Rod Renshaw | 09/07/2020 11:45:45 |
438 forum posts 2 photos | I like Dave's idea for watering the manifold, but also note Martin's concerns about cracking the manifold due to the thermal shock. Perhaps the safest way would be to begin with the engine cold and water that, and then start up. Rod |
Dave Halford | 09/07/2020 12:34:28 |
2536 forum posts 24 photos | Posted by Rod Renshaw on 09/07/2020 11:45:45:
I like Dave's idea for watering the manifold, but also note Martin's concerns about cracking the manifold due to the thermal shock. Perhaps the safest way would be to begin with the engine cold and water that, and then start up. Rod It was something of a quick post. It's best done with bare cast iron when cold, the water soaks into the iron a little so it's very obvious which one is cooler, it takes about 5 sec longer to dry. Tubular manifolds don't matter and they dry so fast it takes several wettings to spot the offender. |
peak4 | 09/07/2020 13:02:19 |
![]() 2207 forum posts 210 photos | Posted by Dave Halford on 09/07/2020 12:34:28:
It was something of a quick post. It's best done with bare cast iron when cold, the water soaks into the iron a little so it's very obvious which one is cooler, it takes about 5 sec longer to dry. Tubular manifolds don't matter and they dry so fast it takes several wettings to spot the offender. Or use a non-contact infra red thermometer. Bill
pgk pgk | 09/07/2020 13:32:09 |
2661 forum posts 294 photos | +1 for hammering a tool through a stubborn filter if accessible and whoever fitted it was having a temper tantrum. pgk |
AStroud | 09/07/2020 13:41:30 |
44 forum posts 12 photos | Here's what I did to remove a stubborn filter. Put 2 jubilee clips over the filter body with their worm drives aligned and tightened up. Found a piece of pipe with id the same as the jubilee clip bands' od. In one end of the pipe cross drilled for a tommy bar. On the other end notched out a circular segment of length such that the clips' worm drives would fit into it. Put the pipe onto the filter with the notch around the worm drives and then used a tommy bar to unscrew the filter. |
Dave Halford | 09/07/2020 14:10:22 |
2536 forum posts 24 photos | Posted by peak4 on 09/07/2020 13:02:19:
True, but everyone can get a bottle of water, it hasn't always been the 21st century and you might want to use it today and all it might need is a new plug lead |
