Member postings for Mogens Kilde
Here is a list of all the postings Mogens Kilde has made in our forums. Click on a thread name to jump to the thread.
Thread: The Workshop Progress Thread 2019
28/08/2019 20:50:16
A very nice engine - absolutely great job
Thank you for sharing !
Thread: Clock #1
07/08/2019 16:14:13
a real treat from here - the first continuous ticks must be a milestone - well done!
Thread: Completed Twin Inline IC Engine
02/01/2019 18:54:29
Hi Steve
Absolutely great piece of work
Thank you for sharing this
/Mogens
Thread: Scroll Saws Again
12/04/2017 21:45:35
Hello Folks
Soon Neil will recieve my article on building a scroll saw attachment for a small lathe
Scroll Saw attachment
regards
Mogens
Edited By Mogens Kilde on 12/04/2017 21:46:22
Thread: What did you do today (2015)
30/09/2015 20:05:48
Hello Folks
Today I finished my latest project - a mini belt sander - made as an attachment tool for my bench lathe.
Lathe attachment belt sander
Mogens
02/04/2015 11:42:25
I've found that it has been a while since an update on my work of the 5 pcs. steam engines.
Today i finished the steam cylinder and steam chest part of the project, these latest parts where a rewarding complicated job to do on manual machinery. wink
Engines 02_04_2015
/Mogens
27/01/2015 21:01:11
Hi Neil
The flywheel is made from mild steel sheet
/Mogens
27/01/2015 16:32:06
Well for now the flywheels has been made and mounted onto my series of inclined steam enignes
Thread: Video showing machining like never before
21/01/2015 18:54:09
When we are at it...
This will take a lot of tea if it was to be made in my workshop
embarrassed
11/01/2015 19:00:35
Today I mounted the crosshead on my 5 pcs. series of an Inclined Steam Engine.
As something new I intend to sell some of my engines after finishing the project.
Mogens Kilde
Thread: Hick & Son Crank Overhead Engine
22/01/2014 12:49:09
When I use the piercing saw, it is 5 strokes (of course pulling) then candle wax, 5 stroke candle vax, 5 strike candle vax , well you got it right ....
Makes the blade last for very long, think i might be combination of cooling and lubricating the blade this way.
Mogens
Thread: 15-day Skeleton Timepiece
26/01/2013 12:50:26
Thanks Russell
No the plate is mild steel plate, if (when) the plate become gray/brown i don't mind, I love that color
26/01/2013 11:08:10
Hi Roy
I've just looked around for broct escapement's, and can see that you are absolutely right - thank you for pointing this out for me.
I think the friction in the escapement will be reduced when I turn around the pallets.
Thanks again
Mogens
25/01/2013 06:15:01
Hello Michael
Thank you
I will try to remember to insert a link in future postings, I can see the problem with some part of the url beeing invisble
regards
Mogens
24/01/2013 19:55:35
Hello all
Just wanted to update you on my projects. This link point to a video where I test the escapement
http://smg.beta.photobucket.com/user/m_kilde/media/20130124_194659_zpsa1602743.mp4.html
Mogens
28/12/2012 14:25:31
Hello folks
Just wanted to show my tool for winding the main spring
Hope the photos tell the function, otherwise you just ask, I'll be happy to answer
Regards and a hope for a happy new year to all of you
Mogens
18/12/2012 06:07:44
Hello folks
Thank you very much, I will go ahead in the workshop.
Wish you all a merry christmas.
Mogens
17/12/2012 19:42:56
Hi John
On the M & P website I find the following for the partnumber 0321 204015 :
HOLE END CLOCK MAINSPRING 20mm x 0.40mm x 40mm You will find other sizes of mainspring in chapter 15. Clock-grade steel.e
I believe this means that the thickness (Force) i 0.4 mm and that the width (barrel height) is approximately 20 mm, this leave the 40mm to be the inside diameter of barrel
Is this correct ?
Mogens
17/12/2012 17:36:20
Thanks to you all, now I can go on with experimenting The last 40 mm dims. is that the outer diameter of the coiled spring when supplied ?
Mogens
17/12/2012 11:13:52
Hi Roy
Thanks for your reply.
Exactly... Thats why I would like to know the approximate dimension, and experiment in the work shop
Mogens
