dave... ‘Thanks for that - I’m just starching the surface with C++ so this is helpful to me. John |
dcosta | 27/02/2020 20:19:22 |
496 forum posts 207 photos | Hi Dave, |
Phil Grant | 22/03/2020 08:14:45 |
107 forum posts 21 photos | Following a request on the Clough42 GIT hub I put my bracket designs I made for my small WARCO (Chinese) lathe and ELS on thingiverse Here |
Jimmeh | 26/03/2020 18:16:38 |
![]() 27 forum posts 12 photos | It's been very slow progress for me on this project, but a recent change in my working arrangements has saved me 3+ hours of driving to/from work each day. I now have the whole system working on the bench and am in the progress of sorting the hardware on the lathe. I tried my hand at using a new (to me) gravograph and the result is actually alright (don't look to closely!). Last night I fitted the drive system, which is a nema24 hybrid stepper with HDT3 belts and pulleys. I'm hoping to drive the encoder with an HDT5 belt straight onto the headstock gear. I should be able to try the whole system fairly soon. Huge thank you to Phil Grant for the circuit board and components! Edited By Jimmeh on 26/03/2020 18:18:15 |
Roy Vaughn | 14/04/2020 13:17:52 |
70 forum posts 4 photos | Nearing the finishing post now and starting to think about detailed functionality. It would be useful to see a visual indication of a stepper driver alarm on the control panel. James has included support for the input from the interface but I can't see any functionality attached to it in the code. Does anyone know any different? Stay safe, Roy |
Martin Connelly | 14/04/2020 13:30:17 |
![]() 2549 forum posts 235 photos | If you have closed loop hybrid servo-stepper motors and drivers from Leadshine (possibly others as well) they have an error signal that is triggered by the position feedback differing from the demanded position by a set amount (that can be changed by the used if required). This signal would be fed back to the controller to either trigger a light, audible alarm or other action. If you don't have feedback encoders on your system then this warning may not be available to you. Martin C |
Roy Vaughn | 14/04/2020 17:10:08 |
70 forum posts 4 photos | Thanks Martin, I'm familiar with the hardware requirement, it's what I have. My question concerns the software handing (or not) of an alarm signal. Roy
Martin Connelly | 14/04/2020 17:43:44 |
![]() 2549 forum posts 235 photos | The problem of acting on the alarm signal is what to do? Stopping the lathe but letting the steppers run will cause problems. Stopping the steppers but letting the lathe run will cause problems. Stopping them both will cause problems unless they all stop instantly (or at exactly the same rate) which is unlikely so also a problem. If you have a spindle encoder that keeps the steppers closely aligned to the correct position if the spindle speed runs down then you would probably be able to stop the spindle knowing that the steppers will stop at the same rate as the spindle. The best option for the majority of users may be to trigger an alarm light so that the lathe can run to a point where the operator can take some action that will not cause problems. If you have some means of homing the movements of the lathe and use it at the start of a session you can easily reset everything by re-homing if there is an error signal that Is acted on by stopping safely. Martin C |
Brian Oldford | 14/04/2020 18:44:13 |
![]() 686 forum posts 18 photos | I've followed this thread from its inception. I plan to drive my Super 7's lead-screw via 90 degree skew gears thus containing the stepper motor completely within the change-gear compartment. To design and make the mounting requires the removal of the banjo but I became side-tracked with other more pressing tasks. Now I'm back on track I'll try and put up some photos of my progress, Edited By Brian Oldford on 14/04/2020 18:48:28 |
Roy Vaughn | 14/04/2020 19:11:15 |
70 forum posts 4 photos | The odd missed step isn't crucial except when screwcutting, but it shouldn't happen, so the root cause (overspeed or overload) needs to be fixed by the operator. A lot of missed steps leading to a crash is another matter. If it's due to operator error that's exactly equivalent to the geared lead screw situation with the same consequences and solution. If it's due to electronics failure I imagine that the banjo will be back on the lathe in short order. The lead screw will track the spindle even after the emergency stop button has been hit, but what if there's a power cut? Put the ELS on a UPS? It all gets a bit complicated. So I agree the software best solution is to signal the alarm on the display and leave it at that. Roy
Since it should never happen the only corrective action is to fix the source of the problem, e.g. overspeed or overload.
I envisage alarms arising from the odd missed step due to over-speed or overload, hard to notice otherwise and only important when screwcutting . If something major happens, e.g., the lead screw stops while the spindle carries on, leading to a crash, I imaging the whole lot being decommissioned and sold for parts on Ebay! |
Jimmeh | 14/04/2020 20:14:23 |
![]() 27 forum posts 12 photos | I think its just a placeholder for code to be added at a later date if so desired. When testing my system (CL57T driver + stepper with encoder) I physically forced the servo out of position and it just cuts the power to the servo. Cycling the power restores everything back to normal. Likewise if you spin the rotary encoder really fast one way and then the other the system errors and power is cut. The consequences are obviously bad, but I think I'd rather the stepper powers down if there's a problem. On a separate note I would like to try and see if I can get the whole system to power on/off with the lathe itself. I am conscious that if there is an electronic fart the carriage could move unexpectedly and I would like the E-stop to help me! I'm almost done with my installation. I just have to adjust the lathe side cover so it fits back on and mount the control panel somewhere accessible. Its really quiet without the change wheels rattling away, and I actually use it for fine feed now. Before I never bothered as it was too much of a pain in the ass swapping everything around. |
Roy Vaughn | 14/04/2020 21:07:41 |
70 forum posts 4 photos | Jimmeh I have the same setup. I haven't tried those tests. Maybe the behaviour of the stepper controller could be changed so let the software take control by doing something over the data port. Probably in the all too difficult category. Apologies for the junk in the end of my last email, I can't get rid of it now. |
Johnboy25 | 18/04/2020 09:17:37 |
![]() 260 forum posts 3 photos | Hi everyone. I’ve been following this build on James Clough’s YouTube channel (Clough42) this is an on going project and there have been updates which I have included & modified in software. There are ‘third parties’ actively adding options they consider to be useful. I have seem mods to include more safety features. This is not a ‘finished’ project and there are safe guard in place. Further info can be seen on github forum. Addition features are planned but James is currently contributing to the Corvid19 response producing PPE for hospital staff which he’s making on his 3D printers. I have been building this system along with a friend who has a Southbend 4.1/2”. He wants to screw cut metric threads. He’s managed to get his hardware up and running and it has transformed the versatility of the lathe. I’ve been repairing/renovating the gearbox prior to fitting on my Boxford 4.1/2” metric lathe between making parts for the Loco project. I’m using this lockdown period to maximise workshop activities and trying to keep me out of harms way. Stay well & keep away from this virulent viruse |
Johnboy25 | 18/04/2020 09:17:39 |
![]() 260 forum posts 3 photos | Jim This is a mod that has been produced to use the on/off button To disable the servo Drive. I also intend to incorporate an E-stop activated by the lathes control system. Edited By Johnboy25 on 18/04/2020 09:28:44 |
