Here is a list of all the postings vintagengineer has made in our forums. Click on a thread name to jump to the thread.
Thread: Has your clock slowed down ? |
09/03/2018 15:46:15 |
The standard Greenwich Mean time is fiddled every year to make up for errors in our orbit. We are supposed to have a double leap year every 300 years but the powers to be have decided to adjust this every new year.
Thread: Is society becoming more stupid |
09/03/2018 15:42:18 |
When I served my apprenticeship, the sparky's dept had a button on their counter with sign saying "do not press". Many an idiot pressed it unbeknown to them the button consisted of two contacts and when you pressed it you got a healthy wallop of electricity! Albeit with no amps.
09/03/2018 10:28:39 |
Peanuts are not actually nuts they are legumes.
Posted by Mexican jon on 09/03/2018 02:53:53:
The world gone crazy
Edited By Mexican jon on 09/03/2018 02:54:33
Thread: Cobalt drills? |
04/03/2018 21:04:24 |
I have used a resharpened masonary drill bit to drill very hard steel. |
Thread: Bandsaw blades |
04/03/2018 20:59:10 |
Industrial bandsaws have butt welders on the side for making up blades. We used to make our own blades and weld them through a hole in the job to cut the centre out. |
Thread: aluminium grade |
04/03/2018 19:40:53 |
When welding aluminium it is best to use some of the parent material as a filler rod. |
Thread: Bench grinders and their dust |
03/03/2018 20:36:41 |
All my grinders are connected to a vaccum cleaner via 45mm sink waste pipe. It removes 90% of the dust, due to there being a partial vaccum in the wheel gaurd.
Thread: Cleaning aluminium corosion |
03/03/2018 20:23:24 |
Caustic soda is highly aggressive to aluminium and very difficult to neutralise. Srcubbing with phosphoric acid works but you need to neutralise it with a baking sod solution afterwards. |
Thread: Chucks 3 or 4 jaw for general use. |
02/03/2018 23:24:22 |
When I did my apprenticeship we were only allowed to use 4 jaw chucks. 3 jaw chucks were for production work. I can set up a 4 jaw chuck faster than you can set up a 3 jaw chuck with soft jaws. We never used hard jaws except for in the maintenance shop where you just need to do rough work. |
Thread: Tool Owners Ghosts |
02/03/2018 21:44:42 |
I have a 6" engineers square stamped RAF 1916 and it came from the Royal Aircraft Factory in Farnborugh. |
Thread: Large Lathe - 16 feet diameter faceplate. |
01/03/2018 18:55:10 |
Boring mills are much larger in diameter than the height. They are basically lathes standing on end. Very larger ones ar sunk into the floor so the face plate is level with the floor. |
Thread: Large lathe for sale |
01/03/2018 13:54:53 |
Anyone want a bigger lathe? **LINK** |
Thread: Galvanised steel |
01/03/2018 10:00:26 |
To remove zinc, soak overnight in a saturated solution of malt vinegar and table salt. This will dissolve the zinc and works well on nuts and bolts!
Thread: Hobby related jokes |
25/02/2018 10:04:14 |
That applies to all modern cars! Posted by Mick Charity on 25/02/2018 07:33:32:
The primary function of design is to make it difficult to fabricate & impossible to service.
Thread: Tig Brazing Copper |
25/02/2018 10:02:44 |
I still always test the cleanliness of tanks with a naked flame! Posted by Hopper on 25/02/2018 05:11:58:
Posted by vintagengineer on 24/02/2018 17:27:50:
I have welded hundreds of fuel tanks. There is no danger what so ever if you follow the correct procedures. You need to use a good degreaser to clean the inside and then flush with water. Yeah, it's a one in a thousand chance any residual flammable petrol will explode while welding a tank. Keep going... Edited By Hopper on 25/02/2018 05:13:28
Thread: Silver soldering. |
24/02/2018 22:50:30 |
It needs to be nickel plated afterwards and I not sure if you plate over tin lead ? Posted by IanT on 24/02/2018 22:32:08:
As a hand-brake 'handle' is presumably not subject to high temperatures, why not 'tin' the parts with soft solder and then sweat them together. Unless it's on an 'edge' - this should make a very strong joint and would be much easier to do. Regards, IanT
24/02/2018 21:48:35 |
I am making a handbrake lever for a vintage Bugatti. I need to increase the thickness on the handle end to a particular shape. Can I silver solder both sides of the join and then clamp together and heat to make the joint? I would normally used Silver solder tape but have run out and cannot find a supplier. Thanks in advance. |
24/02/2018 17:27:50 |
I have welded hundreds of fuel tanks. There is no danger what so ever if you follow the correct procedures. You need to use a good degreaser to clean the inside and then flush with water. Posted by Andrew Tinsley on 24/02/2018 16:48:35:
Sounds pretty dangerous to me. I know of 2 deaths caused by explosions with people trying to braze petrol tanks. It just isn't worth the risk. Andrew.
Edited By vintagengineer on 24/02/2018 17:32:11 |
Thread: Making brass and bronze |
23/02/2018 14:48:19 |
I work a lot on vintage cars and what appears to aluminium castings are in fact ali zinc alloy. The foundries used to melt the ali then bulk it out with cheaper zinc. It is a real bugger to weld! |
Thread: New to flaceplatery - a question of balance |
23/02/2018 08:53:24 |
Even on huge lathes you need to balance the faceplate. The better it is balanced the lest chance there is of turning ovals. We used to cast lumps of lead in baked bean tins and used these as balance weights. |
