Member postings for Rogeman
Here is a list of all the postings Rogeman has made in our forums. Click on a thread name to jump to the thread.
Thread: Firefly
22/05/2022 17:22:09
Phil,
I was simplifying the action but as you say treat each side separately, there is plenty of room in the central block for a good depth of thread so once the outer end is in line with the outside of the frame it can be screwed in.
The same with the other connections.
I am not yet in a position to complete this assembly but just thinking ahead, I was not able to think outside the box so that was why I asked for help. Now that you have explained the procedure I understand what I need to do when I come to assemble the cylinders.
I will report back when it is completed.
Thank you again for your explanations.
Roger
22/05/2022 15:02:07
Phil,
If I understand you correctly you are saying to, for example screw pipe into cylinder twice required depth, then as the other end is screwed into the other side it unscrews half the depth. Both sides then have the same depth of thread.
That sounds like a good method central blocks and pipe work do not get in the way.
I will give it a try as soon as I can and let you know the result.
Thank you for your helpful reply.
Roger
22/05/2022 12:28:53
I am building a 3 1/2-inch firefly. I have reached a point where I have made all the cylinder parts and I am trying to work out how to fit them to the frames. In each of the frames there are two holes for the steam pipes. The steam pipes are screwed into the cylinders and valve chest.
All the threads on the pipework are right-hand threads I am unable to work out how to fasten the cylinders, valve chests and pipework together and fasten them to the frames. The steam pipes are to go through these two holes in each frame. Could someone suggest a solution to this problem, the only answer I have is to cut a slot in the top of each frame and fit the valve chest separately after having first fastened the cylinders in place.
Thread: Ipod in the workshop
21/04/2013 16:35:14
Hi,
Has anyone used the Apps available for the Ipod/Iphone from the following web site:- www.plaincode.com ?
The "Clinometer" is good for levels etc. and the "Setsquare" is good to set things up on, for example a milling machine at any angle required.
They are also Free which is even better.
Roger
Thread: Rivet size and Pitch
09/08/2010 11:41:51
I am building a 3 1/2" Firefly and would appreciate some advice on rivets.
I would like to use some for their intended purpose of holding parts such as the buffer beams to frame etc. This is straight forward.
Where I am having difficulty is on the side tanks. What size should I use, also what pitch and how many. I am not looking for precise scale detail but would like to look the part without overdoing it. There is no mention of rivet detail on the drawing.
Many Thanks
 Roger
Thread: Tachometer design
03/03/2010 15:04:50
I have followed this thread with interest and hope to learn to programme a Pic well enough to make my own Tacho one day.
Having searched the web this looks to be a good system and its free
 Roger
Edited By Katy Purvis on 01/06/2015 12:20:25
