Electrical fault on X Feed PCB?
John Rudd | 22/11/2016 09:45:35 |
1479 forum posts 1 photos | R35 would normally be connected across Q4, subject to Les's schematic being correct, which is the fault light latch....closer examination of the board will tell if it has been 'blown away' or just not fitted.... And just to clear up any misunderstanding on the board and X3 mills....this is not the same board fitted to later X3 mills with the brushless motor.... Edited By John Rudd on 22/11/2016 09:46:47 |
Les Jones 1 | 22/11/2016 09:57:31 |
2292 forum posts 159 photos | Hi John, Les. |
Martin W | 22/11/2016 11:42:42 |
940 forum posts 30 photos | Hi The fact that none of the lamps lit when Martin applied power to the unit implies that there was no mains getting to the unit, one item Les wanted Martin to check. Looking at the pictures Martin posted there 'appears' to be no damaged components or tracks, unless R35 has vanished into oblivion. While I realise that it is a low power device I was wondering if the 22V zener might have afforded any protection to the components downstream before the fuse blew. Looking at the pictures it doesn't look as if it suffered catastrophic failure as could happen with a mains short, though a fast acting fuse may limit the visible damage. I am fully aware that the physical appearance of a component does not always reflect its functionality, some failures can be spectacularly obvious and need no checking. If the zener diode is intact then I would assume that downstream components would stand a fair chance of survival and there might be some hope of resurrecting the board. Just musing. Martin W |
Les Jones 1 | 22/11/2016 22:50:39 |
2292 forum posts 159 photos | Hi Martin (W), Les. |
I.M. OUTAHERE | 23/11/2016 02:00:43 |
1468 forum posts 3 photos | Have you plugged another appliance or tool like a mains powered drill into the same power socket to see if there is power there? There is also the possibility although a small one that the limit switches have been damaged or the direction switch . If the power light is not lighting up you either have no power , lamp is blown , the fuse is blown or not making contact inside the holder so i would look at that first by checking continuity between the mains plug active (hot) pin and the connector that the power lamp connects to the active (hot) line , if your buzzer sounds when you check this it means the lamp is dead but if it does not sound check either side of the fuse as i have seen fuse holders do some strange things ! Then check the neutral line the same way but leave out the fuse check as it is on the live side only but do check the neutral side of the lamp for continuity as a broken circuit here will stop the lamp lighting also . |
Martin King 2 | 24/11/2016 13:08:38 |
![]() 1129 forum posts 1 photos | Hi All, Someone has kindly offered to take a look at the whole unit for meto see exactly how much damage I have caused. Doubltless we will see the resuklts of the post mortem here later on. My grateful thanks to all who have tried to help me with this, very much appreciated. Regards, Martin
Martin King 2 | 08/12/2016 16:36:15 |
![]() 1129 forum posts 1 photos | Hi All, Unit arrived this pm from oop north and is back in working order complete with a now fucntioning power on light! Cannot express my appreciation enough to John Rudd for doing this for me. Perhaps he may be along to explain what was wrong with it but I am one happy bunny! Now where was that soldering iron.......? Happy Xmas All! Martin |
