JasonB | 25/10/2022 13:11:25 |
![]() 25215 forum posts 3105 photos 1 articles | I've done a plot using those sizes I got off the scan, it's close but does drift off to one side, changing the right link for Jules' length makes it a lot worse but he may have tweaked the mounting points. Also tried substituting some nominal imperial sizes based on the horizontal link being 3" but get various deviation from the piston tod axis. |
JasonB | 25/10/2022 16:21:42 |
![]() 25215 forum posts 3105 photos 1 articles | Some more fiddling ha sgot me the required stroke if I allow a +/- limit of 0.15mm on the piston rod in it's hole so I'm sure it could be made better with some more playing about. However I have just found this which looks promising, I think Michael may enjoy a look. part of this source of interesting stuff |
Michael Gilligan | 25/10/2022 18:37:44 |
![]() 23121 forum posts 1360 photos | Thanks, Jason, for the links to linkages I’ve only just arrived home, so that’s my evening entertainment sorted. MichaelG. |
Michael Gilligan | 25/10/2022 21:28:33 |
![]() 23121 forum posts 1360 photos | Another useful reference: **LINK** https://www.gutenberg.org/files/27106/27106-h/27106-h.htm Consider Figure 14 in the second section [sorry, I haven’t found the William Freemantle patent] Now … Here is the Scott Russell mechanism, 21st Century version: **LINK** https://jaset.pressbooks.com/chapter/design-and-analysis-of-a-modified-scott-russell-straight-line-mechanism-for-a-robot-end-effector/ MichaelG. . Edit. __ Appendix E of this PhD thesis is also worth a look: https://core.ac.uk/download/pdf/186333083.pdf Edited By Michael Gilligan on 25/10/2022 21:45:43 Edited By Michael Gilligan on 25/10/2022 21:47:31 |
Paul Lousick | 26/10/2022 04:32:28 |
2276 forum posts 801 photos | After a bit of searching on the net, I am a little wiser. The Watts linkage and Peaucelliar -Lipkin linkage has 6 levers to accurately aligns and supports the piston rod with the cylinder axis. **LINK** The Muncaster engine has a simpler system, although not perfect, should work for my model engine. This is the result of my investigation so far. I have plotted the offset of the linkage arms in relation the axis of the cylinder and found that the slot in the left arm only needs to be 0.5mm long to compensate for the difference in length as the arms rotate. When the piston rod is fully down , the rod end is guided by the cylinder bush and cannot move sideways. The length D=26.5mm. When the crank is at 90 degrees, D=27.0mm. At 180 degrees D=26.5mm but the rod end can move to the left because of the 0.5mm slot in linkage arm . My thoughts are that If I lengthen the vertical (113mm) link on the left side slightly, I can get plus/minus 0.25mm offset at the top position. |
pgk pgk | 26/10/2022 06:21:40 |
2661 forum posts 294 photos | It’s a tad much to take in without drawing it myself - but did you allow for hinging at the bottom of the 113 rod in your work? pgk |
Michael Gilligan | 26/10/2022 06:58:20 |
![]() 23121 forum posts 1360 photos | Beautifully illustrated, and tabulated, Paul But, [along with pgk, I presume] I am concerned by the 113mm dimension on the left 113 defines position of that link when it is vertical, but I can see nothing to describe the distance between its pivots. . Please correct me if I am ‘barking up the wrong tree’ MichaelG. |
JasonB | 26/10/2022 07:00:13 |
![]() 25215 forum posts 3105 photos 1 articles | And the rod is not 113mm long, thats the height above base |
Michael Gilligan | 26/10/2022 10:16:24 |
![]() 23121 forum posts 1360 photos | Please forgive me if I am being delusional, but I think I may have sussed the underlying problem here In this model, the block on the right-hand pillar appears to be used simply as a bracket and pivot point for the duplicated arms [E] In the classic Scott Russell mechanism, however, it provides for a sliding motion: **LINK** [as provided earlier] Ref. https://jaset.pressbooks.com/chapter/design-and-analysis-of-a-modified-scott-russell-straight-line-mechanism-for-a-robot-end-effector/ . So; the model is avoiding that fundamental complication by enlarging another pivot into a slot Thus missing the basic concept of the mechanism [ rather like putting a dummy governor on a model engine ? ] . MichaelG. Waiting to be shot-down in flames |
Paul Lousick | 26/10/2022 10:30:06 |
2276 forum posts 801 photos | Hi pgk, The CAD model is fully constrained and pivots as it would in a real model. Michael, It is a different type of mechanism and also simpler than the one I put in the link above. No sliding surfaces are used to guide the piston rod, just linkage arms. (not as good as trunk guides as used on other engines) The flywheel in the 3D model can be rotated and set at any angle (shown below at 0, 90 and 180 deg,) which moves all of the associated parts which can be dimensioned in a 2D drawing. I tried raising the vertical link slightly to see if this improved the offset at the top pivot but was not successful. Now will try varying the lengths of the other arms to see what happens.
Edited By Paul Lousick on 26/10/2022 10:38:42 |
Michael Gilligan | 26/10/2022 10:44:42 |
![]() 23121 forum posts 1360 photos | Posted by Paul Lousick on 26/10/2022 10:30:06:
[…] Michael, It is a different type of mechanism and also simpler than the one I put in the link above. . Sorry, Paul … I think we might be at slightly crossed purposes What I was trying to say was that I think either Muncaster’s original, or the subsequent CAD interpretation, gives the appearance of being a Scott Russell mechanism, but isn’t actually. MichaelG. . Edit: __ As quoted on p1 of this thread: [quote] unique for that time, these were designed as models, not scaled down industrial items. As such they were designed in their own scale [/quote] Edited By Michael Gilligan on 26/10/2022 10:52:57 |
JasonB | 26/10/2022 10:50:23 |
![]() 25215 forum posts 3105 photos 1 articles | Michael although the Russel is a bit different you are indeed right that the slot will allow sideways movement so it's not a "straight line" one on the model which is why Paul queried it in his opening post. Julius has been know to do similar what a model locks up during a simulation, as I have said it makes it "work" on the 'puter but I'm not aware of a CAD program that simulates the knocking and wear that may result.
JasonB | 26/10/2022 18:47:24 |
![]() 25215 forum posts 3105 photos 1 articles | I asked about the linkage over on MEM forum and although no one has come up with a perfect solution yet, this recent reply uses software to plot the path of the big end from this simulation, This is the plot for those that can't see it on MEM |
Michael Gilligan | 26/10/2022 20:28:36 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 26/10/2022 10:50:23:
. Busy afternoon, so I’ve only just seen your post, Jason At the risk of repeating myself … Yes, I agree Paul’s opening query was perfectly reasonable. [in the context of Muncaster’s design for a model] Paul asked: ”Does anyone have geometric design data of how these linkages are supposed to work?” The answer to that must, I fear, be No … because they are not supposed to work [!] and therefore there is no requirement for geometric design data. … they are simply a visual approximation of something which would work if the model was fully and accurately detailed. MichaelG. |
Michael Gilligan | 26/10/2022 20:49:17 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 25/10/2022 08:06:25:
[…] I'm 99.9% sure Julius took his from Westbury's artcles about Muncaters designs. What would be useful is if anyone has issue 1756 from Vol 72 that described these engines
. With my emboldening for emphasis +1 I would really like to see how Muncaster detailed that pivot Fixed or Sliding ? … that is the Question [ and I suspect the answer might be: He didn’t ] MichaelG. |
Michael Gilligan | 26/10/2022 21:28:24 |
![]() 23121 forum posts 1360 photos | Alternatively … Does anyone know for sure whether the “little book” is a straight facsimile of Muncaster’s articles in Model Engineer ? https://www.chronos.ltd.uk/product/model-stationary-engines-their-design-and-construction-by-h-muncaster/ … if so, it might be worth £5.50 just to satisfy my curiosity. MichaelG. |
Paul Lousick | 26/10/2022 22:14:21 |
2276 forum posts 801 photos | This is a link to Edward T Westbury's post about the Muncaster engines which were in Model Engineer. The 2 cylinder is listed but does does not contain the complete article which was in a later issue of ME. Does anyone have a copy ? |
Michael Gilligan | 26/10/2022 23:49:29 |
![]() 23121 forum posts 1360 photos | I’ve just found an archived advert for a 1913 edition of Muncaster’s book https://www.peninsula-live-steam-engines-tools-and-supplies.com/ourshop/prod_6977728-RARE-1913-EDITION-Model-Stationary-Engines-Design-and-Construction-Muncaster.html
Doesn’t really get us any further, but I would guess the images are better than the Tee Publishing reprint. MichaelG. |
Hopper | 27/10/2022 00:22:54 |
![]() 7881 forum posts 397 photos | Posted by Michael Gilligan on 26/10/2022 21:28:24:
Digging around in the vague recesses of my mind, I recalled I might have bought a copy of that reprint once. So digging around in the vague recesses of my library, I found it! It is worth GBP 5.50 and the reproduction quality is good. But there is no mention or drawings of the parallel motion linkage, pseudo, real or otherwise. There are drawings in it of a single cylinder entablature engine of very similar appearance but it uses the more conventional cross-head with vertical square guide bars running between the top of the cylinder and the bottom of the overhead table. The other drawings/articles in the book are for the more usual mix of double cylinder marine engine, horizontal mill engine, and vertical engines, all more the type of thing we see from Stuart Models etc. Includes nice drawings and words on making a ball governor and the connected throttling valve. Ditto reversing gear. It was first published in 1912. The words are rather sparse with not a lot of "how to" full words and music. The instructions for the entablature engine are one long paragraph, probably about 200 words, with one GA drawing with most of the dimensions left to the initiative of the resourceful builder. But I have no idea if that is how ME would have published things in that era or if their articles would have been more in depth.
Edited By Hopper on 27/10/2022 00:34:59 |
Michael Gilligan | 27/10/2022 00:29:21 |
![]() 23121 forum posts 1360 photos | Thanks, Hopper … glad to hear it’s a good reprint, but disappointed by the absence of info about the linkage. MichaelG. |
