Here is a list of all the postings paul rayner has made in our forums. Click on a thread name to jump to the thread.
Thread: Muncaster's Simple Entablature Engine |
26/10/2019 13:50:40 |
Jason I'm waiting of some reamers etc to progress, so I thought I would make a start on some studding for the main bearings. A couple of stupid questions if I may 1) did you use washers? as it looks as though you have when you expand the picture but they look painted or is it just a shadow from the camera light 2) How did you tighten the nuts up without chewing up the paint???? 3) did you locktite the studs in to a set depth regards Paul |
24/10/2019 20:43:24 |
Jason I'm not brave enough to do it that way on the mill with such small taps. I do however with bigger ones M6 + as a matter of interest I thought I would "have a go" at removing that broken tap. I drilled through from the other side and to my surprise when the drill met the tap I measured it and the tap was only 3.5mm in the work. I then got a small punch? drift? one of them round bar things with a flat end on lightly tapped a few times each side and bugger me it came out! So I need not have made another bearing block ah well it's all fun eh regards Paul |
23/10/2019 18:36:30 |
I will take it on board to go up 0.1 next time. I called at the local suppliers on my travels today and picked up an Osbourn 1st tap and did the rest of the holes a treet. Geoff. it was a blind hole but, I like you on small stuff hold it in my hand, but this is, to be honest, is where I think I went wrong, I used a small tap wrench instead of one of those pin chuck types. lesson learned regards Paul |
22/10/2019 20:50:25 |
it is, I have no Ali in my scrap box. To be honest it's not something I use. besides it's expensive Last time I looked at the price of some, I nearly had a heart attack. There's a steel stock holder local to me and if you buy standard stock lengths it's dirt cheap so my efforts are all in steel. Paul |
22/10/2019 20:32:08 |
this is a bit of a bugger-
I was tapping the first hole in the lower bearing housing, A brand new presto tap as well I blame Jason the fixings are too small. M10 are much more manageable. |
Thread: Tom Senior M1 Vertical Head Drawing |
12/10/2019 08:40:26 |
If I remember rightly the horizontal drive has bronze or oilite? bearings & the MT shaft has 2 bearings in it. 1 at the bottom which is held in place with the cover & the one at the top is held in place with a split screwed washer (the type you put a screw in so it doesn't come loose I don't know what you call them) there are no shims in there. You have to put the bearings on the shaft first and then slide the whole thing into the head. your old bearings should have numbers etched onto them so you can identify them like that if all else fails regards Paul |
Thread: diameter calculation |
11/10/2019 13:23:32 |
Hi all worked a treat thanks guys. I'm not very good at "sums" I've just read through the postings and I think my head is going to explode thanks again. regards Paul |
11/10/2019 13:19:49 |
Bob check your in box, also have you joined the tom senior group on yahoo, I used to be on that and the is loads of info on there. regards Paul |
11/10/2019 08:36:51 |
Hiya John Posted by john Chappell 1 on 11/10/2019 07:38:39: Yes I am up to issue 4620 but awaiting some cast iron. 60 Dia mm as far as I can see you can't get it out of 50mm.
You can get the cylinder out of 50mm bar, just don't put the hole through the middle like I did in the first one regards paul |
11/10/2019 08:31:22 |
75.06 will do for my needs thank you for all your help, It was a head scratcher for me! regards Paul |
10/10/2019 21:37:08 |
Thanks Guys just the job, I will plot it out First job in the morning. regards Paul |
10/10/2019 21:09:38 |
Hi all I'm wanting to drill 3 holes in a triangular fashion on my mill with the PCD function I've already set up the work piece with the quill in the centre, The centre of the holes are 65mm equally distant apart from each other. Question is how do I calculate the diameter of the circle needed? I could do it on paper with a compass etc but I want it more accurate than that. I've had a look at the machinery's manual but cannot seem to find anything. thanks in advance for any help regards Paul |
Thread: Exactly... |
09/10/2019 16:54:10 |
Hiya Ifoggy yes it's a great book, I borrowed this from the listening library a while ago, not just about engineering though. well worth a read regards Paul |
Thread: Sharpening Machine Drills / Clarkson T&C Grinder |
06/10/2019 11:53:23 |
peak4 beat me to it, the bedroom work shop is an excellent site, there is drawings for the universal head on there as well as the fingers. You could use the er collet system to hold the drills as I'm planning on doing. regards Paul |
01/10/2019 19:15:40 |
Iv'e never cut a cylinder from bar stock before, but seemingly "the process may look a bit daunting" but "the process is quite simple" he goes-
cut a hole oh dear! port face won't be big enough start again better port face big enough Ok it's not perfect port face is 0.2mm too wide and if you look close iv'e nicked the inside of the bottom flange, but that will be covered any how. so on the whole to say I've never done this before i'm quite pleased with the results, I'm going to leave the holes for the steam chest till later when I decide weather to make the chest 0.2mm wider or not. the exhaust is drilled but not tapped yet, a bit of fettling, honing and jobs a good un. cheers Jason |
Thread: Why does the micrometer have a second knurled segment |
05/09/2019 23:18:03 |
or a C spanner |
05/09/2019 23:15:33 |
Posted by Michael Briggs on 05/09/2019 22:58:47:
Photo finish Paul, let’s call it a draw nah you win by exactly 60 seconds |
05/09/2019 22:56:25 |
Posted by Alan Waddington 2 on 05/09/2019 22:13:53:
The second knurled grip is designed to afford the user better purchase when using the micrometer as a hammer during squaring operations and such like. well you learn something new every day, I didn't know you could use them as a hammer as well. I just use mine as a G cramp! |
Thread: Where to begin? |
09/06/2019 20:55:55 |
Hello Ivan Iv'e been following this and another post with some interest as I'm considering having a "dabble" myself. with regards to Fusion 360 I know it's free for hobby users but for how long? Admittedly I have not contacted them but I just get the sneaky feeling it's just for 12 months? Also you say that drawings are saved in the cloud. which I didn't know, does this mean you cannot save it elsewhere eg usb stick? Is it possible to load it onto a computer not connected to the internet? Iv'e been watching Paul McWhorter on the tube and i'm leaning towards Fusion 360 it seems doable to me Hope you don't mind me asking regards Paul
Thread: Excel Die Filer |
26/05/2019 17:17:37 |
the offset is about 1/2" centers the top bar is 7/8" regards Paul |
