Member postings for John Haine
Here is a list of all the postings John Haine has made in our forums. Click on a thread name to jump to the thread.
Thread: Proxxon CNC Mill
29/08/2023 06:50:17
The Nano can run vanilla grbl but not the offshoots mentioned, but vanilla works fine for straightforward 3 axis milling. For CAM and simple CAD I use CamBam which is quite cheap and excellent for most purposes. Lots of people using grbl use UGS as Huub mentioned.
28/08/2023 22:19:17
David, congratulations on the new machine. When you say Arduino interface, what do you mean exactly? To the best of my knowledge there is no Arduino based controller that is compatible with Mach3, Arduino cnc is usually based on grbl or a derivative and there are a number of "g code streamers" that can be used with them. One mentioned here recently is I think Openbuilds Controller.
https://software.openbuilds.com/
Edited By John Haine on 28/08/2023 22:25:14
Thread: A Well-Tempered Hybrid Pendulum Clock Project
28/08/2023 11:31:12
I think that must be an aluminium or steel tooling plate?
Thread: Isochronous knife edge suspension?
28/08/2023 11:29:16
The actual locus of the bob is a "prolate trochoid", not a cycloid. Woodward shows that the radius of curvature of this for small angles is greater than the circular path of the bob with no roller. This means that the "lift" of the bob for a given deflection is less than for a circle, whereas for a true cycloidal path it would be greater. In fact the circular deviation of a pendulum with roller suspension is greater rather than less than normal. Others have confirmed this numerically. Unless one could hang the roller on a magnet this means that there's no point in roller suspensions in an attempt to reduce circular deviation.
Another point is that for compound pendulums (which all real pendulums are to a greater or lesser extent), it can be shown that there is no path the bob could follow that will be isochronous. There are some schemes to correct for circular deviation over a small range of angles, of which the most successful was probably the Fedchenko suspension spring. Or one can try to control CD to gain other benefits which is what Harrison's circular cheeks do.
Thread: Improving hobby-grade Servos
28/08/2023 09:34:17
Posted by Andy_G on 27/08/2023 22:14:29:
Posted by Ady1 on 27/08/2023 19:32:33:
I was really hoping someone had created an easy multi axis software solution for hobbyists
Not sure if this is what you're asking, but the 32bit ports of GRBL will support up to 6 axes (definitely for the first two, and probably for the third. (Open loop still, though.)
GRBL_ESP32
FluidNC
GRBL_HAL
GRBL_ESP32, although no longer actively supported is *very* compatible with 8 bit GRBL and its senders. Both it and FluidNC can be compiled in the arduino IDE.
FluidNC supports software configuration, so you can make machine changes without having to recompile. It will play with many of the Gcode senders, but not my favourite one (Openbuilds Control).
GRBL_HAL needs to be compiled in the appropriate IDE - I haven't used it as I can't be bothered to install yet another IDE, and the web based configurator has limited options.
GRBL_ESP32 works well for me on a 3 axis machine with the ability to run a second spinde (laser + rotary) and a 4th axis without having to change any firmware or wiring.
CAM is the big hurdle for 4+axes.
Edit: I should say *cheap* CAM is the big hurdle...
Edited By Andy_G on 27/08/2023 22:18:37
Andy, I wish you hadn't posted this! Now I'm thinking about upgrading my cnc to use esp32!
27/08/2023 07:37:48
Well for completeness it was in HJ August and September 1994.
Intriguingly, he shows that if the roller rolled below a flat rolling surface it could work.  Very strong magnets might do the trick, but then the rest of the pendulum would have to be non-magnetic to avoid magnetic forces interfering with gravitational.
Edited By John Haine on 27/08/2023 07:41:55
26/08/2023 22:56:53
This has been analysed by Philip Woodward but alas doesn't result in isochronism. I could dig out the reference if interested.
26/08/2023 14:01:34
It's worth looking up Harrison's tin whistle compensator for fine tuning.
My Nome has a stepped hole in the Bob with a ledge. Upper part of hole is 10mm, lowere about 14 fro memory. No need for a square step, just use ordinary drill.
Thread: Forum Platform Changes - PLEASE READ
26/08/2023 07:49:24
One "feature" of the current site which keeps annoying me which I don't recall having seen mentioned is the behaviour of "More Latest Posts". If this feature is retained it would be great if it actually showed a list that didn't include all the latest posts at the top - i.e. just the ones that dropped off the list.
Thread: Counterbore as facemill?
26/08/2023 07:17:47
Its teeth will probably not have side clearance so not operate very effectively as a face mill. As Thor suggests, give it a try? Nothing to lose.
Thread: How come Windows XP can use Bing …
26/08/2023 07:15:49
Any web browser can open a file on your local storage just as easily as one from a web server provided it recognises the file format.
Thread: A combinatorial problem.
26/08/2023 07:12:59
You have 3 blocks each of which may be in the stack or not. The sum of the heights is
A*10 + B*20 + C*25
where A B and C can be 1 or 0 depending on whether you use that block or not. ABC forms a binary number, which can go from 0 to 7:
000, 001, 010, 011, 100, 101, 110, 111
For each you can easily compute the total height and enumerate the possibilities. A 2 minute spreadsheet gives:
0 0 0 0
0 0 1 25
0 1 0 20
0 1 1 45
1 0 0 10
1 0 1 35
1 1 0 30
1 1 1 55
25/08/2023 09:48:35
Jason, you mention png but I trust that other file formats will teh supported for attachments? Every other forum I use allows a range, and for us in particular pdf, xls, txt, would be very useful. That would also allow for example software in .txt format (to share useful programs) to be attached.
Thread: Achieving a long-term quality finish on brass?
25/08/2023 07:09:48
I'm sure there are 🇺🇸 stockists.
24/08/2023 21:48:04
Renaissance Wax
24/08/2023 09:56:12
Posted by JasonB on 24/08/2023 09:21:16:
So if you have images in an album and want to be able to access them copy them within the next few weeks.
Well that will be quick and easy won't it? No alternative to one at a time as far as I can see.
24/08/2023 08:06:55
Bateman has flat top bracket and no clamp. My Arduinome had clamps but I recently slackened those off as I suspected the pendulum might be slightly out of plumb.
Compared to my Helmholtz coil configuration your magnets are rotated 90 degrees. Also thinking about the force lines from each magnet, as the other end is in contact with the rod the flux may be "bent back" at the hot end, how will they interact with the coils?
Thread: Precision pendulum techniques
23/08/2023 22:30:24
I'm probably late to this party but had a sudden thought today. Though the measurements I did on the Sharp opto interrupter showed impressively low (sub micron) repeatability, I just realised that the emitter wavelength is 950nm, nearly 1 micron, so arguably whatever one does in the optical system will not I think improve the results.
Thread: Myford Connoisseur & Super 7 PLUS Countershaft
19/08/2023 07:20:56
I have a big bore S7 with vee belt drive to the spindle and the countershaft runs in bronze bushes.
Thread: Pendulum 'Q' value and measurement methods
18/08/2023 20:25:59
Posted by duncan webster on 18/08/2023 18:20:58:
If I had a pendulum which was perfect in every way apart from a bit of damping and I let it run down, the frequency would very gradually increase as the amplitude decayed, but it wouldn't have a normal distribution.
The period would decrease very slightly, but the cycle-to-cycle random variation would be very small unless there was a lot of noise affecting it (for example support vibration).
