Warco WM250V Rattling Noise
mechman4806/06/2018 23:29:32
2947 forum posts
468 photos
Re. dro's... I use a couple of digi tyre depth gauges on my lathe, one on the tail stock & one on the cross slide both fixed by 5mm neodymium magnets glued on to the under side,& 3mm ones glued on to the end of the probes, small but very strong grip & both work spot on for me. If I'm not using the tailstock one I use that for the saddle longitudinal travel, never had an error, other than of my making...
Tail stock dro...
Cross slide dro...
George.
Ross Lloyd 110/06/2018 00:14:11
153 forum posts
1 photos
Posted by mechman48 on 06/06/2018 23:29:32:
Tail stock dro...
Cross slide dro...
George.
Thanks George! Whats the maximum travel those things can read?
Cheers
Ross
mechman4810/06/2018 10:52:10
2947 forum posts
468 photos
Posted by Ross Lloyd 1 on 10/06/2018 00:14:11:
Tail stock dro...
Cross slide dro...
George.
Thanks George! What's the maximum travel those things can read?
Cheers
Ross
​I've taken the stops off the slides end & I can get up to 37mm travel which is fine for the final finishing to length / up to shoulder / final dia. I did make one out of a 150mm digi vernier & that worked ok but wasn't happy with the faff on locking it every time but could get 135 mm reading with that...
George.
Edited By mechman48 on 10/06/2018 10:54:00
mechman4810/06/2018 18:00:32
2947 forum posts
468 photos
Ross
Whilst I was in the man cave today I did a check on the tyre gauge digi read out travel on the saddle travel position, can get 50mm safely before scale comes out of read head... sufficient travel for finishing off with just a 'tad more', & when you're done just unclip it & store it back on the tail stock, or wherever...
​George.
Ian Skeldon 210/06/2018 19:42:32
543 forum posts
54 photos
Hi George,
How are these gauges attached to the machine and where can they be bought?
Many thanks,
Ian
Ian Skeldon 210/06/2018 19:46:15
543 forum posts
54 photos
Can't edit my previous post but I have re-read that you use magnets glued to the scale, so if you can offer advice on where to buy these type of scales.
Thanks,
Ian
Ross Lloyd 111/06/2018 01:52:09
153 forum posts
1 photos
Posted by mechman48 on 10/06/2018 18:00:32:
Ross
​George.
Thats really quite ingenious. I dont fancy a full DRO setup on the lathe at this time, but those might just be a nice compromise.
mechman4811/06/2018 09:27:32
2947 forum posts
468 photos
Bought off eBay... cut the lugs off, super glue / epoxy 4-6 neodymium magnets onto back... voila! ... usual disclaimer applies.
George.
Edited By mechman48 on 11/06/2018 09:29:41
Howard Lewis11/06/2018 22:27:29
7227 forum posts
21 photos
If you don't fancy modding a digital caliper, (They really are HARD steel) you can buy DROs with horizontal scales for tailstocks, saddles etc, or vertical for Z axis on vertical mills)
My Tailstock DRO now won't switch off, (Battery removed for the present, dared not say "currently" ) so the next job on the Round Tuit is to remove, strip and clean the circuit board, and hope that it will be cured.
Edited to remove unwanted emoji!
Edited By Howard Lewis on 11/06/2018 22:28:27
Ian Skeldon 212/06/2018 21:17:56
543 forum posts
54 photos
Posted by mechman48 on 11/06/2018 09:27:32:
George.
Thank you George, very helpful links and very cheap gauges. Will give it a go.
Thanks, Ian
