Here is a list of all the postings S.D.L. has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco WM280V-F Gearbox |
05/07/2020 18:33:40 |
And the last part of Barry's journey back to a working lathe. After final confirmation that the gear selectors were engaged and working properlye gasket sealing compound was applied and the rear cover panel refitted. Where the missing screw had been (original hole filled with sealer) I managed to extend the tapped portion of what was left in the casting and fitted longer screws which gave some purchase. Gearbox and shaft taper shear pins refitted. Note table used for changing gear wheels. Corner removed to allow door to open, override block top right engages with safety cut out switch for testing, and banjo rests on the extended piece when pivoted forward. Final photo shows everything panelled up and ready for testing.
Posted by Steve for Barry
04/07/2020 17:29:32 |
Next Installment
Refitting the front panel. I had removed the three knobs to give them a good clean. Each knob has TWO balls, a spring and a tensioning grub screw so care must be taken not to lose any part. These were removed before driving out the roll pins securing the knobs to their shafts. I used some M4 nuts and bolts in place of the roll pins to position the gear selectors such that the selector arms would line up with the gear trains. The selectors were very loose, so to keep them vertical I inserted some 15mm lengths of bamboo skewer and slightly compressed them against the front panel with bolts screwed by hand into the tensioning grub screw holes. This method worked well. The technique I found worked was once the arms were vertical it eventually becomes possible to get the actuating cams to engage whilst pivoting the front panel against the bottom of the gearbox housing. Full engagement could be confirmed by looking in a mirror positioned behind the gearbox (as in the last photo) then moving the selector knobs in both directions. Once comfortable with the positioning it was a matter of applying gasket compound to the previously cleaned surface of the gearbox, repositioning it in front of the mirror and repeating the pivoting motion and confirming again that the selectors worked correctly before refitting and tightening the 5 front panel retaining bolts.
Loaded by Steve for Barry
Thread: What is this cutter used for? |
04/07/2020 17:19:04 |
Revers sice chamfering tool on CNC. for deburring the far side?
steve |
04/07/2020 10:01:46 |
Posted by Howard Lewis on 03/07/2020 19:08:25:
So soon, you will be up and running again, and better than when the machine left then factory. Good work! Howard Considering Barry did a conversion to three phase motor and vfd that was covered in MEW. Before this happened it will be a far better lathe than when new and shipped. Steve |
03/07/2020 18:29:29 |
Next Installment
Although I had read it elsewhere, I was surprised at just how ineffective the gearbox drain plug was. It is around 20mm ABOVE the level of the inner casting. This results in a large amount of residual oil cascading out when the front panel is removed. Someone had suggested adding a drain hole at a more appropriate position, so that formed part of my project. I decided to fit a magnetic drain plug and sourced one from eBay. It required an M12 x 1.5mm tapped hole. After some deliberation I drilled a pilot hole 19mm up from the bottom of the front cover in the mill. The panel was turned over and a 14mm mill, centred on the previously located pilot hole, used to produce a clearance for the M12 tap. The panel was again turned face up and a 10.5mm tapping hole drilled. The hole was then tapped perfectly square whilst still in the mill. The finish on the front panel although adequate for a panel face was not deemed good enough to guarantee a good tight fit when the magnetic drain plug crush washer was compressed, so a light skim with a 20mm end mill improved that area. I used a 20mm ‘Q’ cutter to produce the hole in the front aluminium cover plate, the centre of which had also been located using the pilot hole.. The last photo shows the reworked gear to the left on its keyway and the now smooth triple gear assembly on its shaft & keyway Posted by Steve for Barry
03/07/2020 18:27:29 |
Posted by Tony Pratt 1 on 02/07/2020 19:46:19:
I have a Warco lathe & sorry to say this type of thing is par for the course, a first year apprentice wouldn't do some of the things I have seen on my lathe. snip Tony Reminds me of the old 80/20 rule, get 80% of a broduct for 20% of the cost, its that detail that costs the money,
Steve
02/07/2020 18:36:32 |
Making the missing gear
Whilst waiting for the outstanding gear to arrive it dawned on me that there was a perfectly serviceable gear on the old triple gear assembly with the correct number of teeth. It would require removal of two of the three gears from the shaft, boring and reaming the hole to 16mm diameter then milling to the correct overall width. The lathe was perfectly useable without the gear box, but I did miss the power fed when boring the hole out. These stages are shown in the photographs. Although it looks otherwise, the shot where the gear is being milled is actually ‘finger nail’ smooth and not scored across the diameter. There only remained the lack of a keyway …. At last, an opportunity to use a broaching tool inherited from a former club member’s workshop for the first time. After a bit of research I found Michael Cox’s article on making a simple internal keyway broach (MEW Issue 184, page 47) and set about modifying a length of 16mm silver steel. The broaching tool travel was pretty limited so the tool had to be customised. I milled a 4mm slot into which I set a length of 4mm square HSS tool steel. I didn’t grind the end, but used it as purchased. An M3 grub screw approximately 20mm from the end of the tool steel is used to progressively advance the cutter into the work in minute increments. After a considerable amount of time, copious amounts of cutting fluid and two blisters, the task was completed. It was slow, hard work but well worth the effort in the end.
Posted by steve for Barry
01/07/2020 21:16:52 |
Hi Next set of Photos and text from Barry In order to disassemble the gear trains I manufactured a simple gear puller as shown for the roller bearings. It may be recalled that when I complained about the stiffness in the gearbox Warco (who had the lathe back for rectification under Warranty) attributed it to ‘swarf’ under the gear selector knob. As can be clearly seen that was NOT the case at all. Someone at the factory in China had obviously struggled to get the triple gear assembly to smoothly slide along the gear shaft and had resorted to agricultural means of persuasion in attempts at achieving free movement! I was not impressed with this at all and will let the photographs tell the tale. It was obvious that the key had to be replaced. The original key was wedged in place so I had to mill it out. As can be seen in one photograph there were several nicks along the edge of the keyway itself which I dressed prior to fitting the new key. I purchased a 4mm square length of keyway bar from Simply Bearings, cut to length and ground the ends to suit. Fitting this was not straightforward and I sensed that the key slot itself was slightly offset and found the new triple gear assembly was binding along the shaft. I resolved this by lightly scraping the shaft either side of the key with the square end of a small flat file. Eventually this resulted in a smooth sliding action along the keyway. Posted for Barry by Steve.
30/06/2020 22:16:34 |
Hi Barry has been busy stripping his gearbox down and repairing and this is the first in a series of posts showing the cause and the repair.
At last I’m able to finish this Gearbox strip and rebuild report. Although I had two gears from Warco (the double and triple gear assemblies) the third gear was on a 12 week back order from China. THEN lockdown arrived and things slowed considerably, so I decided to get as much done as possible prior to the third gear arriving. First surprise, on removing the Gearbox from the lathe body, was when I was removing the rear cover to gain access. After removing 7 of what should have been 10 screws I realise that there was NO screw fitted at the second location in from the left on the bottom row, and the hole had been filled with sealer! When the sealant was removed it was apparent that the hole had been drilled way off centre leaving little thread in the casting. Inboard of the top row of holes there was a burn mark clearly visible on the rear cover plate. When released it was obvious that the inner face of the cover plate had been ground down – to give clearance between the cover plate and one of the gears! See photos showing the teeth of the larger gear clearly above the ground rear face of the casting…………! I am still unable to post photos onto this Forum for some odd reason, so Steve has again kindly stepped in to post on my behalf.
Posed by Steve Larner for Barry
Thread: Using large dies |
19/05/2020 11:10:35 |
Posted by Tim Hammond on 19/05/2020 10:18:45:
Posted by Brian Oldford on 19/05/2020 09:04:07:
Posted by Ian Parkin on 18/05/2020 20:27:03:
. . . . . the large dies i have are all hex nut type so i generally use a big pair of stiltsons to run them down . . . . . . So far as I'm concerned die-nuts as you describe are purely for cleaning up slightly damaged or rusty threads, not cutting them from scratch. I was always taught this, but I've noticed on several videos I've watched on YouTube, the Americans seem to have proper thread-cutting dies in a hexagon shape. Has anyone any further information on this?
The McMaster website shows Hex Dies as thread repair as per UK practice but they do show the conversion holder in the clip below. Would be easy to mage similar at home Steve
Thread: Yet another parting-off question |
17/05/2020 07:49:29 |
Have you checked that the insert hasnt chipped / worn on one side leading it to wander. Its better with power feed you need to cut not rub.
Steve |
Thread: lathe and other modeling equipment |
11/05/2020 16:42:42 |
A quick search advanced search on Ebay for Viceroy TDS shows prices of 450 - 500 pounds. I would try to sell on this site first and / or here **LINK** Steve
Thread: Metric taps and dies - and pitches |
16/04/2020 13:23:29 |
Posted by Perko7 on 16/04/2020 12:14:25:
As far as I can work out, when metric threads are nominated simply by (say) M10 with no additional information, it refers to coarse thread pitch which in this case is 1.5mm. If a fine pitch thread is called for then it is nominated by M10 - 1.25 meaning a thread pitch of 1.25mm. In general, most of the commercially available metric screw threads less than M8 are coarse. The reason for having differing pitches is hard to identify, but the Nord-Lock website has a useful summary here: **LINK** which might help. I suspect that in the smaller sizes, the tolerances required for fine thread cannot be easily maintained in manufacture so the coarse thread prevails. I'm happy to be enlightened by anyone with more accurate information. What you have worked out is correct M? with no further info is coarse used to be standard practice to only put pitch if non coarse although sum machine shops ask for pitch it in all cases now days.
Steve |
Thread: Paint for an Traction engine |
09/04/2020 12:14:34 |
Posted by MichaelR on 08/04/2020 18:59:39:
Steve The paint was applied direct onto steel after cleaning bright with abrasive cloth. Link for application instructions. MichaelR Thanks for the Info
Steve |
08/04/2020 16:16:16 |
Posted by MichaelR on 08/04/2020 14:31:34:
I used Black Friar High Heat Resistant Matt Black paint on my D&NY smoke box which is good for 600C, the paint has stood up well over many years of steaming. MichaelR. Was that direct onto steel or with special primer?
Nice Engine
Steve |
Thread: Threading and the tables |
01/04/2020 20:05:08 |
From memory when we used to use sandvik internal boring bars the shim under the insert has to be different angles for different TPI inserts, there were at least 3 angles maybe more. I suspect for the feed in to be to theory dimension the angle needs to be correct. Steve |
31/03/2020 12:42:12 |
Can you post a picture of the diagram you are using?
Steve
Thread: Coronavirus |
27/03/2020 16:51:25 |
Posted by Bob Mc on 27/03/2020 15:48:15:
Seeing one result of coronavirus is that there are very few aircraft flying...could it be that the good weather we are getting just lately has anything to do with it? Or have I spoke too soon!. Strange I thought their was bad weather before the Jet age.
Steve |
Thread: o-ring groove in plate |
27/03/2020 16:49:15 |
PH Horn do them but they are Spendy.
Steve |
Thread: EMI from electric shavers etc |
25/03/2020 06:55:20 |
Posted by Martin Kyte on 24/03/2020 22:31:30:
Can anyone remember what desperate Dan used for shaving? Martin Was he the one who hit them in with a hammer and chewed them off inside or was that an old song?🤔😀 Steve |
