Member postings for DMB
Here is a list of all the postings DMB has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ML7 questions
14/03/2012 14:47:38
Agree with the others - most important/useful accessory is QC toolpost for exact centre height every time and quick interchangeable tool types. I got a cheaper type rather than the Myford-Dickson which I thought at the time was too expensive. I am very happy with my purchase many years ago but I sometimes wonder whether its yet again get what you pay for and the M-D version might have been a bit more rigid.
Probably 2nd item if not already got one, is a tailstock drill chuck. Then go on to collect 3 and 4 jaw chucks and a fixed steady for long bars to be machined. Oh! and a leadscrew handle.
Good luck and hope you enjoy many happy hours with lathe.
Thread: Boiler supplier
29/02/2012 09:09:49
Given that every trader in any line of business who takes cr cards has already built into the prices of all his wares, paid for by cash or cr/dr card purchasers, the commission costs of the cr card issuer, everyone should use what they are paying for!
1. Pay by cr card so if boiler faulty or not supplied you get your money back from cr card issuer - quote "section 75" to them.
2.When placing order for boiler, ask for guaranteed delivery date then if the keep giving excuses for non-delivery give them a deadline and failure means order cancelled.
As usual, the odd `baddie` brings a harder life upon all the `goodies` but thats life.
Thread: Mill tram
26/02/2012 00:34:01
On my combo horizontal/vert. mill, just behind the head there is a tapered hole which lines up with another in the main casting and a removable taper pin is fitted. Pin has a black knob-handle to grip it and is threaded under the knob with a nut which can be wound down against the casting to force pin out of hole, if stuck. Very quick alignment!
Thread: Making your own case hardening compound.
13/02/2012 15:55:09
Just looked @ Blackgates` site and they`re still listing Casenite.
Thread: ME nuts and bolts
13/02/2012 15:21:38
Hi all,
Nobody mentioned ME60t. Some years ago it was possible to buy sets of 32/40/60tpi ME taps `n` dies. Not seen 60 for sometime now, though. Just thought I would mention it as reading preceding posts, it reads like only 32/40 ever existed.
Thread: Metal storage
10/02/2012 15:35:12
Hi all,
Square plastic waste/rainwater pipe is the stuff to use.
Thread: Power Hacksaw run off
10/02/2012 15:00:06
hello all,
I want a small portable hacksaw m/c, possibly with a view to getting rid of the space eating bandsaw and I found a design in an old ME - Vol. 82 No. 2042 27/6/1940.
The bandsaw also needs expensive good makes of blades - pay rubbish price, get rubbish. At least with the other type ordinary blades can be used and even good ones last a long time. The old 1940 design probably needs long bearings to guide it to cut straight/square. I have necessary ali angle motor and worm reduction gear so will probably tackle this job soon.
Thread: Drilling brass - seizing
02/02/2012 12:59:14
Hi Andrew Johnston,
Looking @ the piccy in your posting 1st Feb @ 22.42, the 2 big castings both appear alike but if as I think, they are Traction Engine shaft bearings, shouldn`t they be handed?
Have looked back thro` all prev. posts on this thread and cannot see any mention of their use, so what are they for?
John.
Thread: think tank
27/01/2012 15:27:24
I think that a separate paperback book like "Machining in your Workshop" (I think it was called), just entitled "Best of ME/MEW Forum", would leave it free for people to buy if they so choose and make another profit stream for MyHobbyStore. Nobody would be forcing anyone to buy it - consumer choice!
Thread: seaside miniature railways
23/01/2012 08:55:26
Hastings Min Rly is right over to the eastern side of the town.
One runs around the lake in Brooklands Park, South Lancing.
There is one in Littlehampton.
Eastbourne Min. Rly., Lottbridge Drive/or Drove, BN23 6NS tel. 01323 520229. Set up by and still operated by the Wadey family since 1992. (7 1/4"G) Can get all this sort of info just using the netty.
There is a new one recently started on Hayling Island. They are building a Sweet Pea, FULL SIZE!!
Thread: Q1 at the Alexandra Palace show
18/01/2012 11:44:57
Looking fwd 2 seeing it. I believe there is one FS example in store/awaiting restoration(?) on Kent & East Sussex Rly.
Thread: Cleaning up castings
18/01/2012 11:41:41
Nitric acid probably works very well on sandy castings since sand be used as the basis for glass making and I believe that Nitric attacks glass. So what do you store it in? Also how would you dispose of it? Pouring down the drain is NOT the solution! Very nasty stuff.
Thread: Milling a curved end
18/01/2012 11:34:32
Thats it, Bayzle. Just flick thro` each vol., use old envelope for a bookmark on useful articles. Later, copy these items on your printer or simply scan them into `puter. Easy way to create your own encyclopaedic `how to do it` manual. Why mess about with donkeys years worth of indexes to trawl thro` umpteen times every time that you want to know something. Thats what I have done, right from 1930`s. Sounds a lot but apart from LBSC theres not a lot else, since some good ideas from way back have been superceded by more recnt better ideas. I would say that 1950 onwards with each decade revealing better ways of `how to do it`. One example; instead of punching a piece of flexible steel tape with loads of holes and stringing it around a wooden disk to create a new set of dividing holes, its now only necessary to print out required number of divs. on a circular bit of paper + stick it to any old disc and use a pointer.Job done!
Thread: Q1 Snifting valve
18/01/2012 11:15:11
David and Nick,
Hope you dont mind the following comment but I think that if any beginner is reading your posts, they may be a bit mis-lead. On full size, the snifter was connected on the regulator/wet header side of the steam circuit so that cooling air would be drawn through the superheater elements to stop them burning out with the heat of the fire. I suggest that "best practice" would be to follow suit, especially if radiant type were used and even non-radiant if made of copper since copper tends to burn out quickly anyway. There is also the need to prevent ash being sucked down the blast pipe in to the cylinders to cause wear.
John.
Thread: ME Shows
16/01/2012 20:31:49
Hi Bazyle,
I have seen a large, single axle trailor used by a ME trader, that was filled with vertical dividers (plastic drainpipe?) to hold bars of metal stock. No packing, just hinge down the backboard/lid + go!
All beers under 5% = "maidswater"! Just fancy flavoured drinks.
John.
Thread: Application of water-slide transfers
16/01/2012 20:14:49
Hi Wolfie,
I have only recently read somewhere that there is a website holding a very large number of old drivers for the likes of ageing printers, etc. I think it was in Computeractive mag. I`ll see if I can find it and post details - it could help someone.
As regards incompatible plugs/ports, go to Maplins + tell `em your problem - they`ll come up with something.
John.
Thread: ME Shows
16/01/2012 00:45:53
I could use my "old codgers" bus ticket for a 20 min. free ride into centre of Brighton to see Modelworld Exhibition in Feb. Hows that for on your doorstep. I probably wont go again this year even though my club, Worthing Model Engineers will have a stand. Reason is that its quite expensive to get in for what I see as essentially a "pins & glue" model xbn. (Table-top railways/trams/knitting/sewing and god knows what.) One of the model railway clubs once actually told me I belong to those "Dirty Metal bashers" in Worthing!!
I will of course, attend Worthing Club`s own xbn. in April this year. This will be a purely engineering xbn. Happy dirty metal bashing!
Thread: Metal thefts
16/01/2012 00:17:52
Defense company - Qinetque has developed a hi-tec system to prevent oil pipe damage/theft of railway signal cable and lots more apps. It involves sending a laser beam down the cable and reflecting it back to a remote box of tricks that analyse vibrations in the beam and where those vibrations took place. It will mean that anyone walking along near the track or digging up cable, say in Darlington area will be detected by an operator in London who can then alert local railway police.
The second reading of a bill takes place next Friday, relating to contrlolling the scrap metal trade - registrations/recording ID of casual suppliers/stopping cash transactions.
All in the Sunday papers today!
Thread: Parting off Blades
10/01/2012 15:09:12
Hi Bob,
Try going back to the business that supplies this mill (Arc Euro??) and ask for advice, even if you did not buy new. If its A.E., speak to Ketan. If its Warco, speak to Roger Warren. I have purchased goods from both in the past and found both of them very pleasant to deal with.
Good luck. Regards,
John.
Thread: Is it just me
27/12/2011 23:22:40
`Ere, `Ere!
