Member postings for michael burton 1
Here is a list of all the postings michael burton 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: is the radius
22/02/2012 18:21:20
just making the throat plate and was wondering is the radius also flanged aswell as the sides ( i belive not) its on a tich boiler
mike
Thread: how long is ok
21/02/2012 21:29:22
hi neil i thort it may be abit weak i only got the 100g i thort it would be ok i havent solderd yet this is just tring to clean up the last of the anealling process before i rivet in the strip and solder the join in the barrel, indefinitely sounds good atleast i wont have a mushy blob haha il get some more citric acid tomorow.
mike
21/02/2012 20:59:44
just starting to clean up my boiler shell and i am using a citric acid pickle of just about 1 gallon of water and 100g of citric acid if thats anough citric i dont know going by the site you just mix till it does the job now some of the nastys have come off but some is being stubbon how long is it safe to leave it in there for and is there any tips?
this is my first time pickling
Edited By michael burton 1 on 21/02/2012 21:00:14
Thread: 2 secs to break 2 hours to remove
20/02/2012 20:21:32
hmm carbon hss cheap dear i dont know il see what my pocket can afford when i come to buying a new one
20/02/2012 19:28:34
hi alan il bear that in mind and when i get the money as i have to buy a new one i will buy hss
Thread: buying copper for boiler makeing
20/02/2012 16:28:43
ah ok so the strip goes on the inside i imagined it going externally il look in to the solder and when i can il make an order as for the staying well i will go for the best method, iv been looking in to the copper for the back head it calls for 13g would 2mm be ok as the fittings wont be screwed straight in i will be making bushes 2mm is .337 smaller then 13g i can get a small peice big anougth to make he back head as i dont have the money or the need to buy a big 300x300 sheet
many thanks mike
20/02/2012 16:15:56
hi to you both yeah it was the tich just a rod, i was going back and forth hardly any movement but it grabbed on the wind out. and if i was to scrap it (i was seriously considering it) i would of had to remake a few parts and fourtunly then it was a carbon steel tap im glad i got it out so is the wife because im very inpatient normally but last night must off been a good day
many thanks to you both for your replys
20/02/2012 01:49:38
just broke a 7ba tap in a 3/16'' piece of stainless steel tried knocking it round nope dried knocking it thru nope in the end i heated it to bright cheery red and broke it out with a carbide scriber then drilled the rest out, result nackerd tap nackerd scriber but saved work piece,
so my question is would the heating of it to such a heat
a) changed the structure of the tap and made it more brittle as before the heat it wouldnt break up.
b) i was just really paitant and as the scriber was harder then most things that would fit in to the hole it finally gave in
don't laugh to much my pride is failing me
Edited By michael burton 1 on 20/02/2012 01:55:47
Edited By michael burton 1 on 20/02/2012 01:57:44
Edited By michael burton 1 on 20/02/2012 01:57:53
18/02/2012 21:27:02
hi all again the barrel is nearly done just a couple more bending sesions then we should be there as mw said the next thing is the long join down the boiler tube, im guessing that a strip of copper the same as the boiler is used and rivited in a zig zag patten alternating side to side. will 1/16 copper rivets be ok to do this and how wide should the strap ideally be?
many thanks once again mike
14/02/2012 12:30:22
hi nigel i managed to get enough plate for the whole boiler for less then 30 pounds of c106 grade
14/02/2012 11:30:58
hello michael many thanks for the reply most helpful, how would you suggest the forming of the the boiler shell makeing a wooden form the size and shape off the boiler? or is there an easier method?
many thanks
13/02/2012 21:55:07
probley going to buy the coper to make the tich boiler tonight and was jus wonder is copper copper the stuff im looking a c106 grade would this be sutible i know you can buy boiler kits but funds wont allow this so do it this way i can spread out the cost
thanks mikey
Thread: 3 - Jaw chuck on Clarke 300 lathe / cutting speeds for brass / steel.
12/02/2012 22:57:05
hi chris go to your local machine mart if your in the uk and they will be able to get them for you you may be able to get them if you phone there help line or service centres
Tel: 0871 410 1270
thats the contact details for the spare part centre
hope to help mikey
Thread: Metal work at schools
11/02/2012 21:49:39
hi all i left school in 2004 not that many years ago, as of the last few years in school i was the only person who had touched the lathes in many years. i for me think what was the road in to engineering apart from familey was the fact of 'work experience' i did 2 weeks in a local engineering workshop this then led me to get a job before i left school so the same week i was straight in to work, sadley the company went bankrupt but i learnt basic cnc programing and manual work one thing i will say is at school as others have said there was not one teacher that had used a lathe in say 10+ years i now only do it as a hobby i went down the automotive route and now have qulifacations in being a mechanic. i think if when work experience allows pick an engineering company if you can as this may be what opens the door to the engineering career that is wanted
Thread: getting there..... now for the slide valves
07/02/2012 23:26:06
hi mikew just building a tich the chassis is getting there jus the valves and nuts to make now oh and the steam tees then should be running on air =)
mike
07/02/2012 13:27:35
thanks guys
mike
07/02/2012 03:16:03
hi all when machining the slide valves is it the nut that holds them against the cylinder face? i will be ordering them this week just would like to know before i start the machining as im going to have to change a few measurements due to the previous builders positioning off the steam ports.
thanks to you all once again much obliged
Thread: Not a question more of an introduction
04/02/2012 22:35:25
welcome to the forum madmike
mike
Edited By michael burton 1 on 04/02/2012 22:35:45
Thread: graphite yarn no thanks o-rings yes please
04/02/2012 22:13:49
o rings in slight drag a hiss hiss sound when moving along the floor and rolls nicley so mayby i cracked it, i did test and trim approch as the previous builder of the model machined so many parts at differnt sizes to each other etc. this was the only way to ensure that they both would do the job
many thany thanks for the replys
03/02/2012 22:50:34
i was thinking the trial and error method il machine the groves till theres a ittle compresson i guess ike you would have if you coverd one end of a outlet on a air ram?
wiv the graphite yarn pistons that are in the model at the mo when a steam port is coverd you get a restiance and if you slightly leave the port uncovered a smidge u get a nice sucking blowing sound mayby this is right already hmmmm whats your opinions on this?
sorry if this sounds stupid but in terms of loco building im a complete newbie iv built osscilaters an open crank 2 stroke demo model to my own crankcase deign and other parts for other hobbies and a battery loco built out of a 3 1/2 in gauge tich chasiss but this is my first proper venture down the steam avenue so am learning as i go on so all help is greatffuy received
