Member postings for bernard towers
Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: MAX-T
13/07/2022 17:01:29
surely MAX-T tools are German And MAX-T engineering in Lowestoft is a plant and machinery company?
Thread: Myford ml7 toolpost bolts
13/07/2022 15:38:37
Every time I bought QCTP holders the first thing I did was to take out the socket heads and replace with sq heads . no swarf no bother.
Thread: What is acceptable chuck run out?
13/07/2022 15:32:52
if you don't have certs for all the items what do you think is acceptable?
Thread: Filing rest - hardened guides ruining files
12/07/2022 20:29:49
if you are worried that your workpiece is flimsy why not support it from underneath???
Thread: Connecting battery charger fly leads
12/07/2022 20:04:45
another one of those myths that people accept as fact after a period of time.
12/07/2022 10:28:39
Jason, In answer to your question all of the drawings / descriptions I have seen go for case hardening which is how both my filing rests were made
Thread: Topslide question
11/07/2022 23:25:00
if you don't want a 7lb one you know what it is!!
11/07/2022 23:21:46
I have been using two filing rests for goodness knows how long both with hardened rollers and have never had trouble with blunting files, possibly you might be dwelling on the point where the file has done its work and you need to move onto the next flat etc.
Thread: Machining fabricating services
11/07/2022 20:09:47
try your local classic car clubs or motorcycle clubs or the friendly local classic car mot tester
11/07/2022 20:04:34
just get a very shallow angle centre punch and put in the slot and tap with Birmingham screwdriver
Thread: Chattering when cutting with countersink tool on lathe
11/07/2022 14:02:24
definitely a single point cutter of some sort, be it a lathe tool or single hole countersink (deburrer) but also as said before drop the rpm.
Thread: What Did you do Today 2022
08/07/2022 12:08:45
Found it Bob ,Go to settings then my account its at the top of page change selection and hit update preferences.
06/07/2022 21:51:54
when What did you do today 2022 is selected why doesn't the current page load?
Thread: Dividing head attachment
06/07/2022 21:42:16
You can also fit it to the rear of the headstock!!!
Thread: Boxford Shaper Vertical feed
06/07/2022 18:33:57
I think you'll find that most English shapers were made in the same factory and badged.
Thread: Tap and die trouble
06/07/2022 17:50:49
Beat me to it Hopper.
06/07/2022 17:49:22
hope the pics tell the story, the gear with a plain section is moved from cross shaft to vertical shaft using the same rachet mech to operate both.
06/07/2022 17:46:40
b76093fc-4831-4202-9f2f-605151d0fb8a.jpeg8a797671-a4f4-42f6-ba2d-2bff08842781.jpeg648ceecc-d08c-4201-807c-8d788753ec51.jpeg4d9948c1-ff32-4abd-bedc-7c1995fb33f4.jpegI think that you only need two gears and piece of shaft to match dia of other two shafts.3182e456-1a38-496f-aa2d-10944a386b07.jpeg
Thread: Phosphoric Acid experiment
04/07/2022 22:39:32
phosphoric acid is also used in commercial vehicle wash bays to clean aluminium.
Thread: Making parting off tools
04/07/2022 22:31:28
sorry Chris but you need to have a good look at GHTs rear tool post design, it does no strain the T slot as everything is sandwiched together making it an extremely rigid affair. Funny how there hasn't been any designs to supersede it!!!
