Milling with 80mm Facemill with Milling Machine
Chris Mate | 19/01/2022 13:54:15 |
325 forum posts 52 photos | Hi, jason, I thought it was like you said, but after googling it, I got to as I have stated it. I have not yet a DRO, so if I misunderstood it, I accept, very confusing as explained in different places on the net. Edited By Chris Mate on 19/01/2022 14:08:15 Edited By Chris Mate on 19/01/2022 14:08:44 |
Tony Pratt 1 | 19/01/2022 14:01:19 |
2319 forum posts 13 photos | Posted by JasonB on 19/01/2022 13:43:37:
X is the side to side movement along the table Y is front to back X is up and down Z is up and down |
Howard Lewis | 19/01/2022 16:03:45 |
7227 forum posts 21 photos | The reason that I mentioned climb milling (Where the feed is in the same direction as the movement of the cutter blade if it is offset ) was that unless the machine has backlash prevention, it is likely that the work will be pulled into the cutter (taking out the backlash ) with possibly damaging consequences.. Otherwise, always feed the work against the direction of cutter rotation, unless the cutter covers the whole surface of the work. Even then take care at the ends of the cut when only one side of the cutter is in contact with the work. Tony Pratt has told you the correct nomenclature for the axes, so that you can avoid any confusion on any future questions Howard |
JasonB | 19/01/2022 16:11:16 |
![]() 25215 forum posts 3105 photos 1 articles | Bit of a typo on my part Maybe a picture from a book would help, this one shows X, Y and Z |
Chris Mate | 19/01/2022 16:41:31 |
325 forum posts 52 photos | JasonB, thanks man, I appreciate this and will stick to this then.. |
JasonB | 19/01/2022 17:11:50 |
![]() 25215 forum posts 3105 photos 1 articles | I'm assuming by 4th axis you really mean one with 4 straight scales in which case you would be better off getting a console capable of "summing" this will give one display for any vertical movement be it from moving the head or the quill so for example if you raise the head to change tooling you can bring it back down to any position and then use the fine feed of the quill to put on the cut. In milling terms the 4th axis generally refers to a rotating axis like a rotary table |
Nigel McBurney 1 | 19/01/2022 18:55:45 |
![]() 1101 forum posts 3 photos | Universal mills had a swivelling table primarily to produce spiral gears and other work which had helix form,the general practice with these machines which had 3 tee slot tables was for the centre slot to be central to the table pivot and the dividing heads had tenons which aligned the axis of the head/tailstock to the centre of the central tee slot,so anyone contemplating the restoration of a universal mill do not attempt to clean up the central tee slot,leave it alone and if making new dividing head keys make sure edges of the keys are equispaced to the keyway in the base of the head. When finishing work with a cutter which is larger in diameter than than the width of the workpiece place the cutter central to the work, Unless the vertical mill spindle is truly vertical, any cutter be it single tooth or multi tooth will produce a surface which is hollow towards the centre of the cut so it is better to get the any slight hollow in the centre of the workpiece. if any is not convinced by this try setting a cutter with the vertical spindle set over a few degrees the result would be a elliptical groove if the head was set over at 90 degrees it would of course produce a half round slot. |
Chris Mate | 19/01/2022 18:56:10 |
325 forum posts 52 photos | Thanks JasonB, I found it(dro-linear-encoder-summing-interface) will look into it. Edited By Chris Mate on 19/01/2022 18:56:28 |
JasonB | 19/01/2022 19:16:55 |
![]() 25215 forum posts 3105 photos 1 articles | That's the sort of thing but some of the readouts will have that built in, eg 4 sockets on the back but just 3 rows of display but they are the more expensive ones so worth checking the prices as all in one may still be cheaper than the readout and separate box of tricks |
Chris Mate | 19/01/2022 19:55:40 |
325 forum posts 52 photos | Correction : Edited By Chris Mate on 19/01/2022 20:04:30 |
Andrew Johnston | 19/01/2022 23:00:29 |
![]() 7061 forum posts 719 photos | Posted by Chris Mate on 19/01/2022 13:27:17:
7-If I want to dial in my vice, I must 1st dial in the Y-Axis swivelled to 0 degrees. I have verified and fine adjusted it using a precission square running the X-Axis forward and backward in relation to spindle. If this is not exactly zero, I found I cannot dial in my vice 100%. I think this may be interesting, seeing if you dont have a swivel bed Y-Axis you rely on its manufactured accuracy, which if slightly out, is a difficult job to get right, so I assume in such a case you can spend hours and just get your vice 97% say accurate as example. I think your geometric logic is wrong. When you are indicating on a vice jaw, with the indicator on the mill body, you are aligning the vice to the ways of the table, and should be able to get it as close as you wish. What the angle of the table is relative to the theoretical perpendicular X direction is irrelevant. On my Bridgeport (fixed table) it only takes a minute or two to align the vice to better than a thou in six inches. When setting the vice on the horizontal mill it takes the same. I have normally set the swivel table on the horizontal parallel the ways on the Z-axis first, so that the cutters cut true rather than at an angle. Having a swivel table does not help in setting the vice accurately. Andrew |
Chris Mate | 20/01/2022 04:25:29 |
325 forum posts 52 photos | Andrew, my indicator was in a chuck(Z1/Z2-axis) in the spindle before I fit the face cutter, I then have the spindle in lowest gear and grip with hand to take up play, it then stays there, so the spindle does not move/turn, I then indicate the vice fixed jaw placed on X-axis which can swivel). Edited By Chris Mate on 20/01/2022 04:29:52 |
Chris Mate | 20/01/2022 04:55:55 |
325 forum posts 52 photos | Request: Can one of the moderators please close this thread, as its now a complete mess and serve no purpose. Edited By Chris Mate on 20/01/2022 05:07:28 Edited By Chris Mate on 20/01/2022 05:08:25 |
JasonB | 20/01/2022 07:29:52 |
![]() 25215 forum posts 3105 photos 1 articles | You need to square the table first so it is at right angles to the fixed Y (front back) Best way I can think of is to clamp a good quality square to the table, clock it true to the fixed Y. Then swivel the table until the other blade of the square clocks true in X. If the vice is set true on a table that is still a bit angled you will make parallelogram parts not square ones. If you don't follow that I can sketch something. A magnetic holder for the Dti will be a usefull addition to your tools |
Andrew Johnston | 20/01/2022 08:17:45 |
![]() 7061 forum posts 719 photos | Posted by Chris Mate on 20/01/2022 04:25:29:
Do I understand this wrong-? Setting the swivel table parallel to X and aligning the vice are separate issues. The only time I use an indicator in the spindle is when tramming the mill. The spindle may not look like it is moving, but it will be. I'll take some photos this evening to illustrate what I do. Andrew |
Chris Mate | 20/01/2022 10:51:14 |
325 forum posts 52 photos | JasonB, that is what I have done. Edited By Chris Mate on 20/01/2022 10:54:36 |
JasonB | 20/01/2022 11:41:49 |
![]() 25215 forum posts 3105 photos 1 articles | That sounds OK to me, Andrew actually having a mill like that may have a better method. I just have a small lever type dti on a magnetic base that sticks to the underside of the head and run the fixed vice jaw against that tapping it until I'm happy and then snug down the fixings. If you have a power X feed then it's even easier to just set it slow and tap as you go. The smaller vice I have a couple of blocks in the groove sunderneath and they locate it reasonably well for most things by just pushing back against the tee slot a sit's tightened 0.01mm over 80mm does me for most things that vice gets used for. |
Chris Mate | 20/01/2022 12:45:44 |
325 forum posts 52 photos | JasonB: I have certain trust assumptions I make and believe it is true points or surfaces that matters Edited By Chris Mate on 20/01/2022 12:47:13 Edited By Chris Mate on 20/01/2022 12:48:39 |
Chris Mate | 20/01/2022 15:15:21 |
325 forum posts 52 photos | From the manual, poor quality, I illustrae the swivel parts involved: |
Andrew Johnston | 20/01/2022 17:03:46 |
![]() 7061 forum posts 719 photos | There's no need for me to post pictures as JasonB has already done so. On the Bridgeport, with a fixed relationship between X & Y, I am only aligning the vice jaw to X-axis movement. The main differences with respect to JBs picture are that I mount the DTI on the Y-axis ways, and indicate the back of the fixed jaw for convenience. On the horizontal mill I'm doing something different in that I am aligning the swivelling table to be parallel to the Z-axis ways on the column. I'm not aligning the table to the Y-axis. I take it as a gjven that the Y-axis is perpendicular to the Z-axis by design and manufacture. Of course in horizontal mode one is also unlikely to be cutting in X and Y during the same operation. I'm going to drop out of this thread now. Andrew |
