Help identifying some tools
Workshop Clearance
roy entwistle11/09/2021 12:56:04
1716 forum posts
Thanks Jay
Robert Atkinson 211/09/2021 13:06:18
1891 forum posts
37 photos
The Bundenburg dead weight tester should have a matching set of weights. normally thes are paired to the tester. Unfortunatly they often go missing...
With the weights it has some value.
Robert G8RPI.
Samsaranda11/09/2021 15:19:17
1688 forum posts
16 photos
The weights for the deadweight tester will be flat discs, if my memory serves me right about 6 - 8 inches diameter, long time since I calibrated any gauges. Dave W
Martin Connelly11/09/2021 17:04:30
2549 forum posts
235 photos
1985 was the last time I used a dead weight pressure tester.
Martin C
Howard Lewis11/09/2021 18:04:04
7227 forum posts
21 photos
You may find all sorts of good things in the filing cabinet, possibly the dead weights for the Budenburg, and other instrument as W I P which might benefit from the addition of the Drum Micrometers.
Seek and ye shall find!
Ebenezer Good13/09/2021 14:42:07
48 forum posts
2 photos
I have a test weight for one of them in my scrap pile, if I could see how to upload a picture I'd put it on here so you can see what you are looking for.
Michael Gilligan13/09/2021 17:30:34
23121 forum posts
1360 photos
Posted by Ebenezer Good on 13/09/2021 14:42:07:
Here, for your delectation and delight is the sticky thread which answers the most frequently asked of all the FAQs
https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
Ebenezer Good14/09/2021 11:42:39
48 forum posts
2 photos
Thanks for that Michael, I was trying to get the pictures to go up directly!
As promised 1 x dead weight
Howard Lewis14/09/2021 14:52:53
7227 forum posts
21 photos
If the worst comes to the worst, and you only have one weight, it can be used to calculate the diameter of the plunger.
Once that is known, it should be possible to calculate the weight for each increment of pressure, and then to make new ones..
Alternatively, the easier calculations may be; knowing the weight that gives a known pressure, others can be calculated by multiplying or dividing and making weights to match the required pressures.
Howard,
