Member postings for DMB
Here is a list of all the postings DMB has made in our forums. Click on a thread name to jump to the thread.
Thread: Sealing boiler fittings
16/08/2011 13:50:00
You could also use Green Hermetite as a gooey sealer - it never sets so easy to unscrew fittings. Do Not use Red version - it sets solid and hard.
John.
Thread: Don't assume the obvious
30/07/2011 22:26:22
Bogs, you must be having a laugh - do you seriously believe that any one in the print trade ever proof - reads anything these days? It certainly doesn`t look like it, judging by all the errors/spelling mistakes and words badly split mid-syllable betyween lines. This is not a dig at DavidClark1 - ME/MEW are pretty good but "the daily rags" are the worst culprits.
Thread: Locomotive axle length- clearance between wheels and axle boxes
24/07/2011 21:47:49
I remember the West Countrys on down trains from Brighton, stopping at "Portslade & West Hove" station when Iwas a kid. Did they clonk, some of them.
Thread: Tearing hair out with disc sander
20/07/2011 10:03:01
Piador is dead, I believe.
Thread: Explanation of job 'Engineers Driller'
19/07/2011 19:51:16
Try enquiring at Science Museum and any Industry museums.
Thread: Milling drawbar
18/07/2011 20:41:54
Re Dusty`s post today. My milling chuck doesnt work loose as I use the drawbar to hold it secure However, on occasion, it has stuck tight but with my new drawbar as previously described, it is no problem to remove. I have used the tang - ended tailstock drilling chuck in the mill spindle to drill holes and its come down. Ido clean my tapers internal and external. I use a piece of soft cotton cloth to draw through, like rifle barrel cleaning.
17/07/2011 23:12:26
Dusty,
Its well known taht a 2MT will part company under a milling load. I have had a 2MT tailsock chuck in mill for drilling holes + thats come loose. Mill or drill chucks just want jamming in by hand and drawbar gently tightened to prevent disasters. I find that Clarkson chuck some times gets stuck fast, possibly when using big (5/8") endmill or slotdrill, ss needing my type of drawbar to shove the tapers apart. BTW, I dont claim originality for it, I read a description of this somewhere - just passing on my knowledge.
Thread: Myford Connoisseur Lathe
17/07/2011 22:57:10
I believe that SMEE used to have a Myford on loan to them for their MEX stand but M now gone, so what now? Presumably a member will bring his along.
15/07/2011 01:05:03
Hi Pat,
I used BMS round bar, NOT Silver Steel for my drawbar. Sil. St. not necessary. Bottom end threaded to suit MT, top end same thread as for the MT. When finished, there is a nut pinned to very top end, along piece of large - AF Hexagon bar, part - bored out to fit over top of mill spindle and locked on to it with 3 grub screws fitted radially and top end is bored out to a clearnce size for drawbar. Another nut is fitted to draw inside the large hex. bar, so its trapped. When the top nut is turned clockwise, it screws thro. the trapped nut and bottom end screws in to MT, drawing male taper into female taper in spindle. Dont over tighten - just nip it up to secure it. When top nut is turned anti - clockwise, drawbar unscrews thro. trapped nut and from MT. The trapped nut wants to stay put and rise up with the unscrewing of the drawbar from theMT but its trapped and cannot move vertically thus preventing drawbar from moving vertically. Something has to give and its theMT shoved down, breaking its grip. Is this now all clear? Hope it helps.
10/07/2011 17:58:16
Look up "Milling collet arbor jammed in milling machine" of 4 June 2011, in Forums.
10/07/2011 17:49:52
Agree with JasonB, regarding make your own drawbar but Paul should go one better and copy my previous post describing the trapped nut which forces the MT apart gently instead of a hammer/brute force, wrecking bearings in the process.
Thread: Dore Westbury Milling Machine
28/06/2011 09:34:02
Hi Adrian,
Watch out for that green dust. Even if its not carcinogenic, it will still do you no good to breath it, or ANY other dust. Use a mask, including when you`ve finished and sweeping up.
John.
Thread: ME bound volume reprints
25/06/2011 22:53:24
Hi Yanna,
I am interested in very early vols., from no. 1 up to 1929.
John.
Thread: Subscription question
25/06/2011 22:25:23
I did exactly the same as Bob Lamb earlier this year and had £50 taken. Was going to complain like Bob but never got around to it as I thought that it looked to good to be true and almost certainly referred to the online price, so did not do anything. Thought it was a bit of a cheek though, the way it was done. Misleading Advertising.
Thread: Mixing flux
02/06/2011 00:04:45
Hi Wallace,
You can almost! Actually,it can be obtained in a hyperdermic syringe (no needle).
John.
Thread: Axle box lubrication
02/06/2011 00:02:11
Hi Robert,
Look at photos (or the real thing) and notice all the little yellow boxes, on fronts of tanks, GWR and on tops of splashers or on running board, other Rly. Cos. Brass boxes with a lid and say, 3 pipes leading to A-boxes. A wick was poked in the top of the pipe inside the oil box and other end laid in box to soak up oil. Hope this helps.
John.
Thread: Paint ????
24/05/2011 11:26:29
Hi all,
I have seen the most fantastic finish on a large model aircraft. It looked exhibition quality - perfect! The owner said he warmed the paint before application, making it much more runny. I think he said it was ordinary Humbrol brushed on, but I`m not sure.
Thread: Steam Boat Ban
27/04/2011 14:05:38
`Metro` newspaper today, page 17, is a photo of a dejected Nick Clark apparently seated at a table with his little steamboat on a typical model boat stand. In length, it looks about 3" longer than the width of his shoulders with a very small vertical boiler. He is quoted as saying top speed is 3 knots.High pressure boilers, IanT? Idont think so.
Good solution seems to be to start a campaign to remove central heating boilers from all council offices!
Thread: Tony Jeffree's Grinder letter in MEW175
19/04/2011 15:54:21
In answer to Tony`s letter; perhaps I am nowhere near unique in quoting SWMBO,
"Wot, ANOTHER project? How many is that? "
Maybe those comments are related to ones like, "What have you got that for?"
Familiar ring to lots of Model Engineers?
Thread: Harrogate model engineering 2011 ?
14/04/2011 09:09:45
Sorry, forgot to say they also give exact dates, but try same info from more than one for corroboration since one of them got it wrong last year but NOT one of those mentioned above.
