Michael Gilligan | 01/10/2021 08:37:33 |
![]() 23121 forum posts 1360 photos | Posted by Dave Wootton on 01/10/2021 06:48:05:
[…] He was very enthusiastic about it and liked it a lot, however after a few months he went back to his old saw, when asked him about it he just said he preferred it, but couldn't explain why. Said it just felt right. […] . I can certainly relate to that, Dave My Dad’s saw feels like a natural extension to my hand. MichaelG. |
DMB | 01/10/2021 09:20:19 |
1585 forum posts 1 photos | Women, bah, how frustrating, they're always right! |
Gary Wooding | 01/10/2021 10:09:31 |
1074 forum posts 290 photos | I have 3 piercing saw frames - an Eclipse, a very old one with no name, and an early KC. The old one has a deep throat and is used only when necessary. The Eclipse was my first and only one for a number of years, but has been relegated to the job of sawing off lengths of rod or tube in the chenier cutter because the KC is so much easier to use for intricate work. It's noticeably lighter, with a better balance, and the blade tensioning method makes it far easier to cope with the problem of removing and replacing the blade when sawing out lots of separate internal sections. See photo. The conventional way of blade tensioning is to slightly bend the frame by bracing one end against the bench and pushing the other while clamping the blade. The problem arises when having to also support the workpiece at the same time in order to stop it rotating and breaking the blade; think of a 6/0 (0.18mm thick) blade in a 0.6mm hole. The screw tensioning of the KC is sooo much easier. |
File Handle | 11/10/2021 15:13:26 |
250 forum posts | I have 2 piercing saws. One very old, one much newer. Both are tensioned by adjusting the length of the frame. this means that broken blades can often be reused, albeit with a shorter blade. i much prefer the older one. If I need more depth I also have 2 fret saw frames.
Tim Stevens | 11/10/2021 16:59:40 |
![]() 1779 forum posts 1 photos | The method I have used when needing to use a piercing saw at an angle is to twist the (soft) ends of the blade. As long as your blades are not rusty (and have been properly hardened - not at the ends) this works well. Another hint which might help is using a piercing saw for parting on a lathe with a very narrow waste band: Ensure that the blade is fitted the correct way, teeth pointing towards the handle, and use the saw below the work. Either spin the work fairly quickly and move the blade slowly back & forth, easing pressure on the return stroke, or rotate slowly and saw quicker. Don't leave the saw stationary in contact or the teeth risk clogging and jamming. And don't try this on thick stock, of course. Traditionally saws were available with a working depth of 6 inches or more. Cheers, Tim |
