Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Brass plate or flywheel casting |
29/09/2023 18:59:05 |
go round your local ind est and look for engineering places and walk in with your drawing and ask if they could help with materials or info, its surprising how accommodating people can be. |
Thread: Speedo gear size |
28/09/2023 18:17:45 |
you quote kph not mph does that not increase the size of your minefield?. If your speedo is marked kph not mph do you not have to overlay that with mph markings?, if so the overlay could be graduated to suit. |
Thread: LED Angel lights |
27/09/2023 17:47:59 |
Not fitted an angel eye but made one on a piece of f/glass board with two rows of led's and powered by a wall wart. its done about ten years service so far (touch wood). |
Thread: London Model Engineering exhibition at Alexandra Palace |
27/09/2023 17:43:54 |
Do you all go to shows just to buy something? |
Thread: Pear projectile proof pitched parapets |
27/09/2023 17:40:41 |
cut the tree down! |
Thread: Bolt or screw? |
27/09/2023 15:02:37 |
Yes I'm with the setscrew def. and was always under the illusion that screws were for wood or if engineering type threads they had heads with slots in |
27/09/2023 14:57:57 |
Hold it in a town where there is no emission zone, there must be some in the southeast with large halls or racecourses? |
Thread: Parallel Reamers? |
25/09/2023 17:56:59 |
If you use a chucking reamer you should be ok as the only cut on the 45deg lead, I do have one or two old fashioned reamers that cut on the front as well like an end mill and have used these in the past to ream blind bores like you need on hand pumps. |
Thread: Myford |
23/09/2023 20:01:24 |
find the recent post "ML7 top slide" for some answers. |
Thread: Project ideas |
23/09/2023 15:43:38 |
try sarik hobbies on the righthand side of this page for a start |
Thread: MEW 332 |
23/09/2023 14:02:38 |
Thanks Michael, on the ball as usual. |
23/09/2023 13:52:20 |
Would like to do the same but can't find the editor? |
Thread: Struggling to squeeze my balls hard enough |
20/09/2023 20:02:09 |
You could let the ball down by heating to red heat and covering in insulting material to let it cool slowly then you can work on it. For the female make internal form tool. For a perfect match run them together with a little abrasive paste. |
Thread: What did you do today? 2023 |
20/09/2023 17:37:14 |
Finally assembled the Humbug in glow form and it runs!!! |
Thread: WHERE ARE THE SHAPER USERS ? |
20/09/2023 09:06:34 |
Suggest you read page 51 of shaper operations by j w Barritt. . As regards to using a hinge. |
20/09/2023 09:05:42 |
19/09/2023 15:42:04 |
when cutting tee slots people use a hinge to lift the tool completely clear after each cut, this requires quite a bit of extra stroke either end. |
Thread: MEW 332 |
19/09/2023 13:22:25 |
You can please some of the people etc. etc. And it’s er16 not 15,, |
Thread: electrical fault puzzle |
19/09/2023 13:04:26 |
If you have undone the switches and the fault has gone I would start there. |
Thread: Measuring instrument storage. |
18/09/2023 21:32:55 |
If you just use cellulose sanding sealer on all surfaces corrosion is eliminatied. |
