Cross Slide Rotary Encoder
Michael Gilligan17/10/2022 16:48:00
23121 forum posts
1360 photos
Posted by Speedy Builder5 on 17/10/2022 15:43:19:
I was hoping that there was an encoder that could be "slipped" onto the slide hand wheel in a simple manner […]
Although it probably wouldn’t slip onto a Boxford, there was … but they weren’t good enough to survive the process of ‘natural selection’ … The WolfCraft ones used Gray Code and mechanical wipers busily wearing-out the PCB tracks, and a tiny grey-on-grey LCD
With the increasing miniaturisation of electronics; it’s probably time someone re-thunk the idea and made a Bluetooth-enabled equivalent with decent resolution, which put the display on your ‘phone or whatever.
Meanwhile … we can but dream
YouraT17/10/2022 16:50:01
83 forum posts
22 photos
oh, so something like this perhaps?
https://www.yuriystoys.com/
Michael Gilligan17/10/2022 17:00:36
23121 forum posts
1360 photos
Posted by YouraT on 17/10/2022 16:50:01:
Not quite
I know and love what you have done over the years, but unless I have missed it [in which case please forgive me] there is nothing of yours that does the bit that Speedy was looking for … a self-contained rotary device which slips nicely onto a feed-screw and counts parts of a turn.
YouraT17/10/2022 17:10:21
83 forum posts
22 photos
Posted by Michael Gilligan on 17/10/2022 17:00:36:.
Not quite
Not me, although that names are similar
It was more a response to the bluetooth connection and on screen display than the leadscrew bit of the OP's request.
I do think though that using small format magnetic scales on the slide is a better approach than the rotary encoder option, as you will be measuring actual slide displacement rather than something one link removed from it.
John Haine17/10/2022 17:12:30
5563 forum posts
322 photos
The encoders that Joe referenced look nice, but would one need to calibrate them? For example, the LS pitch might be a bit off, or the screw somewhat worn.
Michael Gilligan17/10/2022 17:32:46
23121 forum posts
1360 photos
Posted by YouraT on 17/10/2022 17:10:21:
Oops ! … I thought it was an a.k.a.
blush MichaelG.
Michael Gilligan17/10/2022 17:38:00
23121 forum posts
1360 photos
Posted by John Haine on 17/10/2022 17:12:30:
Ultimately, direct reading of linear movement must be the preferred option, but if Speedy just wants a convenient display of Metric values this seems very expedient, and almost certainly better than the visual resolution of a Boxford dial.
duncan webster17/10/2022 17:50:44
5307 forum posts
83 photos
Way back in the mists of time (2013?) I described in ME how I'd mounted an encoder onto the leadscrew of a Cowells lathe. Readout by Arduino. It had a 90 slot wheel which gives better than half a thou resolution with a 0.1" pitch screw. You'd need to find a way of mounting the optoswitches onto the handwheel bracket. By this time, I'd be seriously looking at just buying the gubbins and using a magnetic tape. You'll want DRO on the saddle soon enough having got used to it on the cross slide. If you want a copy of the article send me a pm
Mike Poole17/10/2022 19:13:22
3676 forum posts
82 photos
Chronos list these displays for the C3 type lathes. You may be stuck with the feedscrew pitch of the C3 lathe though.**LINK**
Speedy Builder517/10/2022 19:31:53
2878 forum posts
248 photos
I guess I was looking for something like this with a hole through the middle?
Michael Gilligan17/10/2022 19:49:10
23121 forum posts
1360 photos
Posted by Speedy Builder5 on 17/10/2022 19:31:53:
That was certainly my assumption
… and what Mike links
Edited By Michael Gilligan on 17/10/2022 19:50:40
JasonB17/10/2022 19:54:20
25215 forum posts
3105 photos
1 articles
They do have a hole through the middle see here
However as I said in my first post I think they come set up for metric screws so one turn will read 2.00mm or 0.079" on the display
AJAX17/10/2022 20:11:07
433 forum posts
42 photos
Why not just fix a dial indicator to the cross slide to show movement across the bed? Cheap, no battery, easy to read and zero.
Speedy Builder518/10/2022 06:48:07
2878 forum posts
248 photos
Fair point Ajax! The CHRONOS readout is the sort of thing I was looking for, like Jason said, if I could change the pitch of the feed screw on the device.
Bob
Michael Gilligan18/10/2022 07:43:50
23121 forum posts
1360 photos
Posted by Speedy Builder5 on 18/10/2022 06:48:07:
[…] like Jason said, if I could change the pitch of the feed screw on the device.
That’s why I said this style of read-out had disappeared by ‘natural selection’ [Darwinism]
I have never looked inside the SIEG device, but I suspect it is very similar to the WolfCraft one.
That simply didn’t have enough ‘native resolution’ to cope as a data-source for Imperial/Metric conversion.
Sorry, I no longer have the device, so I can’t take photos … but it was mechanically quite crude.
Edit: __ See here for the use of Gray Code on shafts:
 https://en.wikipedia.org/wiki/Gray_code#Position_encoders
If I recall correctly the WolfCraft device only used four tracks
[as per the monochrome illustration on that page]
Edited By Michael Gilligan on 18/10/2022 07:54:48
Michael Gilligan18/10/2022 08:07:59
23121 forum posts
1360 photos
This [being a more sophisticated SIEG unit] is interesting: **LINK**
http://www.mini-lathe.com/mini_lathe/reviews/Sieg_DRO/dro2.htm
Edited By Michael Gilligan on 18/10/2022 08:10:25
JasonB18/10/2022 08:39:40
25215 forum posts
3105 photos
1 articles
Thanks for the last link Michael, I knew they were thread specific but thought it was the metric thread.
What's really needed is something like a bike computer where you set distance according to tyre diameter but in this case it would be thread pitch. Switching between radius and diameter reading would be an added bonus.
Michael Gilligan18/10/2022 09:23:47
23121 forum posts
1360 photos
Just spotted this offering by ARC : **LINK**
https://www.arceurotrade.co.uk/Catalogue/Machine-Spares/SC3-Mini-Lathe-Spares/SIEG-Mini-Lathe-DRCD-to-Manual-Conversion-Kit
It would be interesting to know what has driven this
JasonB18/10/2022 10:05:05
25215 forum posts
3105 photos
1 articles
That will be the same one I linked to about this time yesterdaywink
Michael Gilligan18/10/2022 10:22:56
23121 forum posts
1360 photos
Posted by JasonB on 18/10/2022 10:05:05:
Apologies, Jason … I don’t recollect following your link [because I wrongly assumed it would be for a ‘digital upgrade’ not for an upgrade from digital to mechanical]
mea culpa
P.S. __ I now also note that the SIEG digital unit, that it is shown as replacing, is already the more sophisticated version [!]
Edited By Michael Gilligan on 18/10/2022 10:32:26
