Tony Jeffree | 04/04/2020 17:21:33 |
![]() 569 forum posts 20 photos | Posted by Bandersnatch on 04/04/2020 17:12:07:
BTW Tony, your dropbox links don't work for me either. It says the folder doesn't exist and then drops me back to my own dropbox folder. Thanks - will take a look. |
Tony Jeffree | 04/04/2020 17:24:57 |
![]() 569 forum posts 20 photos | Try this: https://www.dropbox.com/s/l93f2cwpkpqyxo0/Visor_frame_EUROPE_80mm_4hole_v1.stl?dl=0 https://www.dropbox.com/s/s3n2dr50bf9mrog/Visor_frame_EUROPE_ISO838_v3.stl?dl=0 |
Enough! | 04/04/2020 18:35:52 |
1719 forum posts 1 photos | Thank you, Tony. That worked a treat! |
Tony Jeffree | 04/04/2020 18:57:10 |
![]() 569 forum posts 20 photos | |
Neil Wyatt | 04/04/2020 19:29:43 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Barrie Lever on 04/04/2020 10:29:45:
Neil What basic settings are you using on that Prusa part? Infills, feed speeds etc. B. 10% infill, 120mm/s infill speed, 80mm/s walls, 0.3mm layers, 1.2mm wall thickness, 1mm top/bottom thickness. No support or adhesion. Other settings are probably a bit machine/filament specific, but I'm using 200C filament and 60C build plate with PVA coating on borosilicate glass, buildplate fans on. Neil
