Member postings for Thor 🇳🇴
Here is a list of all the postings Thor 🇳🇴 has made in our forums. Click on a thread name to jump to the thread.
Thread: Stuart V10
29/01/2013 06:05:37
Hi Berra,
may be this ***LINK*** can be of help?
Thor
Thread: Steam port spacing
25/01/2013 18:14:25
Hi Stuart,
steam engine slide valves often had some movement past the port (lead and lap). You can read a bit about this here, here or here.This will provide extra time for steam to expand and move the piston. If you have access to Model Engineer March 21. 1957 p. 421-422 E.T. Westbury discusses simple slide valve engines.
Thor
Edited By Thor on 25/01/2013 18:14:49
Edited By Thor on 25/01/2013 18:33:29
Thread: Warco WM18 miller problem
25/01/2013 05:52:35
Hi David,
I have a milling machine similiar to Weiss WMD25, ta bit smaller than your WM18, and I have not experienced any of the problems you describe.
Thor
Thread: The first steam engine you built
23/01/2013 05:23:10
Hi Brandon,
If you don't want to spend a lot of money on a kit with castings, Phil's suggestion of building one of Elmer Verburg's engine is good advice. Elmer's engines are made from stock materials, some are easy to build, others a bit more advanced. He even has one with a generator (#40). Click on the link supplied above and download one of Elmer's engines.
Thor
Thread: Carfbide Brazing Help Please
21/01/2013 05:25:46
Hi Rick,
I have tried to silver solder tungsten carbide onto steel. I used uncoated carbide and used a dry diamond hone on the underside of the carbide piece and cleaned and fluxed before heating. The carbide piece is still firmly attached to the steel.
Thor
Thread: Rechargeable Cells
19/01/2013 06:04:10
Hi Martin W,
I have the same experience as you with NiMH cells. I use cells that has a low self discharge (Varta) and the last much longer that cheap Ni-MH cells, although that don't have as high a capacity as Neil mentions.
Thor
Thread: Where do I find a roller Filing rest for a lathe?
16/01/2013 18:50:26
Hi Hilmar
Here is one website with pictures of a filing rest. Dean describes how he made one for his Taig lathe. Here is antother.
Thor
Thread: Cool down a mini-mill motor.
15/01/2013 18:09:07
Hi Johan,
Your solution to the cooling problem of the mini-mill is very nice. Is the extracter fan very noisy?
Thor
Thread: ME tapping dril sizes
14/01/2013 05:26:18
Have a look at Harold Hall's website.
Thor
Thread: Carbide insert Dovetail Milling Cutter
11/01/2013 05:37:41
Hi Johan,
your dovetail cutter looks great.
Regrads Thor
Thread: Paddleduck
09/01/2013 18:36:11
Hi Stuart,
May be these links can give you some guidance?
Dean has a description of how he built a governor.
Here you will find drawings and pictures of a Watt-style governor.
Muncaster steam engine governor.
Regards Thor
Edited By Thor on 09/01/2013 18:44:28
Thread: Parallel turning on a Myford ml4
06/01/2013 07:58:47
Hi David
your recommended way of setting up puzzles me. In't it the opposite of what Harold Hall recommends?
Regards Thor
Thread: Black hole
04/01/2013 04:51:39
Hi Bill
my small workshop sure has a big black hole in the floor. If anything small drops to the floor, it is gone! Or may be my eyes are not as good as they used to be?
Thor
Thread: Combined Mill/Lathe
03/01/2013 05:38:44
The round column of the Emco mill has a key that keeps the head positioned. If yoy rotate the head, the column rotates with it.
Regards Thor
23/12/2012 19:51:55
Hi Johan
If you want to make your own dovetail cutter with a carbide tip this site may give you some info. I made one a couple of years ago, it worked although I had to take fine cuts. It acts like a kind of flycutter.
Thor
Thread: Introduction
23/12/2012 06:11:51
Hi Lee
If you think of HSS tool making as a black art why not buy or make a tangential toolholder? It is very easy to grind the HSS tool bits for these holders. If you buy one a grinding jig is usually supplied. It is not difficult to make your own holder and grinding jig.
Thor
Thread: A Pleasant Christmas
22/12/2012 06:09:02
Thanks Bob, same to you
Thor
Thread: Chain driven cams ?
15/12/2012 14:43:05
Hi Siddley,
I found these by googling miniature chains, may be you can use them? Seems they have with pitch from 0.1475in. to 0.375.
If you don't want to make gears for your model engine, it is possible to buy them.
Regards Thor
Thread: My New Warco VMC Turret Mill
01/11/2012 10:44:29
Hi Chris,
Congratulations with your new mill. Hope your helper didn't suffer any permanent injury. Might have been wiser to wait for the cavalry instead of lifting it manually?
I got my new mill a couple of months ago, not as heavy as yours so it was easy to get it off the pallet. I moved the crate over my lawn by rolling it on a couple of broomstick pieces. With the help of a friend it was moved into the workshop (no injuries).
Regards Thor
Edited By Thor on 01/11/2012 10:45:58
Thread: Tilting table getting there.
26/10/2012 05:41:26
Hi Raymond,
The table looks nice, I like the clamps you made,
Thor
