garden tractor wheel lug nuts and studs
AJAX02/06/2020 22:58:26
433 forum posts
42 photos
Posted by Nigel McBurney 1 on 02/06/2020 10:12:37:
I have seen similar hub problems on 1950s steel "British Hubs" fitted to the back wheels of Dot and Greeves competition machines,where the sprocket bolts were forever coming loose.The previous owner no doubt had found that instead of the wheel nuts coming loose ,the action of the wheels over rough ground rattled the short end of the studs out of the hubs,the wheel nuts did not come loose .to cure the problem he reversed the studs and put a lock nut on the back of the hub,
You could well be right and I can't think of a better explanation.
Plasma03/06/2020 09:38:46
443 forum posts
1 photos
Sent you a pm ajax.
Mick
AJAX08/06/2020 22:16:53
433 forum posts
42 photos
I'm still waiting for parts to be delivered, so this has given me a chance to strip everything down, do some weld repairs and give it a lick of paint. Here's a video if you are interested.
https://youtu.be/7Uq76twni7s
Take care,
Brian
oldvelo09/06/2020 02:34:56
297 forum posts
56 photos
Hi Ajax
I had problems too with accessing my albums Etc. The advice I recieved was to use the Icon No 6 on the second row of the posting window or as it advises Ctrl + K keys together.
Great interesting project looking forward to seeing it running.
Eric
AJAX10/06/2020 20:25:00
433 forum posts
42 photos
Some progress has now been made. The chassis has been fully stripped down and some weld repairs made. It has been repainted with Hammerite red oxide primer and Lidl grey paint. I have used this Lidl paint on several projects and rate it highly - it can't be beaten on price, it's tough and looks good too. The wheels are back on and the motor is being positioned for permanent mounting.
Edited By AJAX on 10/06/2020 20:25:25
AJAX10/06/2020 20:29:09
433 forum posts
42 photos
And here is a video update if anyone is interested to have a look around.
AJAX10/06/2020 20:31:35
433 forum posts
42 photos
Posted by oldvelo on 09/06/2020 02:34:56:
Hi Ajax
Eric
Eric,
Thanks for your helpful suggestion. I tried the link option (Ctrl+K) which produced a text link, but found the Image button a better option when I found that I could use the URL for the image.
Brian
AJAX20/10/2020 22:50:33
433 forum posts
42 photos
Just thought I might mention that I used 1/2" UNC screws with the original lug nuts and it's been working just fine. In fact, it has been a real workhorse and the wheels haven't fallen off, yet. smiley
AJAX20/10/2020 22:54:31
433 forum posts
42 photos
Posted by Hopper on 02/06/2020 08:38:34:
UNC taper thread? No such beast exists that I have ever seen. Sure it is not just a worn stud?
Can you clean up the existing studs and Loctite the short ends into the hub and screw the lugnuts on to the longer ends, with wheel etc?
Or use 1/2" UNC high tensile machine set screws screwed through from behind and Loctited in position? Or cut the heads off them and make your own studs?
I never used Loctite in the end (I didn't have any) but keep meaning to buy some for this and other similar jobs. I see there are different versions of Loctite - can anyone suggest which one I buy for general use like this?
Emgee20/10/2020 23:18:35
2610 forum posts
312 photos
For permanent fixing I use 638, however you can still remove the studs by applying heat to break the bond.
Emgee
AJAX20/10/2020 23:22:35
433 forum posts
42 photos
Posted by Emgee on 20/10/2020 23:18:35:
Emgee
Thanks for that.
As an aside, I see that Toolstation stock "Loctite Threadlocker (Normal)" -- I wonder what that is.
Alan Donovan21/10/2020 08:14:52
81 forum posts
41 photos
Hi AJAX
If you visit the Loctite company website you will find their complete range of products, complete with instructions for use and what situations they should be used in. A visit to the website would ensure you are using the correct product for your application.
Loctite do manufacture a couple of ‘general multipurpose’ grades as well as specific grades for specific applications. One of their multipurpose grades would probably suit most home workshop situations, and would probably be available from most DIY or ME outlets.
I hope that helps.
Keep safe. Alan
