working out screwcutting gears.
Ajohnw | 18/10/2015 17:40:22 |
3631 forum posts 160 photos | It looks like you have a setting for 16 tpi A,B,C & D are 60,48,50,27 so if you change the 48 to a 24 you will get 8 tpi. Or some approximation as I think this one has always been metric. Looking at the manual the gear behind A isn't the same size as the one on the end of the spindle. Makes thing tough to work out. If you post a photo of the screw cutting chart that came with the lathe, add any other gears that come with it and count the teeth on gear on the end of the spindle and the one that meshes with it behind A it should be possible to work out what to put in the screw cutting calculations. A photo showing the gear set up that meshes with the spindle might help too in case it's very different to the manual. The problem might be that on what I call real lathes the tooth count on the spindle is usually the same as the one that meshes with it, often via tumbler reverse that is running as an idler. If it's arranged as shown in the manual the lead screw pitch needs to be multiplied by a factor otherwise the sums wont work out. John - |
mick70 | 18/10/2015 18:35:25 |
524 forum posts 38 photos | abcd are as in manual pic1 shows them on lathe gear at back of a is 50tooth gear that meshes to is 24 as in pic 2 |
mick70 | 18/10/2015 19:02:53 |
524 forum posts 38 photos | thank you Rod just tried it and works great thanks. |
Ajohnw | 18/10/2015 19:44:34 |
3631 forum posts 160 photos | The 24 and 52 are effectively a compound train that's always there. The make the lead screw run 24/52 slower than the pitch actually is = finer by that factor. To save me doing one perhaps Rod will add that factor in to his spread sheet. John - |
Roderick Jenkins | 18/10/2015 21:37:41 |
![]() 2376 forum posts 800 photos | Thats better! With a 24/50 pair (threw me for bit there John) and a 1.4mm pitch leadscrew we get: The imperials are exact and the metrics improved. Interesting way of doing it! Rod |
Michael Gilligan | 18/10/2015 21:49:15 |
![]() 23121 forum posts 1360 photos | Excellent work, Rod Just one awkward question: How do you reconcile 1.4mm pitch with the 'measured' 13tpi ... Is it the effect of that two speed-gearbox ? MichaelG. |
Roderick Jenkins | 18/10/2015 22:02:29 |
![]() 2376 forum posts 800 photos | Posted by Michael Gilligan on 18/10/2015 21:49:15:
I can't make it work with a 2mm leadscrew |
Ajohnw | 18/10/2015 23:11:28 |
3631 forum posts 160 photos | There should be a graduated handle on the end of the lead screw. The numbers each side of the zero might offer a clue. Trouble is that it could be anything with an unusual drive like that even 13 tpi but I'd guess it's metric. One thing for sure 8.5 tpi is too far out anyway. John - |
Bazyle | 19/10/2015 09:29:35 |
![]() 6956 forum posts 229 photos | It is still possible that there are two versions of the lathe as the OP has said the table on the lathe does not agree with the manual. 1.4 pitch is weird. Perhaps the op could run 'screwcutting' with a felt tip tool on a long work piece with a specific set of gears to confirm Rod's calculations. |
Ajohnw | 19/10/2015 09:49:02 |
3631 forum posts 160 photos | The best option is probably a photo of the dial on the handle on the end of the main lead screw showing the zero in the middle and the numbers each side of it. Extreme but I found that was the only way of finding out if some one was selling a metric or imperial lathe. Naughty might be able to tell or maybe not. There are distinct differences. On the other hand the markings might be approx - not exactly unknown but in the past it's been 2.5mm = 0.100 which it doesn't. Or maybe Clark will reply to the email he sent. John - |
mick70 | 19/10/2015 10:13:08 |
524 forum posts 38 photos | the D gear on 40/20 tpi should be 42 not 27. when set to 1.5 the 8tpi is correct. will slowly work my way through the others over next couple of weeks and keep updating thread as when i check them out.
am very grateful for help so far. |
Roderick Jenkins | 19/10/2015 10:28:05 |
![]() 2376 forum posts 800 photos | I think MichaelG is correct, there is further translation gearing associated with the 2 speed lever. A 2mm pitch leadscrew seems to fit with Naughtyboy's measurement. This, together with introduction of 20:14 (or similar ratio) gears gives a very good result: I've added the third place of decimals so we can see that the metric gears are now exact and the imperials are very good approximations. If this is how the gearing is arranged then hats off (and apologies) to the designers! It really needs a 30 tooth gear in the train to give a reasonable 8tpi. What a fun puzzle Rod Edited By Roderick Jenkins on 19/10/2015 10:33:51 |
Ajohnw | 19/10/2015 12:24:28 |
3631 forum posts 160 photos | The parts diagrams only show a dog clutch - no high low feed lever. It does mention that there is a 50T gear on the spindle but zero else. There are lots of variations on this one about but no luck finding another make's manual. I found one that did 4 - 120 tpi, others 8 to ??. Some have gearboxes, some have the milling head with and without a separate motor. Some even have power cross feed.
Actually I had an early one - put me off Chinese lathes for ever but maybe they are better now. They had just updated it by chopping off the tailstock nose to gain an extra 2" between centres. Fine but it needed a morse extension socket to work up to a centre which reduced the centre distance to less than it was before. Head stock out of alignment but could have been shimmed - I think. Tail stock the killer. Hand scraped, it had been but probably 1/2 mm to go and not anything like aligned anyway. John - |
Paul Relf-Davies | 18/11/2015 16:30:29 |
84 forum posts 1 photos | Hi all, I've been working on a simple (web-based) program to calculate change gears for my own use...it is still a work in progress, but using it, with the OP's gear, it has come up with the following combinations: It should be noted that my program is designed to expect an imperial lead screw pitch, but should handle the 'imperialification' of a metric pitch, so these figures used a pitch of 7.69TPI, as opposed to 3mm. I make no guaranteed that these combination will actually fit together...I'm still working on that feature! Simple: A : D -> Result (Error) Compound: A : B / C : D -> Result (Error) (under the covers, the program is just working out the resulting TPI for a given lead screw and set of gears for all possible combinations, and then the result with the specified target (in this case 8TPI) and filtering out those where the error is too great. The calculation used is as follows (using the 1st compound set as an example) (Driven / Spindle) x (Leadscrew gear / Driver) x Leadscrew TPI (B/A) x (D/C) x Leadscrew TPI (48/50) x (39/36) x Leadscrew TPI 0.96 x 1.083 x 7.69 1.04 x 7.69 7.9976, which is 0.03% under the target of 8TPI I hope this is of use....(and I'd be very grateful if anyone could point out any errors...I'm still 'enjoying' the gear-combination calculation learning curve!)
cheers Paul |
