latest drawings
JasonB | 03/08/2010 07:25:56 |
![]() 25215 forum posts 3105 photos 1 articles | Because the 3 1/2" has no the flange is 5/32". on the 3 1/2" drawings
3 3/16" back to back plus (2x 5/32") = 3 1/2"
Jason |
Dave Harris | 03/08/2010 09:30:56 |
28 forum posts | JasonB,
Thank you, having re - read all the forgoing, and re - studied the diagram regarding the back to back/wheel profiles in the article re track and wheel standards in the ME handbook, and your comment above, I now understand the dimensions. I had a fixation over the back to back dimension and was not taking into account the flange dimension! My apologies to all for being so 'thick'!
Dave |
David Clark 1 | 03/08/2010 11:37:44 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
I only edit the articles, I don't rewrite them.
Also, some methods used by authors I would not use if building it myself. That does not mean they are the incorrect method. If Ray decides to change recognised standards, that is his decision.
If I start changing anything then I would probably introduce major errors.
All I can do with any article is edit it for grammar if needed and ensure all is in the correct order.
regards David |
Dusty | 27/08/2010 14:41:21 |
498 forum posts 9 photos | Having just read the latest instalment of this series I have noticed that the drawing for the main spring shows the thickness as 0.78. Ray says that it is masive and would be rigid in the model, that is an understatement. By my calculation the thickness of this spring should be 0.054. How did I arrive at that, The spring on the original is 3/8" or .375, if you use a divisor of 6.85 this will give you 0.054. Why 6.85, this is arrived at by dividing 24" (the gauge of the original loco) by 3 1/2" (the gauge of the model). By the way the remaining springs in the stack are 5/16" thick or 0.045 in model terms. |
JasonB | 27/08/2010 15:11:34 |
![]() 25215 forum posts 3105 photos 1 articles | Just looking at the proportions of the rest of that part its obvious the thickness should be 0.078", look like someone left a 0 out.
Jason |
Dusty | 27/08/2010 16:35:17 |
498 forum posts 9 photos | Jason
I do not agree, my sizes have come from the works drawing which shows 3/8" thick by 3" wide for this spring. This makes the model spring 0.054 thick by 7/16 wide. The drawing in M.E. is 7/16 wide but .78 thick. This would then make the full size spring 17/32" thick if the dimension should be 0.078 on the model. I doubt that they would have made the spring such a bastard size, especially with a stack of leaves underneath it.
If you look at album 5 of David Clarkes photo's a very good view of the springs is available the top leaf is not massivly thicker than the lower leaves, this I think supports my argument. Edited By Dusty on 27/08/2010 16:41:23 |
JasonB | 27/08/2010 18:38:24 |
![]() 25215 forum posts 3105 photos 1 articles | As the spring on the model is infact a "beam" that supports a coil spring (thats how I read it) then I assume the maker has made this one stronger as all the other leaves are just dummies. If it were scale size without the other 15 leaves to add support it would likely flex and risk going curve up
If you are going to make working springs then yes the thinner size would be better. But as they are dummies there is likely to be a reason teh top load bearing one is thicker
Jason |
Dusty | 27/08/2010 19:41:07 |
498 forum posts 9 photos | Hi Jason
Yes that would be sensible. I must admit that I had not thought along those lines. Bit of tunnel vision on my part I fear. |
peter ravenscroft | 12/01/2011 15:18:56 |
100 forum posts 3 photos | hello
has anybody fitted the cylinder mounting plates yet as i am having problems i have marked everything out ok and have checked it all but the plates seem to foul the tank mounting brackets
any idea's
tia
regards
peter
Dusty | 13/01/2011 09:26:31 |
498 forum posts 9 photos | Peter
As I see it, the tank mounting brackets are on the inside of the frames and the cylinder mounting plates on the outside. How do they foul? I have not started my build yet but have a full set of drawings plus the works drawings available. |
Donald Mitchell | 13/01/2011 10:11:48 |
![]() 90 forum posts 3 photos | Peter & Dusty, I have checked with Raymond on the phone this morning and he confirms that both the tank brackets, and obviously the cylinder mounting plates are on the outside of the frames. He acknowledges that they are very close, but if accurately made to the published dimensions it will all fit. Good luck, keep at it. Donald Mitchell ![]() |
peter ravenscroft | 13/01/2011 14:36:10 |
100 forum posts 3 photos | many thanks donald i'll have another go tomorrow and i'll let you know how i get on
hi dusty i'm building it with the model engineer issues to see if there are any mistakes had a couple of problems but nothing to drastic
regards
peter |
Dusty | 13/01/2011 17:41:18 |
I have started writing my lines 'I must read drawings properly before pontificating' I think 50 should be enough. In fact I should have looked at the drawings, having done so I can see that the brackets are indeed on the outside. I opted to purchase a set of drawings. Having built a loco from drawings published in a magazine I know that errors can occur in the magazine that are not in the drawings. It is almost impossible to check your own work when transposing from one drawing to another. I will start building later this year when all of you who have started, should have ironed out any problems. |
peter ravenscroft | 13/01/2011 18:22:59 |
100 forum posts 3 photos | hi dusty
i'm gulity of doing that see one of my posts i read the magazine on the way home and did'nt read the mesurment corectly there are a number of errors in the model engineer and some measurements missing but on the whole it builds as he said in his series
i did start a 5" version many years a go and still have my drawings so i have some knowlage of the loco
regards
peter |
peter ravenscroft | 11/02/2011 16:40:19 |
100 forum posts 3 photos | has any one read the latest instalment of the darjeeling loco in the current issue of model engineer (4379) if so can you please tell me the radius of the expansion link as i think the dimentions are missing or is it me misreading the drawing
regards
peter |
JasonB | 11/02/2011 17:01:06 |
![]() 25215 forum posts 3105 photos 1 articles | Does seem to be missing.
J |
Nicholas Farr | 11/02/2011 17:17:47 |
![]() 3988 forum posts 1799 photos | Hi, you might even think the latest issue is 4397, but no I can't see it.
Regards Nick. |
Donald Mitchell | 11/02/2011 17:45:33 |
![]() 90 forum posts 3 photos | Hi Engineers, I have just checked with Raymond and the radius of the expansion link slot is 5 11/16 Raymond has checked his master drawings (as supplied to ME) and the dimension is correctly shown on them. Donald Mitchell ![]() |
peter ravenscroft | 11/02/2011 18:05:14 |
100 forum posts 3 photos | thanks donald
id worked it out to be 4-3/8 by blowing the drawing up to the correct size so it's nice to know the right dimension thge issue is 4397 by the way typing error
regards
peter |
Keith Rogers | 05/03/2014 08:37:51 |
1 forum posts | Am I the only person building the Darjeeling loco. So far I have made the boiler & had it tested, got the chassis running on air & am well on with the cab platework. At the moment I am waiting for some 1/4" 'D' section to arrive also material to clad the boiler. I have not had too much trouble building building the loco but a few assembly drawings would have helped, at times its like a jigsaw puzzle wondering what goes where. Keith Rogers. Warrington |
