Member postings for A Smith
Here is a list of all the postings A Smith has made in our forums. Click on a thread name to jump to the thread.
Thread: 74 TX650 build.
11/08/2023 11:44:24
What a challenge! What a result! Well done.
Thread: UK Made Boilers
02/08/2023 11:48:20
Posted by Trevor Johnsson on 01/08/2023 09:30:46:
If the boilers are made to BS 2790 there is a requirement under Section 7.0 to provide drawings, documents, data sheets and test certificates. If these were provided the boilers may be accepted although limited to 700 bar operation. Both of the ASBSC codes for boiler limit the operating pressure to 700 bar..
Let's see, 700 x 14.504..............
Thread: Do you need an oil change with less than 10,000 miles in 10 years?
21/07/2023 11:56:04
A teaspoon of "R" in to a full petrol tank has the same aromatic effect.
Thread: Material for Collet Holder
02/06/2023 12:32:09
I made an ER 25 Collet holder EN1A some years ago, it proved perfectly satisfactory. I'd avoid cast iron for the same reasons everyone else has given. No stupid questions, you know the rest.......
Thread: Oh dear - not quite right - again!
17/05/2023 12:23:10
Draw used as a substitute for drawer.
Thread: Blueing Blues
21/04/2023 12:16:13
"Stainless Steel" is more properly called "Corrosion Resistant Steel"
"Never seen a mainline loco with rustless steel frames", said Curly.
Thread: bodged thread repair
03/03/2023 11:53:15
I'd go to a specialist motor/ motorcycle engineering firm that employs a good welder. They would have all the options and could select the most appropriate repair technique. There's a very good one near Bedford with which I have no connection other than as a satisfied customer.
Thread: Mc Donald Model tractor
15/02/2023 12:46:13
Always look forward to your posts Fred. Marvellous work.
Andy
Thread: All motorcycle races and trials events in Northern Ireland cancelled this year
10/02/2023 12:09:00
I've stopped going to the IOM TT because I don't want to be there when (not if) someone gets killed.
Thread: A poor early Christmas present.
21/12/2022 12:39:18
I bought my QCTP from Myford many years ago. I have had to return several pattern tool holders as they did not fit. One of the common faults is that the hole for the height adjusting stud is too close to the rear face of the holder and consequently, the knurled nut fouls the rotating clamp on the block. Some can be jobbed by turning down the knurled nut. Others just wont go on at all, as the angles and clearances of the slot and v's are incompatible.
I took my Myford supplied block to MEX this year and tried the RDG offerings. Slightly tighter than the originals but OK. I bought a couple, may buy some more at another show, after trying them first.
Thread: NHS Fiasco
17/12/2022 10:20:30
Oh well, live and lean. Apparently, it is easy to make the correct decisions during an unprecedented crisis.
Thread: Doncaster Model Railway Show.
17/12/2022 10:00:26
Harrogate ME Show 2023, March 10th & 11th. I see that there is a Yorkshire Event Centre web page announcing this show. There's also a brief mention of it in the latest ME. Anyone know more?
Thread: NHS Fiasco
15/12/2022 12:11:07
Easy to retrospectively pick apart decisions made during an unprecedented crisis. The media were screaming for something to be done to resolve the PPE shortage, the Civil Service were operating at a glacial rate and the usual professional critics were poised to find fault.
Thread: Applying torque
25/11/2022 12:00:26
Interesting discussion. In the early 70s, I cured a rattle from the o/s front wheel of my brother-in-law's Morris Traveller by taking the hub cap off and recovering the snapped of stud that had fallen victim to a pneumatic wrench. Changed the studs on all four wheels.
Thread: Harrogate Showground
18/11/2022 11:52:24
I always found that the queues to get through Harrogate gave my old Satnav plenty of time to update! Never had a problem finding Doncaster racecourse, excellent fish & chip restaurant just across the road too.
Thread: Words and phrases
16/11/2022 12:11:30
Ship Shape & Bristol fashion? Dim as a Toc H lamp?
Thread: TIG welded copper boilers
20/10/2022 12:09:16
I wonder if anyone else is interested to know if the "well known UK based professional boiler manufacturer" mentioned by Luker is still in business?
I only know of two firms that advertise this type of construction, maybe there are others.
Andy
Thread: Rail Card Renewals
24/08/2022 12:24:55
I've had good use from my railcard. Unfortunately, I don't think the railways are viable in the long term, too useful as a political football to some and for others, an unfair burden on the taxpayers who have little or no access but have to contribute to subsidies.
Thread: Do you "still" enjoy driving?
17/08/2022 12:02:08
Do I detect a misunderstanding? Public roads aren't provided for motorists to have fun on and being a good pilot doesn't make one a good driver
Sound of many giggling motorcyclists......
Thread: British Homes Have Air Conditioning ?
22/07/2022 12:08:16
All too often when someone says, "OK climate change is a thing but re we really sure it is all down to CO2 / greenhouse gases or are there other mechanisms also at work?", someone else will *tar that person as a denier.
* "Traduce" would be more accurate.
