Here is a list of all the postings SteveM has made in our forums. Click on a thread name to jump to the thread.
Thread: Amazing Engineering Video |
21/08/2021 13:35:57 |
You are welcome Roy, and I couldn't agree more. |
21/08/2021 13:03:01 |
I recently stumbled across this astonishingly beautiful animation of a Gnome 9-B2 Monosoupape Assembly. I think anyone with even a passing interest in engineering will find it absolutely fascinating. |
Thread: Can this motor be reversed? |
09/08/2018 23:05:50 |
Posted by John Rudd on 09/08/2018 15:00:12: You are half way there..... Follow the wires from the Start cap, this will take you to the Start winding, then just swap over... Many thanks John, that was just what I needed. The job was done and the rotation reversed. Made me ridiculously happy! Just to explain fully in case anybody else has a similar motor, this is what I found when I removed the back end.
The yellow and blue wires from the start capacitor were traced to the posts subtly red arrowed in the picture. Many thanks to all who chipped in with advice!
09/08/2018 14:01:24 |
Thanks for the replies, and sorry, perhaps I should have added some more information in the original post. It's a 4-pole induction motor so circa 1450 rpm. 1000w. Single phase. Sadly there is no handy wiring diagram anywhere, but at least the wires are different colours! I'm pretty sure the start capacitor is the black 100 μF and the run is the white 10 μF. I know it will work beautifully because my last mixer was an identical Benford. It worked just fine with a similar setup for more than a decade and I would have it still but some passing vermin took a fancy to it while I was at work. I was really hoping that somebody would have encountered the same wiring arrangement and the solution would be as simple as 'swap the black wire with the yellow'! Edited By SteveM on 09/08/2018 14:11:30 |
09/08/2018 11:38:11 |
Hi all, I want to use this ex floor polisher motor for my concrete mixer, an old Benford. The motor would be perfect if only it could be made to turn in the right direction. Before I am tempted to switch some connections on the start circuit that could kill me or the motor, can anyone tell me if the direction of rotation can be changed easily - or has it been fiendishly designed to make it difficult? Edited By SteveM on 09/08/2018 11:39:31 |
Thread: Blow torch recomendations |
03/02/2018 00:28:23 |
There are a number of brazing videos on on YouTube posted by a guy who calls his channel 'Xynudu' (AKA Rob) He uses and recommends a Bullfinch 4100 and this is one of his videos: The torch looks like a good piece of kit and I've promised myself one for this years birthday present
Edited By SteveM on 03/02/2018 00:29:52 |
Thread: Vertex 6" rotary table |
21/01/2018 10:26:11 |
Hi John, Improving the vertex rotary table Hope that helps |
Thread: Power File |
24/07/2017 21:24:51 |
Another positive vote for the powerfile from me. Useful for so many things I wouldn't be without it now. Mine is the B&D 900E model from Amazon, used often and no belt problems. That Silverline is less powerful than the B&D but a lot smaller and more versatile, and with a good level of feedback. For £30 I reckon it doesn't have to be useful very often to be worth it. |
Thread: Small Milling machine |
25/03/2017 21:08:52 |
The Downham (AKA Elliott or Gate) Jig Borer Miller is a brilliant workshop milling machine with a tiny footprint. I think it's often disregarded as a serious milling machine just because of it's jig boring capability. But it was designed to be capable of milling and indeed it mills beautifully, being capable of ploughing some deep furrows in steel if needs be. And the handwheels on the Mark 3 are a joy to use. |
Thread: Optical chucks |
30/01/2017 22:36:40 |
Stefan Gotteswinter shared an excellent video on YouTube about the design and construction of an optical microscope. Like all his videos it's very interesting and well worth watching. |
Thread: Todays update from Bodgers Lodge |
25/01/2017 20:34:01 |
Interesting job indeed John. I've no doubt that your welded solution will have the strength to last the course, but I wonder if the shape of the vanes may cause a problem. It's looks from your picture as if the original impeller has hydrodynamically shaped vanes with rounded ends which will shift the fluid efficiently. Having said that it also looks as if the surfaces have been left rough from the casting. |
Thread: Inverter motor package |
09/12/2016 09:05:50 |
A guy called Gavin Oseman regularly advertises on the Home Workshop site. He sells a lot of inverters and sometimes inverter/motor packages. He only has inverters advertised at the moment but it could be worth a call to see if he has any motors. This link will bring up his ads: Gavin Oseman Ads
Thread: Safety and superglue chucks |
30/11/2016 20:49:56 |
Posted by pgk pgk on 30/11/2016 13:06:58:
".... There are times when you want to bury your pants rather than put them in the laundry." That made me laugh. I really wish there was a 'This was really funny' button.
Thread: dividing head /indexing |
16/11/2016 00:57:23 |
Hi Mark, The spindle is a bit small with only MT1. But it comes with a built in 24-hole indexing function!
The tailstock is also for sale... Steve |
Thread: Which Clinometer? |
06/11/2016 22:07:27 |
Thanks for posting that Michael. They certainly didn't go overboard with instruction manuals in those days! Steve |
06/11/2016 12:01:16 |
Peter - I like that one too! Builder - I haven't got anything in particular to measure and I know that one of the dinky digital devices will do all the measuring and fit everywhere I need. I want something that'll be useful for a number of things occasionally, but in particular I want one of these because it's a beautiful tool. Sad but true. Michael - thanks for the tip, I hadn't seen one of those. Now it is also on the list! Hacksaw - PM sent. Also nice username. Rik - I agree almost word for word with both paragraphs! Steve |
Thread: BBC 4 this eve. |
06/11/2016 00:57:24 |
No problem Rik. I missed the first tip, perhaps just as wel from your comment. But I've looked at the programme info from the BBC site and they make it sound quite interesting, so you have to be forgiven for that Haven't yet seen the Precision programmes, but I will soon. Unless you warn me off them! Steve |
06/11/2016 00:39:28 |
I quite fancy putting a clinometer on my 'crikey I need one of those' list. Not one of the new fangled digital things (yet) but one of the qualty instruments from yesteryear. I've narrowed it down to two models like the ones pictured, both made by Watts/Hilger Watts/Hall Watts or even Taylor Hobson. Do any of you have any interesting experience with these devices? Which would be the most accurate of the two? And what are the pros and cons of each? Edited By SteveM on 06/11/2016 00:40:53 |
Thread: Defunct Hard drives |
05/11/2016 18:17:35 |
It seems they (can) make nice little grinders. This is one of many on YouTube: Grinder I think this is one of the motor controllers: Controller which somehow they can make and deliver to you from halfway around the world for less than a quid. Add any 12v(ish) DC power cource and you're away! Steve |
01/11/2016 21:10:17 |
Thanks for the tip Rik, it looks interesting. Have a question though... what was the last programme you tipped? Steve |
