Electric motor question for those with electrical experience.
Russell Eberhardt | 13/07/2014 14:26:10 |
![]() 2785 forum posts 87 photos | Posted by tractionengine42 on 13/07/2014 09:46:35: Stuart's information concerning the base frequency set to 29Hz is very attractive. Something to be aware of is that, although this method maintains the same torque, because the speed is reduced by 2/3 so is the power. So your 1 hp motor becomes a 2/3 hp motor. That may or may not worry you depending on what you intend to do with the lathe. Russell. |
GoCreate | 13/07/2014 16:52:39 |
![]() 387 forum posts 119 photos | Hi Everyone, I have decided to change the motor on the mill to the one given to me by a friend complete with a VFD. Then their shouldn't be any power issues. I have a Drummond model B lathe that I would like to get set up (some day). Now that I know I can run the old mill motor via a VFD with a base frequency set at 29Hz without modification, I will keep it for use on this lathe. Even running at reduces revs and possible lower power the old mill motor will be more than an acceptable match for the Drummond lathe. I think this has turned out very well for my purpose. Thanks again everyone that posted. Nigel |
