Member postings for Adrian Hemmings
Here is a list of all the postings Adrian Hemmings has made in our forums. Click on a thread name to jump to the thread.
Thread: rudy,s model steam tractor
24/09/2022 10:22:24
can anyone help me with the building of rudy,s model steam tractor . i was look up info on bypass valve and cam across lots of photo,s of someone building this . not sure which forum site it was on . look forward to hearing from anyone with info
Thread: pressure gauge
23/09/2022 15:39:02
could any one help me out , i have just bought a 0-80 psi 1 inch dia pressure gauge with 2.36mm dia nipple end with 1.62 mm dia bore , how do you attach 1/8 inch dia copper pipe to this
Thread: machinery covers
12/02/2014 17:35:18
hello could anyone tell me what and where i can obtain machinery covers to help combat the damp problem in my workshop .thanks ade
Thread: index
31/08/2011 17:21:04
could any one tell me which volume of model engineer magazine started to have the index of the previous volumes in .thanks ade
Thread: clayton steam lorry - help
08/08/2011 11:03:29
i am a newcomer to the art of model engineering am in the process of starting to build a 2 inch scale clayton steam lorry.have some drawings and model engineer mags explaining the build which seam a bit misleading at times.need to know how it all works, different functions of items such as boiler,safety ,blower,water valves,injectors,hand pump,pressure gauge and water tank ,etc.how they inter connect with each other.also how to get started with all the controls,water into the boiler,cab reverser arrangement and all other levers to make the lorry move.is they any books or other publications that anyone knows of that will help me out in the building my clayton steam lorry. look forward to hearing from anyone. thanks ade
Thread: clayton steam wagon
08/08/2011 10:38:51
donald thanks for the reply ,i have the piping layout that in model enginers mag number 3603 i also have drawing m35 sheet 9 which has boiler fittings, pump etc and piping layout on.
Thread: help needed
07/08/2011 19:41:46
hello i want to fit a dog-clutch to my 2 inch scale clayton stem lorry .i have been told that information about this idea is in one of the volumes of model engineer mags .does any one which volume it was in. thanks ade
02/08/2011 20:17:23
donald my clayton has the water pump fitted into the tank behind cab, does the pipe from pump go to one of the clack connectors on boiler ,and im i right in thinking the other connector out of top of tank goes to the feedclack / bypass which is fitted to boiler side .also where does the pipe from bottom of water gauge go to . thanks ade
02/08/2011 10:35:43
i am building a 2 inch clayton steam wagon at the moment .is there any one who has built or is building a clayton can help me out with a few questions.i am a novice model engineering builder and any help would be appreciated.thanks ade
10/03/2011 19:06:51
any help and information would be appreciated to track down castings and drawings to help build a clayton 2 inch scale undertype steam wagon. look forward to hearing from anyone. thanks ade
