Member postings for Baz
Here is a list of all the postings Baz has made in our forums. Click on a thread name to jump to the thread.
Thread: Machining EN3b mild steel
17/03/2023 19:46:16
BDMS = bright drawn mild steel, clues in the name, black bar is rolled hence the scale rolled into the surface.
Thread: Clarkson Tool & Cutter Grinder Grinding wheels
16/03/2023 13:55:45
Roy PM sent
Thread: Workshop Mistakes (True Confessions)
15/03/2023 14:29:00
Totally agree with you Tony, most places I have worked the inspection departments were made up of failed machinists, those that were too slow or made too much scrap, and they strutted around in their pure white coats telling the “ handle turners” how it should be done, and getting paid a fortune for shuffling a few bits of paper. A case of Those who can, do. Those who can’t, inspect. I shall now collect tin hat and go hide in shelter.
15/03/2023 12:34:57
Roy I have just dug out my Clarkson book, are you referring disk wheel and cup wheel part numbers 92612 and 92613, if you are they are just Clarkson reference numbers and will mean nothing to anyone outside the factory.. in the back of the book, page 27 in my copy are the British standard wheel symbols, these are what you need to use when specifying a wheel. Luckily on page 26 they list the full spec for wheels they used, cup wheel 38A150L8VBE, if they were good enough for Clarkson they will do the job.
15/03/2023 11:47:45
All those wheels should still be available, they are all standard shapes, maybe not in those particular grades. It all depends on what you want to sharpen but a couple of four inch cup wheels will do most things ally oxide for HSS or green grit for tungsten carbide tools. Wheels can got from any tool merchant, can’t be more precise because we cannot mention names on here but an internet search will provide many sellers.
Thread: Warco Lathe Bedway Scratches
13/03/2023 22:24:06
Pictures would be helpful.
Thread: Can a touring caravan be disassembled and then reassembled easily?
12/03/2023 23:01:45
I certainly wouldn’t want to take mine apart, get a bloke with a crane and lift it over the garage, they’re not very heavy.
Thread: Stuart Twin Victoria (Princess Royal) Mill Engine
12/03/2023 22:07:22
Jason can you tell me where you got your lovely internal grooving tool from?
Thread: Hemingway large bore fixed steady kit
12/03/2023 19:13:09
I am slowly building one, it’s about number ten in the priority list, getting locos ready for this season is top priority, but I would certainly recommend facing both sides and cleaning up the outer edges before cutting in half. The casting will never be to drawing, it was underside when cast same as the bar stock, mine is all cut dead length or slightly short, I have purchased a fair few Hemmingway kits over the years and the raw material in all of them is short to start with, I put it down to the fact that I live in the south and perhaps our inches are a bit longer than inches north of the M4 motorway. One thing I shall certainly do with my fixed steady is to make some decent adjustment screws, the bit of M6 studding I got in my kit is absolutely disgusting. I shall screwcut some 1/4 dia stainless 26 or 32 tpi, haven’t decided which yet.
10/03/2023 17:52:03
Phil, he most probably got quickly promoted to foreman, at least that’s what happened to all the merchant bankers that I worked with, the more hopeless they were the higher they got.
Thread: Trefolex
09/03/2023 15:19:30
Not come across any for a long time, I am still working my way through a ten pound tin that must be coming up 40 years old, still seems to be ok, needs a bit of a stir up before use though. I inherited it half used from my old man, will certainly see me out, must bequeath it to someone when I croak.
09/03/2023 15:12:56
My biggest workshop mistake was ever entering one in the first place, got talked in to it and by the time I realised it was not what I wanted it was too late, stuck turning handles for a lifetime.
Thread: Golmatic MD24
09/03/2023 14:56:24
I looked at that model quite a few years ago and wasn’t wonderfully impressed, ended up buying a Emco PC50 mill with Siemens 820 control.
07/03/2023 15:40:22
Nice windmill, can’t make out what the sign on the gate says. Is it open to the public?
Thread: Why is the world of model engineering still imperial?
07/03/2023 11:32:27
Posted by Paul McDonough on 07/03/2023 08:56:07:
"Really this thread is going nowhere"
I'm sorry i asked! :0(
Totally agree with you Paul but you have to remember that it is cold in the workshop at the moment and all the members are sat in front of the fire with nothing better to do. Model engineering is imperial because 99% of drawings are done in imperial, we all bought mics verniers etc years ago when they were imperial, we pick up tat from boot sales etc that is mostly imperial, we buy ex industrial machines, old Colchester Bantams and Bridgeport’s that were imperial. I was working up to ten years ago in the aerospace industry, all our drawings were imperial, all our measuring gear was imperial, the fifty year old Hardinge lathes that we were expected to hold half thou tolerances on were imperial, half of this country is still imperial.
Thread: 5" Gauge Maid of Kent
07/03/2023 08:53:07
I think we are missing something.......content.
Thread: Bore mic/comparitor?
05/03/2023 22:09:01
Agree with Emgee it’s a bore or groove comparator.
Thread: A photo for anyone who ever claimed a Myford wasn't a "Proper Industrial Lathe"
04/03/2023 10:35:17
Pete if is me you are referring to I will pm you loads of pics of what I have done.
Dave Wootton totally agree with everything you said, couldn’t have put it better myself.
03/03/2023 09:00:36
One place I worked had a couple of Myfords used for making floats for flowmeters and another company used a Myford for machining cordite.
Thread: Making a hole in my headstock. Good, bad or unnecessary?
02/03/2023 19:56:45
If it makes oiling easier I would do it. Boxford obviously thought it was necessary. At the end of the day it’s your machine and you can do what you want with it.
