Member postings for Robert Butler
Here is a list of all the postings Robert Butler has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Super 7 spanner sizes
07/04/2021 21:45:46
And use ring spanners where ever possible.
Robert Butler
Thread: Replacment oil can spout
06/04/2021 11:17:31
Try Googling Wesco Oil Can Spouts - from £2-00 upwards
Robert Butler
Thread: ER 16 / 20 or JT2S, JT33 and JT6 Straight shank tooling
30/03/2021 18:00:18
Dear Martin
I think I have managed to send you a message!
Robert Butler
Thread: Was Draw Filing ever a chargeable offence in the RAF?
24/03/2021 21:17:27
I doubt it, when in the RAF where else would you put your filing other than in Drawers!
Silly humour time for which I apologise.
Robert Butler
Thread: Raglan 5 inch lathe
19/03/2021 16:34:46
There are change wheels on HW 16DP 7/8 bore and 3/8 thick.
Robert Butler
Edited By Robert Butler on 19/03/2021 16:35:17
Edited By Robert Butler on 19/03/2021 16:36:33
Thread: Helical pencil sharpener blade replacement
14/03/2021 23:14:26
Jakar - well know auction site spares listed. Caran d' Ache helical cutter replacement on Amazon UK (should I have mentioned this) Google make of machine as above and add spare parts. I obviously don't know if they will fit but with the sentimental attachment worth a punt and may be capable of modification to fit.
Robert Butler
Thread: What does this thing do?
10/03/2021 11:22:49
Gentlemen to shatter a possible illusion, I remember well my woodworking lessons over 50 years ago now. Regrettably not much time for woodwork now. Dovetail squares (now there's a contradiction in terms) permit striking out using a proper marking knife with the unsharpend edge of the blade resting against the square thereby preventing wavy lines.
Robert Butler
09/03/2021 22:08:40
Or reverse the the direction of application of the knife which is only sharpened on one edge.
Robert Butler
09/03/2021 21:27:47
It must also be noted the joints were marked out with a "marking knife" - never pencil although the marked lines could be highlighted with pencil and the waste also marked with pencil.
Robert Butler
09/03/2021 20:02:50
If it is a dovetail jig it can only be used for marking out, who would risk fine dovetail saws or chisels using it as a guide for cutting the joint?
Robert Butler
Thread: Help needed, can't release cast iron wheel
06/03/2021 17:19:15
Is that a screw slot immediately above the puller screw 12-00 o'clock? does the item on the end of the wheel then unscrew? both would serve to locate the cast iron wheel and when the wheel is removed may also reveal a key?
Robert Butler
Thread: Is this a daft idea please?
05/03/2021 21:28:26
Make sure you have enough headroom for the draw bar once installed particularly if the collects/chucks benefit from metric and imperial threads!
Robert Butler
Thread: What Did You Do Today 2021
28/02/2021 21:27:55
Iain - drain the compressor EVERY time you have finished using the compressor.
Robert Butler
Thread: Looking to pay for someone to finish an engine
24/02/2021 19:11:46
PS wrong Tamworth MES I think
Robert Butler
Thread: Fuel Resistant Filament
23/02/2021 19:04:16
Just a thought, there are carburettor repair kits listed on the internet and for old engines, vehicles or marine applications.
Robert Butler
Thread: boring bar
23/02/2021 18:46:47
Ring Jenny J B Cutting Tools she will probably know exactly what you want, a very helpful lady.
Robert Butler
Thread: MEW issue 301
16/02/2021 14:44:51
301 Delivered today by trusty Newsagent.
Robert Butler
Thread: Parting 1 1/2 phosphor Bronze
05/02/2021 22:30:42
I assume back post = rear tool post - silly question was the parting tool inverted? if not this would explain the problems experienced.
Robert Butler
Edited By Robert Butler on 05/02/2021 22:31:32
Thread: Odd size allthread availability?
03/02/2021 10:44:46
Tim - no problem - anything to include a bit of humour
Robert
03/02/2021 10:36:10
Or a die
Robert Butler
