Here is a list of all the postings Fowlers Fury has made in our forums. Click on a thread name to jump to the thread.
Thread: Bore micrometer | ||
10/05/2019 14:09:55 | ||
'had written before" take maximum reading as it's moved around". This was it in use:- | ||
10/05/2019 13:05:42 | ||
Valuable comments above ! Kiwi Bloke ! makes observations I can endorse from experience.
I suppose, given my ignorance in such matters, that the least subjective method might be to turn down a diameter of steel on the lathe until it "just" fits and then measure its OD with a micrometer (allowing for temp equilibration). But that's fraught with problems of surface fnish etc and gives no indication of bore ovality.
Thread: Setting Milling-machine Vice | ||
07/05/2019 12:20:23 | ||
The subject has of course been covered before here in May of last year. On 30/05/2018, I posted "Lining up the milling vice....I'm with Clive F's 4th para "Personally I'm not great lover of keyed vices.... etc" Further details & Images shown with that original posting. I still find it takes about one minute that way and is always accurate. Edit:- Apologies - I tried inserting link to that thread but am getting error. https://www.model-engineer.co.uk/forums/postings.asp?th=136030&p=2 Copy & paste that into search bar should bring up Google link Edited By Fowlers Fury on 07/05/2019 12:27:11 | ||
Thread: Turning Cast Iron question - Health & Cleaning Up | ||
07/05/2019 00:02:36 | ||
'have posted on this before, as have others. Meehanite is great stuff to machine but the after-effects can be a trial.
Edited By Fowlers Fury on 07/05/2019 00:03:57 | ||
Thread: 2" Clayton Wagon help | ||
26/04/2019 20:56:09 | ||
Didn't find either problem you've experienced. Frustrating for you and sympathies but you need to check dimensions from Robin Dyer's (?) plans as I didn't deviate from them. | ||
Thread: C.B. Reeve year clock | ||
14/04/2019 22:10:31 | ||
Before replacing the old & yellowed issue in the book case, here's a fairly hi-res scan of the only other page with images. | ||
14/04/2019 21:59:23 | ||
Paper & print quality comparatively poor then but assuming you only want to see that one page:- | ||
Thread: anealing piano wire | ||
13/04/2019 18:12:17 | ||
You're not wrong about it being used in pianos. If you put it to Google you'll get plenty of information. Here's the link to the Wikipedia article:- **LINK** It's tough, very tough and will mark your wire cutters if you attempt to cut it. I was dissuaded from trying to anneal it by numerous articles describing how difficult it was to restore its original strength. A high speed mini drill is the best tool for working it e.g. grinding disc to cut it, diamond burr to drill it. <Edit typo> Edited By Fowlers Fury on 13/04/2019 18:14:26 | ||
12/04/2019 13:10:58 | ||
This will work but it depends if you're on friendly terms with your dentist.
Thread: Soft Feel Finish on Radio | ||
06/04/2019 19:51:00 | ||
" Where can you buy this paint, (See below). Did you clean off first or just paint over? (Paint over) " | ||
06/04/2019 18:05:50 | ||
Another version of Neil's suggestion above....... | ||
Thread: Errors and Omissions | ||
15/03/2019 23:15:34 | ||
It's thoroughly worthwhile to advocate a collection of errors on drawings yet there's the inevitable "but". It really is a treasure trove of information and enlightenment on just how many errors on popular drawings have been identified over the years. I compiled a detail list of errors found on a certain hot air engine and notified the author. He replied that the errors would be corrected on the next print but as far as I'm aware they never were. There were however posted on the M.E. Clearing House Errors Pages.
Thread: Centre finder? | ||
09/03/2019 18:30:44 | ||
Many years ago in one of the ME mags, it was suggested that you could dispense with gimbals etc and just cut a thin slice of india rubber (= pencil eraser) and fix in a frame. The pointed rod was simply pushed through to provide the magnified "wobble". I remember trying the idea and after cutting a slice from an eraser about 1/16th thick (?) it worked well enough for setting up in a 4 jaw. Much later, the gimbal below was removed from a broken lab item. The gimbal looks easy enough to make, probably more so than drilling steel balls..
Thread: Issue Reading New Digital Viewer | ||
10/02/2019 11:35:34 | ||
"Why don't they just do what most of the other magazines I read online do and publish these as a PDF. You still have to be a subscriber to access them so what's the problem?" Possibly because it is considered too easy to redistribute pdf versions e.g.within M.E.Socs.? But publishing staff, contributors etc are undeniably entitled to remuneration for all their work. Sorry ~ a digression from the original thread...........
Thread: Trends in Radio Ads | ||
06/02/2019 23:16:40 | ||
Neil writes "Working from home I listen to a lot of Radio, chiefly Planet Rock..... ". My gripe is BBC TV and their ever-increasing amount of self-advertising between programmes. Also their regular annoyance of advertising masquerading as news. They introduce some untopical item on BBC TV News and you know it's going to end with ".....and you can see more on that by watching ***** on BBC1 tonight" | ||
Thread: Sliders too tight | ||
01/02/2019 21:50:41 | ||
Your other post might suggest the 'scope has been used in a path lab. Do you know its working history?
Thread: Proxxon MF70 went bang | ||
01/02/2019 00:55:55 | ||
Martin et al, (It was a design fault cured by fitting the plastic cover over the base of the pcb and later, by fitting a computer-case fan adjacent to the brushes. That fan acquires a suprising amount of carbon !)
31/01/2019 20:45:21 | ||
Amidst all the electronic experts here, this will be inviting ridicule but.... | ||
30/01/2019 22:26:15 | ||
Dave wrote "Yes I do but the quality of the image is so poor, it is unreadable ... take a look at my image above, that was captured with the snipping tool."
30/01/2019 17:55:14 | ||
With Pocketmags I never discovered how to "print" more than 2 pages at once (used Print to pdf), could've been my set up but seemed a restriction of Pocketmags. To capture and collate a complete article was an irritating & time consuming process with Acrobat. Quicker alternative was to use Windows Snipping Tool, save as jpg, then sharpen if needed with (free) IrfanView. The image quality not as good as Print to pdf but certainly OK & much quicker process. Example of image below - much reduced.for posting here:- With Windows 10, pressing Ctrl and + together will magnify the screen for a particular drawing and another "Snip" can capture it .
