Tony Jeffree | 08/09/2023 23:28:48 |
![]() 569 forum posts 20 photos | Posted by david bennett 8 on 08/09/2023 20:39:40:
Posted by Tony Jeffree on 08/09/2023 18:38:03:
Posted by duncan webster on 08/09/2023 13:51:38:
Posted by Tony Jeffree on 08/09/2023 12:34:16:
..........or what radius of generating circle for the cycloid is required in order for it to work.
Same as the pendulum cycloid. Plausible answer, but where's the proof? As I tried to show in my post yesterday,at 16:28 the generating circle doesn't matter. A cycloid is a cycloid. Pick any convenient size. dave8 I'm sorry, that's absurd. What if I choose a convenient size of 0.000001mm as the radius of the generating circle? |
david bennett 8 | 09/09/2023 01:19:55 |
245 forum posts 19 photos | Then it wouldn't be a convenient size - would it? dave8 |
david bennett 8 | 09/09/2023 01:56:08 |
245 forum posts 19 photos | On second thoughts, if you find that is a convenient size, please go ahead. Be sure to do a write-up so we can follow your procedures, especially the measuring. It's sure to attract a lot of attention. You'd like that, wouldn't you? dave8 |
david bennett 8 | 09/09/2023 04:45:04 |
245 forum posts 19 photos | Posted by Tony Jeffree on 07/09/2023 14:04:58:
Of course, a moment's thought about the wheels on a car would have brought you to the same conclusion. A point on the tread follows a near-enough cycloidal path (give or take the flexibility of the tyre), but you'd better hope that the wheel axle doesn't follow a cycloid, or it is going to be a rather bumpy ride! Edited By Tony Jeffree on 07/09/2023 14:05:35 If a point on your tread follows a near-enough cycloidal path, you probably need new bearings. dave8 Edited By david bennett 8 on 09/09/2023 04:45:55 Edited By david bennett 8 on 09/09/2023 04:58:52 |
Michael Gilligan | 09/09/2023 06:10:08 |
![]() 23121 forum posts 1360 photos | This discussion seems to have taken an unpleasant change in style … I now regret that I unintentionally revived it at the end of page 4 MichaelG. |
david bennett 8 | 09/09/2023 11:06:34 |
245 forum posts 19 photos | Michael, guilty. Me, not you. Its because of perceived rissole-like responses from one member. I would be happy to draw a line here. dave8 |
Tony Jeffree | 09/09/2023 11:35:51 |
![]() 569 forum posts 20 photos | Michael My apologies if I have offended anyone - that was not my intent. Regards, Tony |
david bennett 8 | 09/09/2023 11:52:12 |
245 forum posts 19 photos | o.k. dave8 |
david bennett 8 | 09/09/2023 12:23:11 |
245 forum posts 19 photos | Michael |
Tony Jeffree | 09/09/2023 12:43:44 |
![]() 569 forum posts 20 photos | Posted by duncan webster on 08/09/2023 19:41:06:
OK, try this, which is so far above my head it might as well be in orbit Duncan - Thanks - that is very useful indeed - the evolute of a cycloid is a replica of that cycloid shifted by 180 degrees, which is what is needed for the cheeks to work. It also indicates that the generating circle for the cheeks must have the same radius as the desired cycloid's generating circle - as per previus discussions this must be half of the effective length of the pendulum. Pretty clear then that this was Huygens' intent. Regards, Tony |
david bennett 8 | 09/09/2023 14:26:23 |
245 forum posts 19 photos | I think I now see where the confusion comes from. Much of this discussion has become about Huygens cycloidal cheeks and how they are constructed. The 1/2 pendulum length roller is needed for that. The method I proposed is based on the rolling wheel principal to produce a cycloidal path. That is a completely different approach to Huygens. The question now is - does the diameter of the roller matter in this context? dave8 |
duncan webster | 09/09/2023 14:30:58 |
5307 forum posts 83 photos | There is only one cycloid which will give isochronous motion. This has been stated time and time again. Michael gave up on 05/09, now I give up. |
Tony Jeffree | 09/09/2023 14:51:58 |
![]() 569 forum posts 20 photos | Posted by david bennett 8 on 09/09/2023 14:26:23:
I think I now see where the confusion comes from. Much of this discussion has become about Huygens cycloidal cheeks and how they are constructed. The 1/2 pendulum length roller is needed for that. The method I proposed is based on the rolling wheel principal to produce a cycloidal path. That is a completely different approach to Huygens. The question now is - does the diameter of the roller matter in this context? dave8 I believe I answered that with the diagram I posted on 07/09/2023 13:41:13 and subsequent posts. The diameter of the roller has to be equal to the effective length of the pendulum, otherwise the bob *does not* follow a cycloid. |
david bennett 8 | 09/09/2023 23:14:38 |
245 forum posts 19 photos | Thanks everybody for your help in this. I've finally got my head around the change of curve from extending the rod, and even the apparent paradox of a point in a circle being a cycloid one minute and not the next. Sorry for testing your patience so hard. dave8 |
david bennett 8 | 11/09/2023 23:00:59 |
245 forum posts 19 photos | If this project wasn't already dead, here's another nail in the coffin. In preparing a cirular section to match the required circle ( 125mm radius now), placement of the magnet came up. The only place for the magnetic forces to even out would be in the middle of the bob! Not very practical. dave8 |
John Haine | 12/09/2023 08:32:22 |
5563 forum posts 322 photos | I'm not sure I see that Dave. Why wouldn't the arrangement I sketched work? |
david bennett 8 | 12/09/2023 16:12:40 |
245 forum posts 19 photos | Posted by John Haine on 12/09/2023 08:32:22:
I'm not sure I see that Dave. Why wouldn't the arrangement I sketched work? John, I think you mean the sketch in the "general" forum? (If this works, it leads to the intrigueing idea that local magnetism can replace gravity in a clock) Just from playing about with magnets and rollers they accelerate to seek the closest contact at the strongest pole point. This ruins any hope of a high Q and swamps the effect of gravity. I was trying to minimise this by putting the magnet in the centre of the rollers.It just felt wrong. |
John Haine | 12/09/2023 16:38:07 |
5563 forum posts 322 photos | Indeed, that's the one. Maybe one can shape the corners of the polepiece to prevent this? If I may, just to close this topic off, I did mention earlier that it is known that the cycloid does not make a compound pendulum isochronous (and in fact there is no curve that can do that). My friend Andrew Millington (who is a real mathematician) has looked at this and come up with an approximation for the circular deviation of a compound pendulum moving in a cycloid, and also checked this against Woodward's analysis. This would apply to David's magnetically suspended pendulum as well as a pendulum with cycloidal cheeks. There are two factors to consider. One is the distance from the suspension point to the CoG of the whole pendulum, which is "r". The other is the "radius of gyration" which is a measure of the pendulum's "compoundness", which is "k".If the amplitude of swing is "a" radians, then the fractional change in clock rate is: k^2.a^2 / [16(r^2 + k^2)] If the pendulum is "simple" then k = 0, so the rate change is zero. Suppose we want a 1metre pendulum. The bob weight can't be too large because it has to be supported by the magnet. So let's suppose it was 1kg. The "shoe" which has the circular face and contains the magnet needs steel polepieces and the magnet has to be strong and probably quite heavy. For the sake of argument suppose the whole shoe weighs 100g. Assume the rod is say carbon fibre and effectively weightless. Given the length of the rod and the weights you can calculate the position of the CoG and the value of k. Putting them in the formula and calculating gives a fractional change in rate of: (+a^2/16)/13 For a normal circular pendulum the standard expression for CD is: -a^2/16. So while the CD is significantly less than for a conventional pendulum it isn't zero and can't be made zero. I think your suggestion and the experiments you did were very ingenious, but the fact that one does lose the "ideal" anisochnonicity (is that a word?) combined with the practical difficulties you've highlighted make this approach of theoretical interest only.
John Haine | 13/09/2023 10:52:57 |
5563 forum posts 322 photos | Andrew pointed out a small error, my formula (+a^2/16)/13 = a^2/208 should have been... (+a^2/16)/11 = a^2/176 Clearly though this is for specific physical parameters and could be larger or smaller depending. Edited By John Haine on 13/09/2023 10:53:43 |
david bennett 8 | 15/09/2023 16:28:49 |
245 forum posts 19 photos | John, could that error be "tuned out" with a rating nut? dave8 |
