Here is a list of all the postings Dismaldunc has made in our forums. Click on a thread name to jump to the thread.
Thread: Importance of the forum in your life. |
19/02/2013 16:35:32 |
Like Neil says this is my "virtual club" being in a remote area this is pretty much my only source of help . As a complete novice this forum has helped me build several small engines and a boiler. I would miss it a lot . Dunc |
Thread: digital height gauge displays random numbers |
10/02/2013 11:44:54 |
well that seems to be sorted.. Brought it into the house for a warm and it now seems like a happy bunny. Righty then Tinas main bearings it is then! Thanks Lads Dunc |
10/02/2013 10:29:27 |
Hi chaps Thanks for the rapid replies, I have tried 2 new batterys but both were stored in a cold work shop, So I have brought the poor thing into the warm for a little TLC. I will see if that helps Dunc |
10/02/2013 09:59:04 |
Hi Chaps
I bought a digital height gauge from Allendale at the last Harrowgate show, It has been a joy to use and improved my accuracy no end. However this am when I went out to play (with an ambitious set of ideas in my head for a good 4 hour session) it just gives a bizzarre ever scrolling read out. I shall of course contact Allendale tomorrow but wondered if there is anything I can do to make it play nice ( I have changed the battery Dunc |
Thread: Stuart S50 metric conversion |
04/02/2013 18:01:46 |
Hi mark s end me a personal message with your e mail address and they shall be yours . i converted the plans when I built mine. Dunc |
Thread: Aligning boiler bushes |
20/01/2013 14:46:57 |
Hi bill, I sent you a "personal message" if you look at the "my account" box at the top left you will see the "my messages" link dunc |
19/01/2013 14:12:40 |
Hi bill sent you a pm dunc Edited By Dismaldunc on 19/01/2013 14:13:00 |
Thread: Live steam fittings |
18/01/2013 20:42:20 |
Thanks mr fizzy , that's all the info I needed. I'm a metric peep so help with the imperial stuff really helps |
18/01/2013 12:10:29 |
Hi chaps, I'm in the process of finishing my glr vertical boiler and want to use it to power some small stationary engines ( stuart s50 , Tina etc). However the the range of sizes of fittings is making my head hurt..... So I think the question is what size steam pipe do I need to use? Thanks in advance Dunc |
Thread: Turning cast iron |
14/01/2013 21:40:42 |
Hmm a "file" you say ??? ( looks it up on Wikipedia ) |
Thread: Milling Machines |
14/01/2013 18:59:16 |
Yup I have the arc euro sx2 as well and I'm impressed for the money, it also has a rigid pillar instead of the swivel mount. dunc |
13/01/2013 13:31:08 |
Hi chaps, well with a bit of faffing about and a combination of all your sage advice I have managed to complete one side and am pleased with the result. I ran the lathe a bit faster as per Neil, ground the corner off so I could get a start and finally hauled the flywheel round by hand until I managed to "cut the crust off" many thanks to you al once again. i live on a Scottish island and am unaware of any other hobbyists, basically any activity that doesnt either feed you or earn you a few bob is looked at a a bit strange. I wish I had a pound for every time someone looks at one of my lovingly created engines and asks "aye that's nice...... But what does it do ? " Dunc |
12/01/2013 16:49:00 |
Hi there ,thanks for the quick replies. Yup I'm using a carbide tool, I'm running the lathe as slow as possible ( it's a bit of a juggling act. If I start too slow it just stalls when the tool hits it, not a lot of low speed torque on these wee chinese lathes ) so it looks like the casting will be going in the solid fuel stove overnight Edited By Dismaldunc on 12/01/2013 16:53:44 |
12/01/2013 16:01:37 |
Hi chaps, I am attempting to turn the 6inch fly wheel for my glr "Tina" on my mini lathe , I realise that it's a big ask for a little machine but am trying light cuts in order not to stall the motor. however IT'S SO HARD I've made a couple of stuart. Engines before and they were fine but I'm even getting sparks flying off the tool and can't seem to get into the metal. Any ideas ? thanks muchley dunc |
Thread: Glr vertical boiler |
05/01/2013 16:33:39 |
well I think I've got to the bottom of why this is suddenly a lot harder..... owing to me having the typing skills of a baby elephant wearing boxing gloves I ordered 449 solder instead of 455 not only does it melt at a higher temp, it also costs more I. hearby award myself the "Order of Numpty class 1" (bows and retires) |
05/01/2013 15:23:17 |
Aargh! Trying to solder the top tube plate , put loads of flux, solder rings around and the tubes and short lengths of solder tucked in the flux all around the outside. I made a little hutch in the brazing hearth ,heated it from the outside a till all the solder melted and disappeared. The tubes all look fine but half of the circumference of the outside is not sealed, so I fluxed it again and tried again but still the same result..... Help !!!! |
31/12/2012 15:43:09 |
Hi Chaps, thanks agiain for allthe advice, Adams boiler/engine setup looks the business. So I've at least made a start.. Here is the tubes and firebox from the bottom (the fact that it has no firebox door may seem a little odd, but seeing as its going to be gas fired and it was my first attempt I thought I would follow the sdvice in the wee book and just mage a "dummy" door). Here is the foundation ring which has couple of bits where the solder has not flowed correctly (i think it did flow but the gap was too large, so it did "tin" both edged but fell through the hole. I have since given the side a bit of a tap and will try again when my solder/bigger burner arrives from cup). I made rings of solder for the tubes and cut little lengths for the rim. You can see the small ridges to stop the tubes falling through. I had to put them on the inside as did not leave enough lenght to fit through the plate (whoops!) this means the water section will be about 3mm shorter than it should be.
and finally the top tube plate waiting to be soldered when the solder arrives (i've run out) you can see where some solder I applied by had went into a tube and ran its full length (a waste of expensive metal Edited By Dismaldunc on 31/12/2012 15:44:02 |
24/12/2012 09:19:02 |
Thanks Martin the boiler looks great, love th idea of sticking the cladding to some card, I shall be using/stealing that idea |
23/12/2012 15:03:18 |
Well I reckon I'm gonna need a bigger burner, will hop onto the cup alloys site and get busy with my credit card |
23/12/2012 10:30:39 |
Hi chaps, thanks for the advice and yes Martin more pics would be great, I bit the bullet last night and had a crack at the boiler tubes. All seems to have gone well and on your advice a cocooned the assembly in some refractory material I bought from my heating spares company. It's 5mm thick white stuff that bounces all the heat back and is only £7 for a huge 1200x600 piece they call it ceramic paper. I will take some pics later. on another note I see GLR are closing down, which is a bit sad as I wanted to get the wood cladding and steam fittings kit from them..... |
