Injector Tanks.
Keith Bloor10/08/2023 16:21:24
17 forum posts
On my 5" Jinty there are 2 injectors and a hand pump. The injectors are fed from a rear bunker tank. I normally run these without filters because they would be quite awkward to get at for cleaning. I have the engine in the workshop at this time and on taking the tank to pieces I find a fair amount of scale. The water at the club is obviously quite hard. Does anyone know of a paint that I could use on the inside of the tanks?.
Mark P.10/08/2023 16:43:49
634 forum posts
9 photos
Could you fit inline filters, just a thought.
Mark P.
noel shelley10/08/2023 18:05:01
2308 forum posts
33 photos
Galvafroid ! Use rain water as feed and as Mark has said make or buy in line filters. Noel.
Baz10/08/2023 19:21:31
1033 forum posts
I painted the inside of a small five inch saddle tank, the tank was an ally casting and I used Precision Paints etch primer and their gloss cream paint, looked lovely but once water was in it was a different matter, the paint started coming away. The tank was removed and the paint stripped off the inside back to bare metal and coated with West Systems epoxy, I drain the tank after use and after a couple of years use it seems fine.
Speedy Builder510/08/2023 21:07:13
2878 forum posts
248 photos
Why do you want to paint them ? It wouldn't prevent scale build up. Is the paint to protect against erosion (Rust or other oxidation).
Bob
Nigel Graham 210/08/2023 21:17:34
3293 forum posts
112 photos
You could fit a filter in the line, or better for appearance, make it to screw into the tank bush so the gauze is inside the tank. The latter having the advantages of being hidden and taking no space around the loco, while still reasonably accessible for cleaning.
If the tank is of brass, the usual for smaller scale locomotives, it does not need internal paint; and as Baz found with his, it can create more trouble than it solves.
