Member postings for Ian Parkin
Here is a list of all the postings Ian Parkin has made in our forums. Click on a thread name to jump to the thread.
Thread: Ideal Guillotine
15/09/2020 21:34:00
Blades easily available but about £150 now
its probably a 1980’s machine that one so not old
Thread: Tachometers sensor magnet
15/09/2020 18:22:14
I need to fit a tachometer on a machine in the morning
how do i fit the small button magnet to a shaft?
if i glue it to a mild steel shaft does the steel sap the magnetism ?
15/09/2020 18:19:02
I worked on the electric versions quite a lot in the past
the manual ones don’t really have any safety features as such
the blades are either carbon steel or high speed Steel on ideals so not hardened
anything you need to know ask away
blade sharpening at a couple of places in sheffield
Thread: Mk1 Colchester student clutch
09/09/2020 19:54:14
The clutch if fitted is outboard of the pulleys away from the headstock
dsc02094 (medium).jpgYou can see it out of focus behind my home made brake...if you have a clutch you cant have a brake usually
08/09/2020 16:11:14
You can have a clutch fitted
does your motor run then when you lift the start handle the spindle starts?
or when you lift the handle does the motor start? And the spindle?
if you don’t have a clutch you should have a brake in the pulley area which could be giving problems
but first I’d look at your drive belt/s
Thread: Hermes Parcels
06/09/2020 13:38:25
The list of prohibited items is all encompassing there’s hardly anything that they will carry
i can imagine if you sent a glass item and it got damaged then that’s ok you lose. But if they lose the item what was in the package is immaterial...they lost it
Thread: Moore & Wright disaster
03/09/2020 12:57:50
Barrie you are right
i misread the listing
03/09/2020 12:12:24
If anyone needs new batteries they are
Varta
4/v250H
4.8v 250mah
Edited By Ian Parkin on 03/09/2020 12:12:35
03/09/2020 12:10:38
I just received 2 new batteries today from “all batteries” for my 2 micro 2000’s
these are a direct replacement but lithium ion
cost £20.30 for 2 delivered
anyone any idea how long I should charge for and is it ok to keep plugged in when not using?
Thread: Can anyone supply a lead for grub screws
23/08/2020 13:25:45
For now I’ve punched out some 2mm thick brass pads and the operators will have to drop one of those down the holes before using a normal grub screw
the machine maker wants £12 each for the brass pad ones
23/08/2020 10:51:49
Brian
do you mean drill the grub screw and turn up some brass pads?
can I drill a grub screw?
23/08/2020 10:18:20
I need 20 of these?
5/16 unc with the brass pad
Any ideas?
Thread: Sourcing Belzona Fluid Metal Materials
16/08/2020 18:33:50
I still have a very space age looking pack (bright orange with fins) that I bought in 1986 and its still working when I need it.
Thread: Twerps with hats on back to front and no front number plates
16/08/2020 18:30:48
There’s quite a few supercars running around South Yorkshire bereft of the front no plate
Thread: What lathe tool for deburring holes?
06/08/2020 16:28:39
When i started this thread i suppose i was looking more for a tool for 45 degree chamfering rather than deburring
anyway after all your thoughts i bought this tool from chesterfield machine tools on eBay....it works a treat and can do perhaps a 3mm internal chamfor.and much larger external chamfor3a17f94f-b230-4ef5-a756-f2ad7ed0618c.jpeg
Thread: Training school auction
06/08/2020 14:22:54
There was a similar auction 2018 in Rotherham with 5 similar lathes and 5 Bridgeport’s
the lathes all went for about £500 each
all the tooling was in big cabinets sold as one lot
so in one cabinet was all the tooling required for 5 lathes
01/08/2020 18:24:22
Jimmy that is a nice tool
maybe look for a sh one
01/08/2020 15:29:09
I use a 45 degree tct tool for relieving sharp edges on external shoulders
is there a tool for internal use?
i know a countersink in the tailstock works but a tool post mounted tool would be ideal.
again a boring bar set over to 45 degrees would work
but I’m after a tool i can just drop on to the QCTP and debur
does such a tool exist?
Thread: Opions sought on using the USB Photo Stick for photo storage
29/07/2020 10:55:33
Are you not able to find your photos and transfer them to any usb stick?
all the photo stick does ..it has a piece of software on it which searches for jpeg files and transfers them for you..
if you can do it yourself it saves lots of money
Thread: How to stop scam phone calls for good?
21/07/2020 18:31:18
Right executive decision made TRuecall it is ordered one
i hope thats the end of the problem for her
