Vertex 6" rotary table
john fletcher 121/01/2018 10:05:11
893 forum posts
Help needed to reassemble and adjust my rotary table. Some time ago I think there was a detailed article on the doe's and don'ts when reassembling these table. John
SteveM21/01/2018 10:26:11
64 forum posts
16 photos
Hi John,
Stefan Gotteswinter has a very interesting series of videos on an identical table which should be linked below. Although to be fair pretty much everything he outputs is interesting.
Improving the vertex rotary table
Hope that helps
Steve
Howard Lewis21/01/2018 15:50:52
7227 forum posts
21 photos
Just DON'T trust the chart that comes with it! It contains errors and omissions, (Eight by my count; never checked beyond 100 divisions).
Certainly the one for 13 divisions is wrong (as I found to my cost!) Some of the errors are probably from reading a Zero as a 6 or an 8.
If in ANY doubt, DO check by calculating!
john fletcher 121/01/2018 16:08:29
893 forum posts
Thank you Steve, youtube is my next port of all. Also thank you Howard annoying when you finish up with either a thin tooth or one missing altogether. I'm in the process of an Arduino conversion. Hopefully no more counting the turns, then the phone rings, I have little black board but my memory is not what it used to be. John
