Steady Rest principles.
Clive Foster31/01/2023 09:35:02
3630 forum posts
128 photos
I like the simple approach that ChrisLH has used.
Model engineers and home workshop types tend to overlook the stiffness of judiciously bent sheet materials. I guess hefty lumps of solid material feel reassuringly much stronger and stiffer even though the extra weight adds pretty much nothing to the useful strength. It does kill vibration tho'.
Probably doesn't help that most of us don't have kit to easily and accurately bend adequately thick material say 10 gauge / 3 or 4 mm steel.
I'm minded to try something similar for my P&W B as I have no steadies with it. That is a larger machine, 12" swing in American terms meaning almost 14" in reality so a bit of beefing up seems indicated. One piece construction with flange all round having an integrated foot with all corners welded should be usefully stronger. Taking the top corners out so the upper part is sort of half a hexagon ought to help too. As will cutting some slots across the flange bends to weld in triangular fillets. Welding will need care to avoid distortion. The simple bar fingers bolted through slots make things useful stiffer too. Two sets of fingers, one short and one long, would be advisable for the bigger machine so there is plenty of fixing area.
I think delrin for the pads unless I decide to use up the small ball bearings in the useful bits box.
vic newey31/01/2023 09:45:38
347 forum posts
173 photos
Here is an unusual type that has different sized holes and can be rotated and locked to suitpittler steady.jpg
Bruce Voelkerding31/01/2023 12:16:14
77 forum posts
7 photos
Vic - is that really a Steady Rest ? The Holes appear to be conical all the way thru. Is it actually a Device to steady the End of long Stock so a Center Hole can be drilled in it ?
vic newey31/01/2023 12:27:27
347 forum posts
173 photos
Posted by Bruce Voelkerding on 31/01/2023 12:16:14:
It's a fixed steady rather than a travelling one, the barrel of the tailstock is shown inserted there as a means to accurately adjust the the setting so it will remain centred whichever one is rotated to. Ideal for rod & wire work
duncan webster31/01/2023 13:26:31
5307 forum posts
83 photos
Posted by Neil Lickfold on 31/01/2023 05:25:05:
The advantages of cast iron is quite easy to cut when making things from it, and is a lot more rigid than cast ali or mild steel........
Cast iron is stiffer than ali, but in tension it's less stiff than steel. Exact values for CI depend on the mix see this.
Main advantage of CI for machine tools is damping, but castings tend to be eaevy, so more material, so even tho the material has lower Young's modulus, the component is stiffer (because there is more of it)
Neil Wyatt31/01/2023 14:55:57
19226 forum posts
749 photos
86 articles
I've 3D printed a custom steady before now, fitted three ball races onto spigots. I put a ring of insulation tape on the work to stop it being marked. It worked very well.
ChrisLH01/02/2023 13:51:40
111 forum posts
7 photos
ega I used Delrin for the pads because I had some. The choice is unlikely to be critical for occasional use. The ali I used is only about 0.090 thick again because I had some and I wasn't planning mamoth cuts. In any case loads are largely up in which direction quite a lot of material is in direct tension leading to small deflections if used gently.
ega01/02/2023 14:49:26
2805 forum posts
219 photos
Posted by ChrisLH on 01/02/2023 13:51:40:
Thank you - Delrin sounds like a good choice.
