not done it yet | 14/12/2019 18:02:21 |
7517 forum posts 20 photos | Automatic cut off means you can leave it while doing other things. I admit to being a bit impatient, like watching paint dry.
Stuart Smith 5 | 14/12/2019 18:09:42 |
349 forum posts 61 photos | I have just bought one of these as well. Cuts ok and the vice holds well on mine. The on/off trigger does not lock, so that is why the mod on the YouTube video to keep it pressed. Obviously needs an external switch ion line if doing this as per videos. The blade seems ok with none of the problems some others have had. The only problem is the vice is not suitable for holding small parts. |
not done it yet | 14/12/2019 21:18:10 |
7517 forum posts 20 photos | The on/off trigger does not lock, so that is why the mod on the YouTube video to keep it pressed. Thanks Stuart. Real up to date information. Either they fit any switch that is available or they are all non-latching switches. Don’t know which, now, so the comment of being OTT for an auto cut-out seems to stand if they have made the saw like that for a good reason (like there is a limited run-factor on the motor). |
Stuart Smith 5 | 14/12/2019 22:03:58 |
349 forum posts 61 photos | It is advertised as a portable bandsaw and doesn't need to be used on a stand. In this respect it is similar to a portable drill. I have tried it like this holding a small piece of steel in my normal bench vice. The only problem was that it was difficult to control when starting the cut. After that, it was similar to using a (heavy) hacksaw. I think if I had made a start with a normal hacksaw I wouldn't have had a problem.
Henry Brown | 14/12/2019 22:25:49 |
![]() 618 forum posts 122 photos | The non-locking power switch is probably because there isn't any damper to control cut which all comes down to cost. The times I have used mine I as very conscious that I was feeling the blade through the material rather than letting the weight of the saw just cut away. Incidentally the vice on mine is fine, although I must admit I was a bit concerned about it holding the bar securely at first. I recently made some T nuts and cut them off one at a time after machining but didn't have enough bar stock to cut the last one so I used an old pair of parallels either side of the machined bar with a previously cut T nut to balance the clamping and it did the last cut fine. Other than deburring I've left the cut as it is quite acceptable for purpose. |
