Thread: Making parting off tools |
04/07/2022 19:05:26 |
Posted by Rowan Sylvester-Bradley on 04/07/2022 17:25:42:
...make a tool from 8mm square HSS and clamp it in the tool holder with no shims or anything, then the top of it is about at the right centre height. That's the wrong approach; grind the tool to whatever shape is required and add shims to get the tool on centre height. With regards to parting off tools one can buy 1/16" x 5/16" HSS blanks from Arc. I use similar blades on my repetition lathe: With regards to insert parting tools i use one on my centre lathe. I found that they chatter badly if the feedrate is too low. I part off at several hundred rpm upwards and use a minimum feedrate of 4 thoui/rev, more usually 6 or 8 thou/ rev. I'm also in the part off using power crossfeed group. Andrew |
Thread: Lathe cross slide travel question |
04/07/2022 14:41:02 |
The cross slide determines the total travel, but where that travel is relative to the work is not well defined, and in practise is set mainly by the position of the tool. You may well have to swap between a LH boring bar for the rim and a RH boring bar and normal knife tool for the centre boss and bore. That is what I had to do on my 16" flywheel on a 13" swing lathe (18" swing in the gap) with a cross slide travel of 7.5": Andrew |
Thread: Dart Reverser nut |
03/07/2022 21:23:45 |
Posted by SillyOldDuffer on 03/07/2022 16:49:15:
...the part doesn't look hard to make from solid to me! I didn't say it was hard, or difficult, but a PITA. Making it from solid means that 3 three points have to be marked out and then picked up on in the 4-jaw chuck. Presumably the 3/16" spigots need to be concentric, so need to be picked up to a high degree of accuracy. Drilling a hole and silver soldering in a pin is simpler and guarantees concentricity. A sliver soldered pin will be as strong as solid. Andrew |
03/07/2022 11:25:11 |
It would be a right royal PITA to set up and machine the three spigots in the correct places. I would machine the basic block to size and then drill through for the 3/16" spigots, plus a blind hole for the 1/8" spigot. Then silver solder in a length of rod for the 3/16" spigots and a shorter one for the 1/8" spigot. If it was felt necessary to stick with a Whitworth thread form I would screwcut it rather than try and find a LH tap. Alternatively I would make the thread M10 for which LH taps are readily available, albeit at a price. Andrew |
Thread: Simple Quiz... Missing Weight |
01/07/2022 12:57:18 |
Roy, I'm afraid you missed my point. The implication is that the set of new weights needs to be able to weigh from 1 ounce to 4 pounds in 1 ounce steps. But that is not explicitly stated. Instead it says anything from 1 ounce to 4 lbs, in which case 1.5 ounces is valid, as would be 1.25 ounces or 1.75 ounces, in fact an infinite number of weights. Andrew |
01/07/2022 12:13:44 |
The problem is incompletely specified, what about weighing 1.5 ounces? Andrew |
Thread: Quick change tool post ? |
01/07/2022 12:10:33 |
Posted by Hopper on 01/07/2022 07:33:07:
..people get hung up on thinking their tool point needs to be dead on centre to the thou...
Oh my word, an outbreak of practical engineering. I don't sweat over tool height, just line up by eye against a tailstock centre. A few thou here and there makes little difference. The smaller the work diameter the more accurate the tool height should be, but I rarely turn much under 1/4" on the centre lathe. Probably 75% of my turning is done with two tools, a CCMT insert and a parting off tool. For these tools I keep the appropriate shims with the holders. Boring bars, profiling and HSS specials are shimmed as needed. Doesn't take long and specials might only be used once, so no point in having a dedicated holder. I tend to run my lathe to the limits in terms of speeds, DOC and feedrates, so prefer the better rigidity of a 4-way toolpost. Just to show that I'm not completely anti QC toolholders I do sometimes use a Dickson QC toolpost, as it is what the hydraulic copy unit came fitted with: Note the radial spline on the left where the 4-way toolpost sits. It allows repeatable indexing of the normal toolpost every 9°; another reason I wouldn't change to a QC toolpost. Andrew |
30/06/2022 16:33:04 |
Posted by Rich2502 on 30/06/2022 15:14:13:
What quick change tool post would you recommend for an Atlas 12" lathe? I wouldn't, I use the 4-way toolpost that came with the lathe. My lathe is 12" x 40" so similar size. Andrew |
Thread: Lifting milling vice off mill table |
30/06/2022 16:29:54 |
I don't use cutting oil or tenons on the vice, ergo no problem. Andrew |
Thread: Warco VM12 |
29/06/2022 20:22:03 |
Posted by Peter Russell 4 on 29/06/2022 19:43:11:
Why use a nylon gear at this point... Cost; a moulded nylon gear is much cheaper to produce than cut metal gears. Andrew |
Thread: Single phase milling machine recommendations |
27/06/2022 22:35:14 |
I'd be looking for a new sparky. It may well be far to expensive to connect a 3-phase supply but I can't see the distance being a problem.There may well be 3-phase in the street anyway, so the distance to 3-phase would be a lot shorter than to the sub-station. That's what I have, a true 3-phase supply connected to the 3-phase cable buried the other side of the street. The use of a VFD gives you the advantages of a 3-phase motor even though only a single phase supply is available. Andrew |
Thread: Amadeal VM25L R8 Milling Machine |
24/06/2022 11:53:48 |
Posted by Howard Lewis on 24/06/2022 01:25:10:
Alignment time is less than 5 minutes, compared to possibly 20 minutes of winding to and fro, tapping to align... It takes me significantly less than 5 minutes to align my vice just using a DTI. Although my machine vice has slots milled underneath I don't use alignment blocks, as the vice gets moved between three different milling machines. Although all T-slots are nominally 5/8" they vary slightly from machine to machine. Andrew |
Thread: How to achieve a clean edge when shortening small screws using a Dremel Cut off Blade Dremel EZ S |
21/06/2022 21:35:05 |
Make a plate of the same thickness as the wanted screw length. Drill and tap 8BA holes, insert screws and file to length. The end of the screw is automatically cleaned when the screw is unscrewed. Andrew |
Thread: 13G? |
16/06/2022 10:32:06 |
Posted by Hopper on 16/06/2022 06:36:18:
.....entirely rational metric system! The metric system is not rational but arbitrary, the same as any other thread system (except possibly BA which is based on a geometric sequence). Before, and during, WWII the French and German metric thread systems were different below 6mm OD. For instance the French used M3x0.6 rather than the international standard 0.5mm pitch. Use of M3x0.6 is still part of the JIS system in Japan, as I discovered when I made some new parts for a guitar for a friend of a friend last year. Andrew |
16/06/2022 10:00:22 |
The OP doesn't say the gauge is 13tpi. The letter G usually refers to BSPP threads. Sometimes the nominal imperial size is approximated in millimetres. So I expect the gauge is for 1/2" BSPP. May be the OP can tell us if the gauge is 14tpi? Andrew |
Thread: Engine scale |
15/06/2022 22:03:53 |
Posted by Harry Wilkes on 15/06/2022 16:47:48:
...I believe at this moment you cannot tow with electric car Not true. In autumn 2019 a mate and I took our gliders down to Talgarth (in the Brecon Beacons) for a few days of ridge running. My mate has a Tesla and he towed his 18m glider from Bideford to Talgarth, about 75 miles, on around half full charge. Andrew |
Thread: cutting a square end on a round shaft? |
14/06/2022 20:16:50 |
Posted by SillyOldDuffer on 13/06/2022 16:17:53:
Is there a difference? Two orders of magnitude. Andrew |
13/06/2022 15:51:45 |
A few tens of thou, not a few tenths. Andrew |
13/06/2022 11:44:38 |
Posted by Hopper on 13/06/2022 11:33:47:
Filing rollers that you fitted to the lathe toolpost while holding the job in the lathe chuck...
That opens another can of worms. Should the rollers be hardened or left soft? Same applies to filing buttons, hard or soft? Andrew |
13/06/2022 10:56:45 |
Turn down the end of the bar to the required diagonal dimension, minus a few tens of thou. Then file the flats. Since the starting diameter is slightly smaller than theoretically correct, a small chamfer should be left on each corner. Keeping the chamfers the same size, and parallel, will ensure that the flats are just that, flat and parallel to the opposite face. Shouldn't take more than a few minutes. Andrew |
